Home » Language IDEs » C / C++ IDE (CDT) » Outline View
Outline View [message #144156] Thu, 28 April 2005 12:32 Go to next message
Originally posted by: cdoomasia.espial.com
I am a new user of the CDT plugin. I have version 2.1 installed with
Eclipse 3.0.0.
The problem I am having is that whenever I open a 'C' file in my project,
I see all the methods / includes / variables in the 'Outline View' but
when I double click on any of the methods in the View it doesn't take me
to the corresponding location in the source file.
Is there any option that I need to turn on? It worked fine when I did Java
development.
I have also turned on the C/C++ indexer in case that's needed.
Any help would be greatly appreciated.
Thanks in advance
Scatman
Re: Outline View [message #144222 is a reply to message #144156] Fri, 29 April 2005 08:55 Go to previous messageGo to next message
Originally posted by: devin_steffler.ca.ibm.com
Can you try CDT version 3.0M6 and see if you are still having problems with
the Outline View?
http://download.eclipse.org/tools/cdt/builds/3.0.0
Note that you'll need Eclipse 3.1M6 to run CDT 3.0M6.
Devin
"Scatman" <cdoomasia@espial.com> wrote in message
news:cb408da54980129e7335612c4be34264$1@www.eclipse.org...
> Hello,
> Eclipse 3.0.0.
> development.
> Thanks in advance
> Scatman
Re: Outline View [message #144624 is a reply to message #144156] Thu, 05 May 2005 09:00 Go to previous message
Generally speaking, this should work out of the box.
It doesn't require the indexer.
If you can submit the source code that reproduces this problem, I would
suggest raising a bug @ bugs.eclipse.org.
> Hello,
> Eclipse 3.0.0.
> development.
> Thanks in advance
> Scatman
Previous Topic:Question about CDT Parser behaviour and subsequent usage
Next Topic:CppUnit in Eclipse
Current Time: Fri Sep 19 11:53:54 EDT 2025
Powered by FUDForum. Page generated in 0.04321 seconds
