Home » Eclipse Projects » Sirius » Interaction with tree and table views
Interaction with tree and table views [message #1553382] Thu, 08 January 2015 12:19 Go to next message
I would like to know if it possible to interact programmatically with the views provided by Sirius (typically table view and/or tree view), in order for example to change the selected element(s) or to listen for events (selection change, double-click on an item). If the answer is yes, what documentation should I look for ?
Thanks in advance.
Re: Interaction with tree and table views [message #1554661 is a reply to message #1553382] Fri, 09 January 2015 05:27 Go to previous messageGo to next message
Hi Frédéric,
If you talk about tree and table editor, as they use JFace TreeViewer,
you can use JFace/SWT API to add listeners to be notified of SWT changes.
Best Regards.
Le 08/01/2015 18:19, Frédéric Botron a écrit :
> Thanks in advance.
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: Interaction with tree and table views [message #1554963 is a reply to message #1554661] Fri, 09 January 2015 09:25 Go to previous messageGo to next message
Hello Esteban,
Yes, using the TreeView object to get access to the tree's selection and events (without modifying directly the underlying model) was my intent.
But my main problem is to find my way to the TreeViewer object from the Sirius Session object. What API calls do I need to get it ?
I am behind a company firewall which prevents me from packaging the Sirius Javadoc using Maven, so I cannot find the information for the moment. I did not find it in https://www.eclipse.org/sirius/doc/developer/Architecture.html and I think I need the Javadoc to go further. I think I'll generate the Sirius Javadoc one evening at home Smile
[Updated on: Fri, 09 January 2015 11:08] by Moderator
Re: Interaction with tree and table views [message #1561884 is a reply to message #1554963] Tue, 13 January 2015 06:04 Go to previous messageGo to next message
Could you explain precisly your need? Elements selection depends of the
editor for which you want selection.
Best Regards.
Le 09/01/2015 15:25, Frédéric Botron a écrit :
> Hello Esteban,
> But my main problem is to find my way through the TreeViewer object
> Javadoc one evening at home :)
Re: Interaction with tree and table views [message #1561892 is a reply to message #1554963] Tue, 13 January 2015 06:05 Go to previous message
You can yet use DialectUIManager.INSTANCE.setSelection(DialectEditor,
List<DRepresentationElement>); API.
> Hello Esteban,
Previous Topic:Can't select target during edge creation
Next Topic:Create edges between siblings
Current Time: Sun Jun 15 08:24:29 EDT 2025
Powered by FUDForum. Page generated in 0.04708 seconds
