Home » Eclipse Projects » GEF » Drag and Drop issue
Drag and Drop issue [message #145795] Sat, 31 July 2004 06:18 Go to next message
Originally posted by: justinaruja.isletsystems.com
Hello All,
I have a window with more than one containers (say 2containers).
Container1 have a list of jobs that must be assigned to workers.
Container 2 have a row of workers.
when I drag a job from the list and drop it on worker's row it must
change to another object.
Please direct me how to achieve this
Thanks in advance
Damian
Re: Drag and Drop issue [message #145974 is a reply to message #145795] Mon, 02 August 2004 12:31 Go to previous messageGo to next message
Does the underlying model change or just the visual representation?
"Damian" <justinaruja@isletsystems.com> wrote in message
news:cefril$ssd$1@eclipse.org...
> Hello All,
> Thanks in advance
> Damian
Re: Drag and Drop issue [message #146017 is a reply to message #145795] Mon, 02 August 2004 15:06 Go to previous messageGo to next message
The default drag tracker uses orphan+add contributions. If you decide to
handle everything in ADD, you can ignore the orphan requests everywhere.
Then, it just becomes an issue of how you interpret "ADD" when it is from a
job to a worker. You can interpret it (in the worker's editpolicy) to mean
assign the worker that job.
The other alternative is to customize the tracker and use new request
types/objects.
> Hello All,
> Thanks in advance
> Damian
Re: Drag and Drop issue [message #146418 is a reply to message #145974] Wed, 04 August 2004 00:32 Go to previous messageGo to next message
Hello Pratik,
Underlying model get change.
Damian
> > Hello All,
> > Thanks in advance
> > Damian
Re: Drag and Drop issue [message #146663 is a reply to message #146418] Thu, 05 August 2004 12:14 Go to previous message
Like Randy said, when you drag a job from container 1, container 1 will get
an orphan request to remove that job. Then container2 will get an add
request to add the job. Rather, if you are dropping on top of a worker,
that worker will get an add request. The worker can then determine what is
the right course of action and return an appropriate command. In this case,
you might want to ignore adding the given job (which means it will get
deleted), and add something else to the model (the new object that you want
it to change to).
"damian" <justinaruja@isletsystems.com> wrote in message
news:ceposr$3gm$1@eclipse.org...
> Hello Pratik,
> Regards
> Damian
> > > Hello All,
> > > Thanks in advance
> > > Damian
Previous Topic:Is it possible to disable PaletteEntries?
Next Topic:Visio stencil to GEF
Current Time: Sun Sep 07 00:00:39 EDT 2025
Powered by FUDForum. Page generated in 0.29426 seconds
