Home » Newcomers » Newcomers » Force syntax coloring
Force syntax coloring [message #146846] Wed, 05 April 2006 05:36 Go to next message
Originally posted by: j.westra.takumi-tech.com
Hi all,
I would like to know how I can force a certain kind of syntax coloring on
a file, i.e. tell Eclipse to consider file x as e.g. a Pyhon file.
We have executable python scripts without the .py extension. Eclipse does
not see it's python, and just displays it as any textfile, without syntax
coloring. It should be easy to tell Eclipse to color it as any python file.
Re: Force syntax coloring [message #146852 is a reply to message #146846] Wed, 05 April 2006 06:08 Go to previous messageGo to next message
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Jurjen Westra schreef:
> Hi all,
> on a file, i.e. tell Eclipse to consider file x as e.g. a Pyhon file.
> does not see it's python, and just displays it as any textfile, without
> syntax coloring. It should be easy to tell Eclipse to color it as any
> python file.
RMB on file, Open with..., choose Python editor.
If those executables have a consistent extension other than .py, you
could define a new file association. Type those last two words in the
preferences filter.
H.
Hendrik Maryns
www.lieverleven.be
http://aouw.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFEM5cce+7xMGD3itQRAmq0AJ9TFURghcCvSkHSIa4/QFkRak64QgCf XMAM
5Yfgo4tl8FWq5IkUYmVOHiE=
=85/M
-----END PGP SIGNATURE-----
Re: Force syntax coloring [message #146855 is a reply to message #146852] Wed, 05 April 2006 06:38 Go to previous messageGo to next message
That does not work: I only have the options Text Editor, System Editor and
Default Editor. I am using Eclipse 3.1.2. Is choosing the python editor a
feature of newer versions? I do have python syntax coloring when I open a
py file.
In general, executable scripts could have been written in any scripting
language (the first line with #! gives it away to the system), so I can
not make a new file association (we also use perl a lot).
Re: Force syntax coloring [message #146858 is a reply to message #146855] Wed, 05 April 2006 07:34 Go to previous message
Hash: SHA1
> and Default Editor. I am using Eclipse 3.1.2. Is choosing the python
> editor a feature of newer versions?
You?re right. You will first have to add the Python editor as an editor
for this kind of files. If they have no ending, I don?t know of a way,
if they have all kind of different endings, you can enter the ending *.*
in file associations, and add the Python editor to that.
Also have a look at the content-type preferences, it might help.
H.
Hendrik Maryns
www.lieverleven.be
http://aouw.org
iD8DBQFEM6tCe+7xMGD3itQRAoP9AJ9sEN4xRlkKXOD9icKLinSRYZzbbgCb Bbf1
3PcaWPyWebLZgRtLOu3qm90=
=jVvZ
Previous Topic:Modifying the java editor
Next Topic:Creating a new Editor
Current Time: Fri Jul 25 23:32:59 EDT 2025
Powered by FUDForum. Page generated in 0.32579 seconds
