Home » Eclipse Projects » Nebula » [GanttChart] resizing the GanttSections height
[GanttChart] resizing the GanttSections height [message #1517468] Fri, 19 December 2014 09:16 Go to next message
Hello guys as aforementioned in the topic's subject,
how can I modify a GanttSection's height?
Re: [GanttChart] resizing the GanttSections height [message #1518100 is a reply to message #1517468] Fri, 19 December 2014 18:12 Go to previous messageGo to next message
Did you read this? http://www.eclipse.org/forums/index.php/t/277366/
Re: [GanttChart] resizing the GanttSections height [message #1518101 is a reply to message #1518100] Fri, 19 December 2014 18:14 Go to previous messageGo to next message
Or this? http://git.eclipse.org/c/nebula/org.eclipse.nebula.git/plain/examples/org.eclipse.nebula.snippets/src/org/eclipse/nebula/snippets/ganttchart/GanttSectionExample.java
Re: [GanttChart] resizing the GanttSections height [message #1522328 is a reply to message #1518101] Mon, 22 December 2014 03:38 Go to previous messageGo to next message
Yes but it didn't help so much.
I already have all the events on a single line, now only want to shrink the standard Section's height.
[Updated on: Mon, 22 December 2014 04:36] by Moderator
Re: [GanttChart] resizing the GanttSections height [message #1523391 is a reply to message #1522328] Mon, 22 December 2014 17:33 Go to previous messageGo to next message
Hi Gio,
Please file a bug. If you would like to take a stab at a possible solution then this would be great.
Thanks for using Gantt,
Wim
Re: [GanttChart] resizing the GanttSections height [message #1536432 is a reply to message #1523391] Tue, 30 December 2014 02:44 Go to previous message
Do you override getMinimumSectionHeight() in your settings? The section height should only increase in case the calculated height is smaller than the minimum.
Previous Topic:[GanttChart] refreshing composite
Next Topic:Remove trace from XYGraph
Current Time: Fri Oct 03 13:09:26 EDT 2025
Powered by FUDForum. Page generated in 0.04326 seconds
