| Problems with Nightly Build N20060328 [message #149125] |
Tue, 28 March 2006 15:46  |
Originally posted by: vladperl.semanticprogrammer.org
I have tried to use Nightly Build N20060328 with eclipse and report design
perspective dissapear.
Beside that report viewer from this build doesn't work either.
Here is exception from running test report:
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
org.eclipse.birt.report.service.ReportEngineService.setEngin eContext(UnknownSource) org.eclipse.birt.report.servlet.ViewerServlet.doGet(Unknown Source) javax.servlet.http.HttpServlet.service(HttpServlet.java:689) org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) note The full stack trace of the root cause is available in the ApacheTomcat/5.5.15 logs.------------------------------------------------------- -------------------------------------I need at least one fresh nightly build that will work fine.Please make the builds a little bit more workable :)Building from the source code didn't help me to get rid from problem withviewer.Thank you,Vladimir
FUDForum. Page generated in 0.26076 seconds
