Home » Archived » BIRT » How does "use report data" work in charts?
How does "use report data" work in charts? [message #149024] Tue, 28 March 2006 10:53 Go to next message
Originally posted by: brice.ruth.isthmusgroup.com
I've put together a report that's pretty simple - it groups on one column,
and then provides a total of rows in the group footer. I would like to use
this data in a chart - so it seems that the chart's "use report data"
would be the ticket for this. However, I cannot find any documentation on
how this is supposed to work.
Maybe I'm barking up the wrong tree? I am still pretty new to BIRT.
Thanks in advance,
Brice Ruth
Re: How does "use report data" work in charts? [message #149084 is a reply to message #149024] Tue, 28 March 2006 12:52 Go to previous messageGo to next message
"Use Report Data" means that the chart uses the data of its container. So
it's only useful if the chart is embedded inside a table or list.
David
"Brice Ruth" <brice.ruth@isthmusgroup.com> wrote in message
news:1f081f63f1c22457798f21d169b42a73$1@www.eclipse.org...
> Thanks in advance,
> Brice Ruth
Re: How does "use report data" work in charts? [message #149104 is a reply to message #149084] Tue, 28 March 2006 13:20 Go to previous messageGo to next message
OK - are there any examples/tutorials/documentation of this? Where do I
look? It doesn't seem as intuitive as dragging a chart into a table.
Here's the group I want to visualize:
<group id="84">
<property name="groupName">Duration</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression
name="keyExpr">row["Duration"]</expression>
<header>
<row id="85">
<cell id="86">
<data id="96">
<expression
name="valueExpr">row["Duration"]</expression>
</data>
</cell>
<cell id="87"/>
<cell id="88"/>
</row>
</header>
<footer>
<row id="89">
<cell id="90"/>
<cell id="91">
<data id="107">
<expression
name="valueExpr">Total.count()</expression>
</data>
</cell>
<cell id="92"/>
</row>
</footer>
</group>
> David
>> Thanks in advance,
>> Brice Ruth
Re: How does "use report data" work in charts? [message #149207 is a reply to message #149104] Wed, 29 March 2006 03:22 Go to previous message
Hi Brice,
I think there are some report wizards with such configuration (chart inside
a table), that guide you to create similar reports.
You can put the chart in the group header or footer, it should work.
David
news:8ce535b5c93d3f8630cdd40c7c934f4e$1@www.eclipse.org...
> <group id="84">
> <expression
> <header>
> <row id="85">
> <cell id="86">
> <data id="96">
> <expression
> </data>
> </cell>
> <cell id="87"/>
> <cell id="88"/>
> </row>
> </header>
> <footer>
> <row id="89">
> <cell id="90"/>
> <cell id="91">
> <data id="107">
> <expression
> </data>
> </cell>
> <cell id="92"/>
> </row>
> </footer>
> </group>
>> Thanks,
>> David
>>> column, and then provides a total of rows in the group footer. I would
>>> like to use this data in a chart - so it seems that the chart's "use
>>> report data" would be the ticket for this. However, I cannot find any
>>> documentation on how this is supposed to work.
>>> Thanks in advance,
>>> Brice Ruth
Previous Topic:Footer page
Next Topic:MYSQL and BIRT
Current Time: Wed Nov 05 08:15:38 EST 2025
Powered by FUDForum. Page generated in 0.04433 seconds
