Home » Newcomers » Newcomers » Upgrade Problem
Upgrade Problem [message #159506] Tue, 04 July 2006 04:27 Go to next message
Originally posted by: bernhard.boehm.bhs.at
Hi all,
I am using Eclipse 3.0.1 for a very long time now, and I just wanted to
upgrade to the new 3.2.0 version. Unfortunately, when I "Search for
updates" in Eclipse, the only possible Eclipse SDK update I get, is 3.0.2!
Is there a possibilty (aside from a complete fresh installation) that I
upgrade from 3.0.1 directly to 3.2.0 - or do I have to upgrade step by
step (from 3.0.1 to 3.0.2, then somewhen to 3.1.0 and afterwards to
3.2.0)?!
Thanks for your infos!
Bernhard Böhm
Re: Upgrade Problem [message #159514 is a reply to message #159506] Tue, 04 July 2006 05:01 Go to previous messageGo to next message
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Bernhard Boehm schreef:
> Hi all,
> 3.2.0)?!
No. The major version changes are not covered by the update manager.
You will need to do a fresh install. This is reasonable, as the
workspace lay-out is not backwards compatible. I.e. it is recommended
to copy your workspace, install the new Eclipse *next to* the old one,
point it to the copy of the workspace, and only delete it if, after some
time, you are sure everything works fine.
H.
Hendrik Maryns
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFEqi5ve+7xMGD3itQRAqNYAJ0Qyetfvr2mF4IARBSsh2knDidoBgCe IW2c
T+jqsXeylXmj/BLdwLuZMcU=
=zqMl
-----END PGP SIGNATURE-----
Re: Upgrade Problem [message #159523 is a reply to message #159514] Tue, 04 July 2006 05:10 Go to previous messageGo to next message
Thanks Hendrik for the answer!
One major question still for me is, if all preferences set (mainly the
CVS-properties) are also usable in the upgraded version, without any
problems?! Because nearly all our projects are stored in the CVS
repository...
Bernhard
Re: Upgrade Problem [message #159530 is a reply to message #159523] Tue, 04 July 2006 05:40 Go to previous message
Hash: SHA1
> repository...
Yes. But you’ll also have to reinstall all plugins and features you are
using. This can be easily done by first exporting the update sites,
then importing them in the new version and find updates.
CVS is built-in, so no probs there.
H.
Hendrik Maryns
http://aouw.org
iD8DBQFEqjd/e+7xMGD3itQRAvn+AJsHFen7f1DjwDPz0JIaW+KKoXPqmACf ZfBh
XVB8xf4jiT1wIn9/4pGQ0uw=
=ENnh
Previous Topic:Fix copyrights problem
Next Topic:NPE with j9
Current Time: Thu Oct 16 10:39:40 EDT 2025
Powered by FUDForum. Page generated in 0.09312 seconds
