Home » Newcomers » Newcomers » installing 3.2 using Update Manager
installing 3.2 using Update Manager [message #159623] Wed, 05 July 2006 10:52 Go to next message
Originally posted by: pavel.sapozhnikov.gmail.com
Hi can anybody help me with installing 3.2 using Update Manager. How do I
do it? I ran update manager and I did both of the choices and I didn't get
any results for 3.2 can you guys tell me how to do it.
Thanks.
Re: installing 3.2 using Update Manager [message #159631 is a reply to message #159623] Wed, 05 July 2006 11:31 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
Pavel,
You can not update major Eclipse versions via the Update Manager. You
need to do a clean install of base Eclipse 3.2 to a new directory, then
you can use Update Manager to add additional plug-ins. See
http://www.eclipse.org/callisto/ for details.
Hope this helps,
- Jeff
Re: installing 3.2 using Update Manager [message #159639 is a reply to message #159631] Wed, 05 July 2006 11:46 Go to previous messageGo to next message
Jeff Myers wrote:
> Pavel,
> Hope this helps,
> - Jeff
Hi Jeff. So lets say I do just a clean install which is fine. I am using
pydev plugin for eclipse and I already have a workspace and all that
stuff and also I dont want to loose my preferences that is my
configuration such as coloring of the code etc. How would I go about not
losing all that.
Re: installing 3.2 using Update Manager [message #159659 is a reply to message #159639] Wed, 05 July 2006 13:24 Go to previous messageGo to next message
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Pavel Sapozhnikov schreef:
> Jeff Myers wrote:
>> Pavel,
>> then you can use Update Manager to add additional plug-ins. See
>> Hope this helps,
>> - Jeff
> losing all that.
It is recommended to first take a copy of you workspace, install the new
Eclipse *next to* the old one, point the new Eclipse to the copy, and
keep the old copy at hand for when something goes wrong. Once
everything is going fine, you can delete the old copy and the old Eclipse.
H.
Hendrik Maryns
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFEq/Xne+7xMGD3itQRAhZjAJ0Xu/MjEU8ummBef/EXQNXLU7tzjgCd Gw1b
zYL91R6NdhCcv4C0WDUd7jM=
=PmH5
-----END PGP SIGNATURE-----
Re: installing 3.2 using Update Manager [message #159667 is a reply to message #159659] Wed, 05 July 2006 13:37 Go to previous messageGo to next message
> Hash: SHA1
>> Jeff Myers wrote:
>>> Pavel,
>>> Hope this helps,
>>> - Jeff
>> losing all that.
> H.
> Hendrik Maryns
> http://aouw.org
> =PmH5
What do you mean when you say "next to". Also all my plug-ins will be
gone. So what do I do about that. Just install the plug-ins again?
Re: installing 3.2 using Update Manager [message #159674 is a reply to message #159667] Wed, 05 July 2006 14:24 Go to previous messageGo to next message
Hash: SHA1
>>>> Jeff Myers wrote:
>>>>> Pavel,
>>>>> Hope this helps,
>>>>> - Jeff
>>>> losing all that.
> Eclipse.
I mean: leave the old Eclipse where it is, and install the new one in a
different folder (or, if you want to have a specific name for the
folder, rename the old one first). Yes, you plug-ins will be gone, you
will have to reinstall them too. I find this a PITA when upgrading
Eclipse, they should take an example from Mozilla. However, the update
manager now comes with some predefined sites which contain much of the
most-wanted plugins.
Otherwise, you can export your update sites in the old eclipse, and
import them in the new one (see the update sites window).
H.
Hendrik Maryns
http://aouw.org
iD8DBQFErAPGe+7xMGD3itQRAqvfAJ4xhHcNdci3Y4i9um02fsOMz1KwTgCe I0xm
923aL/56AZ+hnFdzBmQOcYM=
=aA1b
Re: installing 3.2 using Update Manager [message #159691 is a reply to message #159659] Wed, 05 July 2006 17:16 Go to previous message
I think the Eclipse website really needs to have prominent instructions
on how to upgrade. I made this suggestion a few days ago but got no
feedback. Should I file a bug/feature request somewhere?
-Jeff
Previous Topic:Subclipse, Eclipse & Ant
Next Topic:Eclipse v2.0 - Annoying dialog box
Current Time: Fri Sep 19 11:26:32 EDT 2025
Powered by FUDForum. Page generated in 0.09477 seconds
