How to use GEF with RCP [message #144137 is a reply to message #143789] |
Fri, 23 July 2004 00:48  |
Originally posted by: yogender.globalworldtech.com
i have dowloaded the specific example and necessary plugin. And its
working fine when i run my application as run time workbench.
But I have one RCP appliaction and HelloGef1 example. So when I run this
RCP application the editor part with diagram should appear.
How to do this please help me.
Yogender
Turker Keskinpala wrote:
> I suppose you mean you want to modify an example. You should be able to
> download the specific example code or plugin and import it on your
> workbench. If you are importing an existing plugin make sure "Project with
> source folder" option is selected in "Import As" section of the import
> wizard.
> HTH,
> Turker
> "Yogender" <yogender@globalworldtech.com> wrote in message
> news:cdiqe4$fo9$1@eclipse.org...
> > Hello
> > I want to use HelloGef example from http://eclipse-wiki.info/GefExamples
> > with RCP application in eclipse3.0.
> > I am able to run it as Workbench application but now I want to use this
> > with RCP application.
> > Plese Help me
> > Thanks
> > Yogender
FUDForum. Page generated in 0.03135 seconds
