Home » Language IDEs » Java Development Tools (JDT) » Run Ant... Error: Config file is not of expected XML Type
Run Ant... Error: Config file is not of expected XML Type [message #155655] Thu, 22 April 2004 23:56 Go to next message
Originally posted by: something.something.com
I am running Eclipse 2.1.1 with JDK 1.4.2_01.
When I try to Run Ant..., after highlighting the plugin.xml, I get the
error:
plugin.xml:6: Config file is not of expected XML type.
This is when trying to Run ant for the org.eclipse.core.boot/plugin.xml.
here are the first six lines of the plugin.xml (I didn't change it)
<plugin
id="org.eclipse.core.boot"
name="pluginName"
version="2.1.1"
provider-name="providerName">
It seems to be a problem with Eclipse itself. I was able to gen the
build.xml's a few weeks ago, but something seems to have happened since.
This happens with all plugins I try to open up.
Any ideas?
thanks...
Re: Run Ant... Error: Config file is not of expected XML Type [message #155664 is a reply to message #155655] Thu, 22 April 2004 23:58 Go to previous messageGo to next message
You do not run Ant on the plugin.xml.
You need to Run Ant... on the build.xml that you generate from the
plugin.xml
HTH
Darins
"RPM" <something@something.com> wrote in message
news:c6a3qu$j94$1@eclipse.org...
> error:
> <plugin
> name="pluginName"
> version="2.1.1"
> Any ideas?
> thanks...
Re: Run Ant... Error: Config file is not of expected XML Type [message #155688 is a reply to message #155664] Fri, 23 April 2004 00:47 Go to previous message
oops, sorry for the newbie question!
thanks
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:c6a3u7$jad$1@eclipse.org...
> plugin.xml
> HTH
> Darins
> > error:
> > <?xml version="1.0" encoding="UTF-8"?>
> > <plugin
> > name="pluginName"
> > version="2.1.1"
> > Any ideas?
> > thanks...
Previous Topic:Editor does not react any more after refactoring
Next Topic:What will AST ultimately support?
Current Time: Sun Jul 20 11:44:45 EDT 2025
Powered by FUDForum. Page generated in 0.03351 seconds
