Home » Eclipse Projects » GEF » GEF 3.0 Installed but not in my plug-in list?
GEF 3.0 Installed but not in my plug-in list? [message #145632] Fri, 30 July 2004 05:12 Go to next message
I've downloaded and installed the GEF 3.0 plugin using
Help->Software_Updates, without any problems.
I can see the plugins & features in my eclipse-3.0/features and
eclipse-3.0/plugins folders, and Eclipse says they are enabled.
When I list the plugins using Windows->Show_View->Plugins, the GEF plugin(s)
are not listed.
Additionally the GEF examples I'm trying to build cannot resolve their GEF
plugin dependency.
I'm new to eclipse and know I must be doing something wrong.
Any hints would be very wellcome.
Thanks, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #145651 is a reply to message #145632] Fri, 30 July 2004 05:12 Go to previous messageGo to next message
Originally posted by: yogender.globalworldtech.com
Download the gef plugin first and then extract it ur in eclipse directory
try this
window->Preferences-Plug-in-Developemnt->TargetPlatform->Reload
remember the location should be the eclipse/plugin .
Then Restart the eclipse
Steve Jones wrote:
> are not listed.
> plugin dependency.
> Thanks, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #145659 is a reply to message #145651] Fri, 30 July 2004 05:52 Go to previous messageGo to next message
Yogender wrote:
> Hi
I'm not sure what you mean by "extract it".
I'm using the eaclipse default workspace.
> try this
When I do this the dialogues location edit input is set to the default
"/local/apps/eclipse-3.0", and when I rescan I just get the default plugins
(84 of them) even though the sub-directories ./plugins and ./features
contain the standard plugins as well as the down loaded GEF plugins.
> Steve Jones wrote:
>> Hi,
>> plugin(s) are not listed.
>> GEF plugin dependency.
>> Thanks, Steve.
Steve Jones
I.S.Technology Ltd
Re: GEF 3.0 Installed but not in my plug-in list? [message #145668 is a reply to message #145659] Fri, 30 July 2004 05:55 Go to previous messageGo to next message
Dwnload the GEF3.0. Its ZIP file and then extract it. If you have done
this then go to
help->software update->Manage Configuration
there u can see the file under eclipse platform.
When u click the file u will see gef installed ,right click over that and
make it enable
try this may be it can help u
yogender
Steve Jones wrote:
> Yogender wrote:
> > Hi
> > try this
> > Steve Jones wrote:
> >> Hi,
> >> Thanks, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #145715 is a reply to message #145632] Fri, 30 July 2004 14:29 Go to previous messageGo to next message
"Steve Jones" <steve@istech.demon.co.uk> wrote in message
news:ced2oc$8bd$1@eclipse.org...
plugin(s)
> are not listed.
If they are not listed, how do you know they are enabled? I am assuming
you've already tried restarting Eclipse and that didn't do it either.
> plugin dependency.
Updating classpath (right-click on plugin.xml, PDE Tools -> Update
classpath) doesn't fix it?
> Thanks, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #145769 is a reply to message #145715] Sat, 31 July 2004 04:34 Go to previous messageGo to next message
>> Hi,
> plugin(s)
>> are not listed.
I've restarted eclipse (many times).
When I say the GEF plugins are enabled, I'm just going on the following:
If I look at Help->Software Update->Manage Configuration I see:
Graphical Editing Framework SDK 3.0.0
Graphical Editing Framework 3.0.0
Graphical Editing Framework Developer Resources 3.0.0
If I look at the status of each feature (in Show Properties) eclipse reports
"This feature is configured properly"
If I do this all I see in the dialogs "Available plugins and fragments list"
is:
X org.eclipse.gef.examples.logic (3.0.0)
This is the GEF example I'm trying to build.
Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #145778 is a reply to message #145668] Sat, 31 July 2004 04:49 Go to previous messageGo to next message
yogender wrote:
> Hi
I used Help->Software Updates->Find and Install... to download the GEF
plugins so I haven't seen any actual zip files to extract.
In my ./eclipse-3.0/plugins folder I have:
org.eclipse.gef_3.0.0/
org.eclipse.gef.doc.isv_3.0.0/
org.eclipse.gef.source_3.0.0/
In my ./eclipse-3.0/features folder I have:
org.eclipse.gef.sdk_3.0.0/
> this then go to
> make it enable
It's already enabled, so when I do this the only options available are:
Replace/Disable/Uninstall
I've tried Disable, restart, then Enable.
It works but makes no difference.
Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #145880 is a reply to message #145632] Mon, 02 August 2004 02:38 Go to previous messageGo to next message
Steve Jones wrote:
Hi, me again.
Having failed to get GEF working using Help->Software_Updates, I've now
deleted all the GEF elements from my plugins & features folders.
From the site:
http://download.eclipse.org/tools/gef/downloads/drops/R-3.0- 200406251257/index.php
I've downloaded all the GEF zip files.
Having unzipped:
GEF-runtime-3.0.zip
GEF-examples-3.0.zip
I restart eclipse and enable the GEF plugins using Help->Software
Update->Manage Configuration.
If I now restart eclipse, guess what, the GEF plugins are in my plugin list,
and the GEF logic example is no longer reporting a dependency problem.
This was not the case when I downloaded the plugins directly using the
"official" Help->Software_Updates method.
I'm new the eclipse so I will not investigate what's different when using
Help->Software_Updates but something is definitely amiss.
Onward and upward.
Cheers, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #149240 is a reply to message #145880] Tue, 31 August 2004 13:00 Go to previous messageGo to next message
Originally posted by: bgrieder.NOSPAMquadrem.com
Steve,
Same thing happened to me: I am running a Eclipse 3.0 (same behaviour
with 3.1M1) on Linux GTK2.
I removed manually the folders downloaded using the Update features,
downloaded the zip and extracted them manually. It fixed the issue too.
I have downloaded other plugins and they do not seem to have the same
issue. This sounds GEF specific to me.
Cheers
Steve Jones wrote:
> Steve Jones wrote:
>>Hi,
> Hi, me again.
> From the site:
> Having unzipped:
> GEF-runtime-3.0.zip
> Onward and upward.
> Cheers, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #149598 is a reply to message #149240] Wed, 01 September 2004 11:13 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71823
This should be fixed in the latest integration build. If you have an older
Eclipse build, you can just delete those META-INF folders in the different
plug-ins.
"Grieder Bruno" <bgrieder@NOSPAMquadrem.com> wrote in message
news:ch2akj$3b2$2@eclipse.org...
> Steve,
> Cheers
> Steve Jones wrote:
> > Steve Jones wrote:
> >>Hi,
> > Hi, me again.
> > From the site:
> > Having unzipped:
> > GEF-runtime-3.0.zip
list,
using
> > Onward and upward.
> > Cheers, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #149607 is a reply to message #149598] Wed, 01 September 2004 11:36 Go to previous message
Thanks.
> plug-ins.
>>Steve,
>>Cheers
>>Steve Jones wrote:
>>>Steve Jones wrote:
>>>>Hi,
>>>Hi, me again.
>>>From the site:
>>>Having unzipped:
>>>GEF-runtime-3.0.zip
> list,
> using
>>>Onward and upward.
>>>Cheers, Steve.
Previous Topic:Disposal of figure
Next Topic:Redbook example error - Unable to create part:
Current Time: Sun Jul 20 23:56:17 EDT 2025
Powered by FUDForum. Page generated in 0.05385 seconds
