Home » Archived » BIRT » genReport.bat usage(Usage of command line reports execution)
genReport.bat usage [message #778223] Wed, 11 January 2012 14:05 Go to next message
Hi, I downloaded birt runtime 3_7_1.
I set the birt_home variable using the command:
set birt_home=C:\Xelere\birt-runtime-3_7_1\birt-runtime-3_7_1
then I´m executing this command:
C:\Xelere\birt-runtime-3_7_1\birt-runtime-3_7_1\ReportEngine>genReport.bat -f PD
F -o test.pdf -F samples\hello_world.rptdesign
I´m getting the following error:
C:\Xelere\birt-runtime-3_7_1\birt-runtime-3_7_1\ReportEngine>ECHO off
The input line is too long.
The syntax of the command is incorrect.
As far as I looked the command should run like this. Any advices?
Esteban.
Re: genReport.bat usage [message #778230 is a reply to message #778223] Wed, 11 January 2012 15:08 Go to previous messageGo to next message
I fount the solution to this. The problem was the path for the birt_home was too long just copied the folder to c:\ and it started working.
Re: genReport.bat usage [message #1495827 is a reply to message #778230] Tue, 02 December 2014 09:53 Go to previous message
Other solution:
IN genReport.bat:
1.- Comment lines:
set BIRTCLASSPATH=
for %%i in (%BIRT_HOME%\ReportEngine\lib\*.jar) do set BIRTCLASSPATH=%%i;!BIRTCLASSPATH!
2.- Add line:
SET BIRTCLASSPATH=%BIRT_HOME%\ReportEngine\lib\*
Previous Topic:How to test Birt reports
Next Topic:Dynamic query with mongodb in BIRT
Current Time: Sun Jul 20 17:56:46 EDT 2025
Powered by FUDForum. Page generated in 0.04069 seconds
