Home » Archived » BIRT » Weird 'parameter' effect
Weird 'parameter' effect [message #149962] Fri, 31 March 2006 08:37 Go to next message
Originally posted by: tzeeman.sogyo.nl
Following the screencast "Using data set parameters and report
parameters." in the BIRT tutorial section I came across a weird effect.
The report without parameters has a correct list of countries, states and
cities, but after I put in the parameter on country, the shown result
becomes corrupt. The countries are ok (and respect the parameterising), as
are the states. The column with the cities is plain wrong; all records
show the city belonging to the first record.
Example (paramter is 'A%'):
COUNTRY STATE CITY
Australia NSW Chatswood
Australia Queensland Chatswood
Australia Victoria Chatswood
Austria Chatswood
Austria Chatswood
31-mrt-2006 15:36
Does anyone have an idea what could be going wrong?
regards,
Thomas
Re: Weird 'parameter' effect [message #150026 is a reply to message #149962] Fri, 31 March 2006 08:18 Go to previous messageGo to next message
I just tried this and I dont get the error.
What verision of Birt are you using?
Jason
"T Zeeman" <tzeeman@sogyo.nl> wrote in message
news:0c2ab5374c4e8125eecf037364832b91$1@www.eclipse.org...
> COUNTRY STATE CITY Australia NSW Chatswood Australia NSW
> Chatswood Australia Queensland Chatswood Australia Victoria Chatswood
> Australia Victoria Chatswood Austria Chatswood Austria
> Chatswood 31-mrt-2006 15:36
> regards,
> Thomas
Re: Weird 'parameter' effect [message #150169 is a reply to message #150026] Mon, 03 April 2006 03:19 Go to previous messageGo to next message
Just checked and I'm using the birt-all-in-one download with version 2.0.1
of the BIRT feature. Update shows no newer version available (as expected;
2.0.1 being the latest dl from the site).
Thomas
Re: Weird 'parameter' effect [message #150184 is a reply to message #150169] Mon, 03 April 2006 05:11 Go to previous message
OK. Tried again and this time I started out with only the country and city
columns; first without params, which worked, and then with params, which
worked too. Afterwards I added the state and now the entire thing works.
I can't find a difference between the two reports, but one works and the
other doesn't ?:( Totally weird.
Thomas
Previous Topic:report locale
Next Topic:Sort Data in a cascading parameter
Current Time: Fri Oct 31 01:17:46 EDT 2025
Powered by FUDForum. Page generated in 1.05567 seconds
