Home » Archived » BIRT » Showing only a part of a line series?
Showing only a part of a line series? [message #154915] Thu, 20 April 2006 14:53 Go to next message
Originally posted by: mikewulkan.flyingmoose.ca
I have a chart with 3 line graph series. Series 1 data is meaningful from
X1-Xa. Series 2 data is meaningful between Xa -Xb; and finally Series 3
data is meaningful between Xa - Xc.
Currently I am just setting the values of the series to 0 where the series
falls outside their meaningful ranges. However this doesn't look very nice.
Is there a way of limiting the X axis range where a line series is actually
plotted?
Mike
Re: Showing only a part of a line series? [message #155080 is a reply to message #154915] Fri, 21 April 2006 02:52 Go to previous messageGo to next message
Not really, but you could try to set some null values instead of 0 values.
It should not plot them in that case.
David
"Mike Wulkan" <mikewulkan@flyingmoose.ca> wrote in message
news:e28lap$pi2$1@utils.eclipse.org...
> nice.
> actually
> plotted?
> Mike
Re: Showing only a part of a line series? [message #155212 is a reply to message #155080] Fri, 21 April 2006 08:54 Go to previous messageGo to next message
Hi David,
Thanks, this seems to cover about 98% of the problem.
For some reason the Series 1 plot seems to interpret null values as zero and
plots them as such. But the other series behave as you describe and don't
plot the points.
Can you think of any reason this should be happening?
Mike
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:e29vfl$f5q$1@utils.eclipse.org...
> David
> > Hi,
from
series
> > nice.
> > actually
> > plotted?
> > Thanks,
> > Mike
Re: Showing only a part of a line series? [message #155219 is a reply to message #155212] Fri, 21 April 2006 09:10 Go to previous message
Ooops! Nevermind that last post. I was plotting the wrong value.
Mike
news:e2akmj$58k$1@utils.eclipse.org...
> Hi David,
and
> plot the points.
> Mike
values.
> > Thanks,
> > David
> > > Hi,
> from
3
> series
> > > nice.
> > > actually
> > > plotted?
> > > Thanks,
> > > Mike
Previous Topic:how to set a database schema ?
Next Topic:image
Current Time: Thu Oct 30 22:56:12 EDT 2025
Powered by FUDForum. Page generated in 0.04194 seconds
