Home » Eclipse Projects » GEF » packages not recognized in Eclipse 3.0
packages not recognized in Eclipse 3.0 [message #144674] Tue, 27 July 2004 16:38 Go to next message
Originally posted by: svenkat.asu.edu
I am trying to modify the Pipe and Filter Editor
(http://eclipse-wiki.info/GefExamples). I am using Eclipse 3.0 and GEF 3.0
and it doesn't recognize the following imports:
org.eclipse.ui.IFileEditorInput
org.eclipse.ui.actions.WorkspaceModifyOperation
org.eclipse.ui.dialogs.SaveAsDialog
org.eclipse.ui.part.FileEditorInput
Have these been taken out in Eclipse 3.0?
Also, is there an HTML version of the GEF Javadocs?
Swami.
Re: packages not recognized in Eclipse 3.0 [message #144753 is a reply to message #144674] Wed, 28 July 2004 02:26 Go to previous message
> Swami.
if you have installed GEF properly, you can find the javadocs in your
eclipse-workbench under
help->help contents->GEF Developer Guide->Reference->API Reference
For changes between 2.1 and 3.0 look there:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/org.ecli pse.platform.doc.isv/porting/eclipse_3_0_porting_guide.html
regards,
Max
Previous Topic:Graph Layout?
Next Topic:Figure and ConnectionEndPointLocator
Current Time: Thu Oct 23 00:29:08 EDT 2025
Powered by FUDForum. Page generated in 0.23283 seconds
