Home » Newcomers » Newcomers » display of packages in java perspective
display of packages in java perspective [message #149404] Fri, 21 April 2006 10:39 Go to next message
Originally posted by: markmcallister.hotmail.com
In, Eclipse, I have the following package hiearchy:
com.company.dao
com.company.bo
com.company.utils
com.company.utils.html
All the sources are under /root/src (i.e. /root/src/com/company/dao), and
has been added to be on the build path. In the past, I only saw 3 of
packages appear (see below):
com.company.dao
com.company.bo
The other package, com.company.utils, did not appear because it had no
source underneath it. However, my problem is that now it appears and so do
the other directories:
com
com.company
com.company.utils
Why does Eclipse behave like this? Is this a bug or plugin issue? How may I
fix this so that only packages with source appear?
Re: display of packages in java perspective [message #149413 is a reply to message #149404] Fri, 21 April 2006 12:17 Go to previous messageGo to next message
I found out what the problem was. In my source subdirs, I had hidden SVN
folders (.svn). After I removed the .svn folders, only the packages with
source code appear. However, as you can see, now my code is unversioned. :(
What I tried to do before remove the .svn folder was to exclude them from
the build paths. This approach did not work and had no impact.
The next thing I did was remove project from the workspace, zip up the
project, remove the .svn folders (from all the subdirs, what a pain this
was), add the project back to the workspace, and only the packages with
source code appears. I then closed Eclipse, unzipped all the project files
back (not overwriting anything, and so this means only .svn files were
placed back). Now I have what I want in Eclipse (only packages with source
code appear) and my code is versioned.
This is a strange behaviour of Eclipse. If anyone else has a better
workaround or solution, let me know.
Thanks.
"mark mcallister" <markmcallister@hotmail.com> wrote in message
news:e2aqr7$ugb$1@utils.eclipse.org...
> com.company.dao
> com.company.bo
> com.company.utils
> com.company.dao
> com.company.bo
> com
> com.company
> com.company.utils
> I fix this so that only packages with source appear?
Re: display of packages in java perspective [message #149569 is a reply to message #149413] Mon, 24 April 2006 06:11 Go to previous messageGo to next message
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
It seems like somehow, the .svn folders are not any longer marked as
‘derived sources’. There should be a way to mark them thus and have the
compiler ignore them, but I don’t know how.
H.
Hendrik Maryns
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFETKRTe+7xMGD3itQRAjhMAJ4lfvV+tSbK/0Beq7Pws+Zu77jT0QCf b3Hk
ykZkh7ey/A/c83zEjSNX2MM=
=D51C
-----END PGP SIGNATURE-----
Re: display of packages in java perspective [message #150855 is a reply to message #149569] Tue, 02 May 2006 16:06 Go to previous message
When I installed subclipse AND do a fresh svn checkout, and finally open
up/restart Eclipse, the problem goes away. I think behind the scene,
subclipse may be marking the .svn directories to be ignored or as you stated
"derived sources."
I do not like using subclipse--in the past, it has locked my files and
corrupted my svn repository. Moreover, it has this annyoying UI bug--even if
all sources are committed, the root folder may be showing still as changed.
Excluding from the build path the .svn directories has no effect! I just
can't believe more users are not having this problem.
"Hendrik Maryns" <hendrik_maryns@despammed.com> wrote in message
news:e2i88f$blj$1@utils.eclipse.org...
> Hash: SHA1
>> files
>> source
> 'derived sources'. There should be a way to mark them thus and have the
> compiler ignore them, but I don't know how.
> H.
> Hendrik Maryns
> http://aouw.org
> =D51C
Previous Topic:j2see standard tools
Next Topic:can't start eclipse in Linux (debian)
Current Time: Thu Oct 23 03:19:09 EDT 2025
Powered by FUDForum. Page generated in 0.07367 seconds
