Re: Can not invoke Help Content under Red Hat Linux 9 [message #142637] |
Sat, 11 October 2003 17:27  |
Originally posted by: a_v_karpov.yahoo.com
I installed Eclipse 2.1.1 under Red Hat 9 and everything is fine except I
can not invoke Help Content from Help Menu. Mozilla starts but shows an
empty page. An error is shown: 'Help can not be displayed. The embedded
application server can not run web application. Check log for details.'
I have tried to check the log but just did not find it!
Any advise is highly appreciated.
Re: Can not invoke Help Content under Red Hat Linux 9 [message #153049 is a reply to message #152955] |
Wed, 05 November 2003 10:12  |
Originally posted by: dorian.birsan.net
Hi Kurt,
Yes, I agree with your comments, particularly with the "dll hell" like
scenario.
You can also drop a different version of xerces in the ext directory and
you'll likely run into problems with eclipse 2.1.
I am not sure what the best solution is, but the reality is that this is one
of the unfortunate exceptions, and for most people things are working well.
If you can think of some fixes, please let us know, we'd be happy to use
your contributions.
-Dorian
"Kurt Baldes" <KuBaldes@aol.com> wrote in message
news:boaend$h75$1@eclipse.org...
> dorian birsan wrote:
> > Then, do you have a servlet.jar in your <jdk_install>jrelibext ?
> Gotcha!
> I threw that ugly old servlet.jar-frog onto the wall and look! the lovely
> sight of helpcontents pleased my eyes.
> Much thanks for patient guidance.
> May I generalize the result of our search through logs and configs?
> Since eclipse-version 2.1 the internal mechanism of calling the customized
> Tomcat-server has changed. With customizing also has changed structure of
> directories in which packages are placed, the same with preferences of
> classloading.
> Now a servlet.jar in <JAVA_HOME>\jre\lib\ext\ prevents help-window from
> displaying any dynamically generated content. It smells like dll-hells but
> it's not a version-problem. Any servlet.jar previous in calling-hierarchy
> than
> org.eclipse.tomcat_4.XXX causes this behaviour.
> In his book "Java Servlet Programming" Jason Hunter states:
> It doesn't much matter where you get the servlet classes, as long as you
> have them on your system ...
> An application on my system placed servlet.jar in <JAVA_HOME>\jre\lib\ext\
> (Isn't that the right place for optional packages to Java?)
> Isn't it buggy, that such a possible configuration of a target system e.
> g. for standalone help suppresses correct function?
FUDForum. Page generated in 0.04813 seconds
