Home » Newcomers » Newcomers » ANT - specify what version of java to use
ANT - specify what version of java to use [message #143121] Wed, 15 March 2006 06:26 Go to next message
Originally posted by: chrisg.paper-river.com
I've got some java projects set up in Eclipse. These projects must be built
using Java 1.3, as they are running on a device that is limited to this JVM
version.
I have tried a numbe rof combinations of using different jdks and different
JAVA_HOME variables.
I can get Eclipse to build to 1.3 by setting the jdk to be used under the
workspace settings, however i cannot translate this to the ant build
scripts.
If i leave the eclipse jdk to 1.4, then the ant build works fine, but when i
try to run the created jar on the intended device, i get a
java.lang.NoClassDefFoundError: java/lang/StringBuilder error.
(TO my knowledge, i thought String Builder was implementeed in 1.5 not 1.4,
so i dont know how this is happening!)
So i tried switching the jdk in eclipse back to 1.3, and then running the
ant build - when doing this, the build doesnt happen, as it complains about
there not being a XML parser.
I tried having the eclipse jdk set to 1.4, and setting my JAVA_HOME variable
to the 1.3 jdk, but this creates the StringBuilder errors on the device as
before!
Can anyone explain to me how i might get this working?
Cheers
Chris
Re: ANT - specify what version of java to use [message #143202 is a reply to message #143121] Wed, 15 March 2006 11:57 Go to previous messageGo to next message
You will need to make use of the source and target attributes of the Ant
javac task.
See
http://ant.apache.org/manual/CoreTasks/javac.html
HTH
Darins
"Chris Gates" <chrisg@paper-river.com> wrote in message
news:dv8tom$qpi$1@utils.eclipse.org...
built
JVM
> version.
different
> scripts.
i
1.4,
about
variable
> before!
> Cheers
> Chris
Re: ANT - specify what version of java to use [message #143363 is a reply to message #143121] Thu, 16 March 2006 08:59 Go to previous message
Could you please give the build id?
How does your javac ant task look like?
Would you have a test case that reproduces the problem?
Olivier
Previous Topic:eclipse console no longer showing output
Next Topic:error: entry point not found
Current Time: Thu Oct 30 20:24:43 EDT 2025
Powered by FUDForum. Page generated in 0.10145 seconds
