Home » Eclipse Projects » Eclipse Platform » Problem installing plugins on R3.0 M5
Problem installing plugins on R3.0 M5 [message #160770] |
Sun, 23 November 2003 16:11  |
Originally posted by: jmordax.terra.es
Is there a new mechanism to install plugins via File system in this new
version?
I have unzipped into /features and /plugins for example the Samples zip
and when I start Eclipse it doesn't detect the new feature. ¿?
I did the same test with other plugins like Eclipse-games with the same
result.
Any comment?
Thanks in advance,
Chemi.
Re: Problem installing plugins on R3.0 M5 [message #160965 is a reply to message #160908] |
Mon, 24 November 2003 09:53   |
Ok. Thanks a lot.
So, is this the new way to do this now? Is there any preference to
enable the automatic detection when starting up (like previous versions)?
Thanks again,
Chemi.
Horváth, Csaba wrote:
>Hi,
>I had the same problem, but it was solved. I have selected Help-->Software
>Updates-->Manage configuration (if there is no such menu item you have to
>'customize perspective' and add 'software updates' command to the
>perspective), and enabled the feature I wanted.
>HTH,
>Regards,
>Csaba
>"Chemi" <jmordax@terra.es> wrote in message news:bpr7ra$ml1$1@eclipse.org...
>>version?
>>result.
>>Any comment?
>>Thanks in advance,
>> Chemi.
Re: Problem installing plugins on R3.0 M5 [message #161145 is a reply to message #161113] |
Mon, 24 November 2003 12:33   |
--------------070400070105000208070700
Content-Type: text/plain; charset=us-ascii; format=flowed
dorian birsan wrote:
>"Chemi" <jmordax@terra.es> wrote in message news:bpt682$jka$1@eclipse.org...
>>Ok. Thanks a lot.
>I think this is a side-effect of some changes in the platform code and I
>will investigate it.
>On the other hand, this new behavior seems more appealing, because it could
>lead to removing the update reconciler from the sensitive startup process,
>and would have the user going through the update manager (Manage
>Configuration...) to enable the newly unzipped features.
Well, it was a really easy way to install things.... and the platform
asked you to validate the installation or decline it (as it seems it is
doing now by default). I don't know. I think it is a matter of likes....
and I was used to the other way.
So theoretically, is this going to be the new way to work? Or is it a bug?
Thanks for your comments,
Chemi.
Content-Type: text/html; charset=us-ascii
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
dorian birsan wrote:<br>
<blockquote type="cite" cite="midbptdsb$utj$1@eclipse.org">
<pre wrap="">"Chemi" <a class="moz-txt-link-rfc2396E" href="mailto:jmordax@terra.es"><jmordax@terra.es></a> wrote in message <a class="moz-txt-link-freetext" href="news:bpt682$jka$1@eclipse.org">news:bpt682$jka$1@eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Ok. Thanks a lot.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
likes.... and I was used to the other way.<br>
<br>
bug?<br>
<br>
Thanks for your comments,<br>
<br>
Chemi.<br>
</body>
</html>
--------------070400070105000208070700--
Re: Problem installing plugins on R3.0 M5 [message #161371 is a reply to message #161145] |
Mon, 24 November 2003 22:44   |
------=_NextPart_000_009C_01C3B2DC.96123230
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Currently it is a bug introduced by RCP, or at least it appears so. We =
are tracking it down.
"Chemi" <jmordax@terra.es> wrote in message =
news:bptfk3$v1$1@eclipse.org...
Ok. Thanks a lot.
enable the automatic detection when starting up (like previous =
versions)?
=20
On the other hand, this new behavior seems more appealing, because it =
could
lead to removing the update reconciler from the sensitive startup =
process,
Well, it was a really easy way to install things.... and the platform =
asked you to validate the installation or decline it (as it seems it is =
doing now by default). I don't know. I think it is a matter of likes.... =
So theoretically, is this going to be the new way to work? Or is it a =
bug?
Chemi.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE></TITLE>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Currently it is a bug introduced by =
RCP, or at=20
least it appears so. We are tracking it down.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Chemi" <<A =
href=3D"mailto:jmordax@terra.es">jmordax@terra.es</A>>=20
wrote in message <A=20
href=3D"news:bptfk3$v1$1@eclipse.org">news:bptfk3$v1$1@eclipse.org</A>...=
</DIV>dorian=20
birsan wrote:<BR>
<BLOCKQUOTE cite=3Dmidbptdsb$utj$1@eclipse.org type=3D"cite"><PRE =
wrap=3D"">"Chemi" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:jmordax@terra.es"><jmordax@terra.es></A> wrote in =
message <A class=3Dmoz-txt-link-freetext =
href=3D"news:bpt682$jka$1@eclipse.org">news:bpt682$jka$1@eclipse.org</A>.=
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Ok. Thanks a lot.
versions)?
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
could
process,
</PRE></BLOCKQUOTE>
<DIV>Well, it was a really easy way to install things.... and the =
platform=20
asked you to validate the installation or decline it (as it seems it =
is doing=20
now by default). I don't know. I think it is a matter of likes.... and =
I was=20
used to the other way.<BR><BR>So theoretically, is this going to be =
the new=20
way to work? Or is it a bug?<BR><BR>Thanks for your=20
comments,<BR><BR> =20
Chemi.</DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_009C_01C3B2DC.96123230--
Re: Problem installing plugins on R3.0 M5 [message #174223 is a reply to message #161649] |
Sun, 28 December 2003 05:05  |
--------------010603080107020705000104
Hi Dorian, that entry said it was fixed on M6 but I am seeing exactly
the same problem.
Any update? Have you decided to change the way installation via file
system works?
Thanks in advance,
Chemi.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=47458
> "Chemi" <jmordax@terra.es <mailto:jmordax@terra.es>> wrote in
> message news:bpv1ug$hf2$1@eclipse.org...
> Ok. If you are investigating already, I understand it exists
> already an opened bug. Do you mind to send me the URL?
> Thanks again,
> Chemi.
<html>
<head>
<title></title>
</head>
the same problem.<br>
<br>
system works?<br>
<br>
Thanks in advance,<br>
<br>
Chemi.<br>
<br>
<blockquote type="cite" cite="midbq07vk$2qb$1@eclipse.org">
<title></title>
<meta name="GENERATOR" content="MSHTML 6.00.2800.1276">
<div><font size="2" face="Arial"><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=47458">https://bugs.eclipse.org/bugs/show_bug.cgi?id=47458</a></font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;"
dir="ltr">
<div>"Chemi" <<a href="mailto:jmordax@terra.es">jmordax@terra.es</a>>
wrote in message <a href="news:bpv1ug$hf2$1@eclipse.org">news:bpv1ug$hf2$1@eclipse.org</a>...</div>
Ok. If you are investigating already, I understand it exists already an
opened bug. Do you mind to send me the URL?<br>
<br>
Thanks again,<br>
<br>
Chemi.<br>
<br>
<blockquote type="cite" cite="midbpuj3i$695$1@eclipse.org">
<style></style>
<div><font size="2" face="Arial">Currently it is a bug introduced
by RCP, or at least it appears so. We are tracking it down.</font></div>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------010603080107020705000104--
Current Time: Sat Jun 14 12:46:21 EDT 2025
Powered by FUDForum. Page generated in 0.26683 seconds
