Home » Eclipse Projects » Mylyn » When switching to new local task, explorer focused ui is not reset
When switching to new local task, explorer focused ui is not reset [message #1446000] Thu, 16 October 2014 03:52 Go to next message
I have a bunch of local tasks. When I switch from a task to a different
one that I had never worked on before, I expected mylin to reset the
project exlorer "focused ui", but it doesnt. It seems like it
initializes the new task context with the context of the previous task..
This is Mylin on Luna.
Felix
Re: When switching to new local task, explorer focused ui is not reset [message #1446001 is a reply to message #1446000] Thu, 16 October 2014 03:54 Go to previous messageGo to next message
On 16/10/2014 09:52, Felix Dorner wrote:
> Felix
Oh, and also weird: The generated commit message template in the EGit
staging view does not update either.
Re: When switching to new local task, explorer focused ui is not reset [message #1446242 is a reply to message #1446001] Thu, 16 October 2014 10:54 Go to previous messageGo to next message
What are you doing to activate the task?
The EGit staging view not updating is a known bug in EGit. It should update if you clear the commit message and then stage a file.
Sam
Re: When switching to new local task, explorer focused ui is not reset [message #1446294 is a reply to message #1446242] Thu, 16 October 2014 12:39 Go to previous messageGo to next message
In the task list view, the active task has a blue "bubble". Then to
change the task, I click on the "empty bubble" of a different task.
Ok, not a big deal anyway :) Mylin is great!
Re: When switching to new local task, explorer focused ui is not reset [message #1449643 is a reply to message #1446294] Tue, 21 October 2014 12:55 Go to previous messageGo to next message
There are some cases when activating a task where the last selected item in a view gets added to the context. Is that what you're seeing?
Re: When switching to new local task, explorer focused ui is not reset [message #1461278 is a reply to message #1449643] Tue, 04 November 2014 06:46 Go to previous messageGo to next message
Oh. Didn't know that. I thought activating a task would always start
with an empty context. I'll observe and come back here.
Re: When switching to new local task, explorer focused ui is not reset [message #1461539 is a reply to message #1461278] Tue, 04 November 2014 12:16 Go to previous message
When activating a task for the first time, starting with an empty context is the intended behaviour.
Previous Topic:Any plans to support the Cloudbees Folder Plugin in the Jenkins / Hudson Build View?
Next Topic:Commit messages has not been automatically filled with Mylyn, Jira and Gerrit
Current Time: Sat Jun 14 17:17:06 EDT 2025
Powered by FUDForum. Page generated in 0.04994 seconds
