Home » Eclipse Projects » SWTBot » Clicking on menu Eclipse in Mac OSX
Clicking on menu Eclipse in Mac OSX [message #1470446] Wed, 12 November 2014 05:43 Go to next message
I managed already to click on the "File" menu, but it seems that menu "Eclipse", the one just next to the Apple icon, is not a typical menu.
This code doesn't work for this menu:
private static SWTWorkbenchBot bot = new SWTWorkbenchBot();
bot.menu("Eclipse").menu("Preferences...").click();
Any idea how to access this menu ?
thanks,
Benoît
Re: Clicking on menu Eclipse in Mac OSX [message #1532069 is a reply to message #1470446] Sat, 27 December 2014 15:43 Go to previous messageGo to next message
Theres no way to access the Application Menu using standard SWTBot API, i had tried to extend SWTBot to support the Application Menu but found a bug in the process.
To access the menu you need to call
Display display = ....
Menu appMenu = display.getSystemMenu()
You will be using the set widget directly, so will need to synchronise with the ui thread.
a1dutch
Re: Clicking on menu Eclipse in Mac OSX [message #1538762 is a reply to message #1532069] Wed, 31 December 2014 09:52 Go to previous message
Thanks a lot Andrew for the hint !
For sake of completeness, below the full code which worked in my case.
final IWorkbench workbench = PlatformUI.getWorkbench();
workbench.getDisplay().asyncExec(new Runnable() {
public void run() {
IWorkbenchWindow window = workbench.getActiveWorkbenchWindow();
if (window != null) {
Menu appMenu = workbench.getDisplay().getSystemMenu();
for (MenuItem item : appMenu.getItems()) {
if (item.getText().startsWith("Preferences")) {
Event event = new Event();
event.time = (int) System.currentTimeMillis();
event.widget = item;
event.display = workbench.getDisplay();
item.setSelection(true);
item.notifyListeners(SWT.Selection, event);
break;
[Updated on: Wed, 31 December 2014 09:53] by Moderator
Previous Topic:Seletion on Nebula gridview
Next Topic:select 2 nodes of tree SWTbot
Current Time: Sat Aug 30 23:39:49 EDT 2025
Powered by FUDForum. Page generated in 0.05457 seconds
