Home » Eclipse Projects » Sirius » [SWTBotTest] How to retrieve/check exists of a context menu
[SWTBotTest] How to retrieve/check exists of a context menu [message #1597141] Sun, 01 February 2015 23:56 Go to next message
I wrote a test to check an context menu not available as expected.
I've found no api support it. What i can do is using try..catch(WidgetNotFoundException) which is not a good solution since it take time till timeout happen, increase test time execution.
Do we have better answer for the issue?
Thanks.
Thanh Huy LE
[Updated on: Mon, 02 February 2015 00:57] by Moderator
Re: [SWTBotTest] How to retrieve/check exists of a context menu [message #1602484 is a reply to message #1597141] Thu, 05 February 2015 10:45 Go to previous messageGo to next message
I think that you could do that by modifying a little the service
SWTBotUtils.hasContextMenu(...).
In this service there is a call to swtBotContextMenu.exist(). This one
has a waiting condition on the menu item, that execute this test:
items.addAll(menuFinder.findMenus(matcher));
return !items.isEmpty();
You can try to have the same test but without the waiting condition.
Steve
Le 02/02/2015 05:56, Huy Le a écrit :
> Hello,
> I've found any api support it. What i can do is using
> Thanks.
> Thanh Huy LE
Steve Monnier - Obeo
Need professional services for Sirius?
Re: [SWTBotTest] How to retrieve/check exists of a context menu [message #1607974 is a reply to message #1602484] Mon, 09 February 2015 02:24 Go to previous messageGo to next message
However, SWTBotUtils.hasContextMenu() applied to TreeItem. The method requires two objects: Display and Control where we can retrieve them by call treeItem.display and treeItem.widget.getParent()
How can we do same thing via SWTBotGefEditor when a node selected?
As I know, editor.getWidget().getDisplay() return Display. What proper method return the Control?
(I expect editor.getSWTBotGefViewer().getControl() but the method is protected)
Thanh Huy LE
Re: [SWTBotTest] How to retrieve/check exists of a context menu [message #1610020 is a reply to message #1607974] Tue, 10 February 2015 08:51 Go to previous message
To access the Control using the SWTBotGetEditor, you need to recover the
EditPart of the Diagram and then its viewer. Therefore you should use
the following expression:
editor.getDiagramEditPart().getViewer().getControl().
Steve
Le 09/02/2015 08:24, Huy Le a écrit :
> protected)
> Thanh Huy LE
Previous Topic:Navigate Different Metamodels
Next Topic:Disable vertical reordering of executions nodes in Sequence diagram representations
Current Time: Mon Jun 16 08:48:04 EDT 2025
Powered by FUDForum. Page generated in 0.06598 seconds
