Home » Eclipse Projects » Sirius » Sirius post-condition expression?
Sirius post-condition expression? [message #1608022] Mon, 09 February 2015 03:06 Go to next message
We already have Precondition Service to prevent creating diagram. But how about the post-service after diagram created?
One of use cases, after diagram loaded/ re-loaded, i would like to activate Read-Only mode, which Not allow user drag/drop/delete/edit any elements in the diagram.
Any solution?
Thanks.
Thanh Huy LE.
Re: Sirius post-condition expression? [message #1610082 is a reply to message #1608022] Tue, 10 February 2015 09:44 Go to previous messageGo to next message
If I understand right, you want Sirius to behave as a viewer instead of
an editor?
In the DiagramDescription, if you describe only describe a "Delete tool"
with no action in its tasks, you will obtain a diagram where to user is
not able to drag/drop/delete/edit any elements in the diagram. However,
he will be able to move them in the diagram.
Is this solution good enough?
Steve
Le 09/02/2015 09:06, Huy Le a écrit :
> Any solution?
> Thanks.
> Thanh Huy LE.
Steve Monnier - Obeo
Need professional services for Sirius?
Re: Sirius post-condition expression? [message #1681050 is a reply to message #1610082] Tue, 17 March 2015 02:45 Go to previous messageGo to next message
Hello Steve,
See my answer as below:
an editor?
=> YES.
=> Moving is not allowed as well.
Another solution is removeEditPolicy of each EditPart, but when any change in the model, the policy is reset, the diagram back to editable mode.
I'm still in stuck.
Re: Sirius post-condition expression? [message #1681964 is a reply to message #1681050] Tue, 17 March 2015 10:37 Go to previous message
Depending your goal, maybe exporting representation as images is enough?
You can do it programmatically by using the API
DialectUIManager.INSTANCE.export(...).
If your really need to use Sirius as a viewer (well a read-only editor),
you either can implement a ResourceSetListener in post-commit which
rolls-back the transaction or implement a IPermissionAuthority that will
return false to the canEditFeature/Instance methods.
Steve
Le 17/03/2015 07:45, Huy Le a écrit :
> Hello Steve,
> an editor?
> => YES.
> mode.
> I'm still in stuck.
Previous Topic:Removing element from a list with in an operation
Next Topic:Edge centering problem
Current Time: Tue Jun 17 14:46:12 EDT 2025
Powered by FUDForum. Page generated in 0.04751 seconds
