Home » Language IDEs » Java Development Tools (JDT) » Any luck getting CVSNT to work with Eclipse?
Any luck getting CVSNT to work with Eclipse? [message #147345] Thu, 04 March 2004 15:38 Go to next message
Originally posted by: wilco909.hotmail.com
I am trying to get Eclipse 3.0 M7 to work with CVSNT 2.0.34
Every time I launch Eclipse, I get the following error in the "Problems"
window:
"A class file was not written. The project may be inconsistent, if so
try refreshing this project and rebuilding it."
When I attempt to "Refresh with Remote" I get:
"ERROR: Refreshing 'CVS Workspace' with remote: An error occurred while
synchronizing with remote contents."
I am not using CVS prefixes (I've read that causes problems). I don't
have any attachment to CVSNT but I would like a source control system
integrated with Eclipse and don't have a UNIX box handy. If that is
really a necessity, I can get it set up.
Re: Any luck getting CVSNT to work with Eclipse? [message #147380 is a reply to message #147345] Thu, 04 March 2004 19:27 Go to previous messageGo to next message
Originally posted by: smesh.openrules.com
Our Eclipse 3.0 M7 is OK with CVSNT 2.0.9 on Windows 2000 Pro.
Sam Mesh - http://openrules.com
Life is very short, and there's no time,
For coding and testing, my friend.
Re: Any luck getting CVSNT to work with Eclipse? [message #148136 is a reply to message #147380] Wed, 10 March 2004 23:25 Go to previous messageGo to next message
Hmmm. That's the same version of Eclipse that I'm using and I'm using
the newer (and according to the web site, the most stable) 2.0.34
version of CVSNT.
This is really frustrating and I have no idea how to troubleshoot this
further. I am trying to make this installation as plain as possible and
I get these bizarre errors that don't turn up in any search engines...
Any ideas anyone?
Re: Any luck getting CVSNT to work with Eclipse? [message #148345 is a reply to message #148136] Fri, 12 March 2004 13:22 Go to previous message
> version of CVSNT.
> Any ideas anyone?
I've encountered similar (but not identical) problems with CVSNT 2.0.34
and Eclipse 2.1.2 on Windows 2000 (SP4). It was no longer possible to
synchronize with the repository after a file has been deleted locally.
The cvs server is running on the same machine.
A working solution for my problem was to downgrade to 2.0.26. Then
everything worked ok again (I had to disable the "Setuid LSA Agent" in
the install setup due to fatal crashes in lsass.exe that always ended in
a reboot of Windows! - that problem has been fixed in 2.0.34, btw).
Previous Topic:How to get IJavaProject inside builder
Next Topic:Run As.../JUnit Plugin Test
Current Time: Sun Jun 15 23:47:56 EDT 2025
Powered by FUDForum. Page generated in 0.03938 seconds
