| JavaScript [message #148471] |
Wed, 23 November 2005 04:55  |
Originally posted by: harald.albrecht.plt.rwth-aachen.de
I have a question concerning the Outline view when editing JavaScript:
So far, the outline shows all functions on the outmost level, as well as
variables (var xxx = ...) within these functions and variables on the
outmost level.
However, the outline skips typical JS idioms, such as defining the
prototype and defining methods on the prototype (at least I think that
they are typical, but YMMV). In particular, object initializers are
completely ignored. For instance:
function FOO() {
FOO.prototype = {
bar: function() = {},
baz: function() = {}
Is someone already thinking about tackling this issue. Since I have to
experience in hacking Eclipse: where should I start looking at when I want
to add proper parsing for the aforementioned object initializers in order
to make them appear in the outline view?
Any help greatly appreciated!
-- Harald
| Re: JavaScript [message #148605 is a reply to message #148573] |
Wed, 23 November 2005 13:13   |
On Wed, 23 Nov 2005 12:21:03 -0500, Harald Albrecht <harald.albrecht@plt=
..rwth-aachen.de> wrote:
> I looked into the CVS tree but wasn't able to find the lexical
> specification for the parser and scanner, albeit the source files carr=
y
> notes that they have been created using SableCC. Do you have an idea w=
here
> the JavaScript lexical definitions and grammar can be found?
Yes, we have not included the original SableCC "spec", the reason being =
is
the original author (not me! :) said that they "hand modified" the gener=
ated
code so much, that it no longer resembled the perser generator version a=
nd
could not really be re-generated. And, if we every "re-did" it, we would=
n't
want to use SableCC.
This hand tweaking is of course a bad practice, and one enhancement, amo=
ng many, would
be to "clean up" the java script parser, even recreate it?!, as well as
add "object oriented" functionality you mentioned.
We've mentioned before we have no plans to enhance the javascript editor=
much,
just due to not-enough-people-to-do-everything and would most welcome
participation from the larger community. Of course,
we know its no small task. We've had some interest expressed, but no
committments.
| Re: JavaScript [message #148846 is a reply to message #148605] |
Thu, 24 November 2005 03:32   |
David Williams wrote:
> Yes, we have not included the original SableCC "spec", the reason being is
> the original author (not me! :) said that they "hand modified" the generated
> code so much, that it no longer resembled the perser generator version and
> could not really be re-generated. And, if we every "re-did" it, we wouldn't
In the past I had worked with JFlex in the RemoteTea ONC/RPC project when
developping a Java-based rpcgen protocol compiler. My impression is that
JFlex is easy to use, you write the grammar and embed Java code into the
rules in order to create your object tree representing the information
retrieved.
Since I'm new to Eclipse plugins: I currently do not understand how the
parser is activated, especially in view of the user typing some new text
somewhere in his file. You surely don't want to reparse the whole thing
over and over again? If incremental parsing would be required, would it
then make sense to write a hand-made parser?
Harald
| Re: JavaScript [message #149201 is a reply to message #148846] |
Fri, 25 November 2005 11:13  |
> when developping a Java-based rpcgen protocol compiler. My impression is
> that JFlex is easy to use, you write the grammar and embed Java code
> into the rules in order to create your object tree representing the
> information retrieved.
You'll find that the CSS, DTD, XML, and JSP source parsers used by
the editors in WTP were all written using JFlex.
The JSEditor does activate reparsing based on changes to the text.
Changes trigger JFace DocumentEvents and the JSLineStyleListener
tries to reparse incrementally to keep the syntax coloring up to
date. A seperate call is made to update the outline view. As David
pointed out earlier, we would *greatly* welcome participation from
the larger community of contributors to improve the JavaScript editor.
- Nitin
FUDForum. Page generated in 0.04772 seconds
