Home » Modeling » EMF » [XCore] Can I reference a EAtribute of a Xcore model on another Xcore model (within the same package(Help with basic XCore. Referencing EAtributes from different xcore files)
[XCore] Can I reference a EAtribute of a Xcore model on another Xcore model (within the same package [message #1428983] Mon, 22 September 2014 12:33 Go to next message
I have a very simple question. Unfortunately I am very new to EMF, Ecore and Xcore. I started by using Ecore, however, since XCore was text based it was easier for me to work with it.
I made several simple models, but now I want to create a more complex model.
Lets say I want to create a model that defines a System. A System has a Plaform and Activities.
So, I though it would be best to model these two in different Xcore (maybe a mistake)
Now, my problem is:
I have an EClass Resource, within Platform.xcore, that has an attribute String name. I also have a EClass Transfer, within Acitivy.xcore.
Class Transfer
contains Resource source
contains Resource target
What I want to do know is:
derived String name get
source.name + "_" target.name
I know I am trying to insert Java code here, but I thought it would work. I get an error, logical, that says this field cannot be applied, there is no type of such in GenModel
I tried also
source.getName()
Error message: no defintion for getName()
I think this might be a stupid question. Maybe I should not have seperated the models. Is there a way of doing this?
OR if this is a simple question and there literature I can read, could you point me to it? I really can only find the wikipedia for XCore and it is not being enough.
Re: [XCore] Can I reference a EAtribute of a Xcore model on another Xcore model (within the same pac [message #1429028 is a reply to message #1428983] Mon, 22 September 2014 13:50 Go to previous messageGo to next message
João,
Comments below.
Yes, the editing experience is quite a bit nicer...
> model.
> (maybe a mistake)
It's hard to say.
> Now, my problem is:
> Acitivy.xcore.
> Class Transfer
It seems sensible...
I need to see complete example to understand the errors; after all, in
the above you're missing a '+'...
> I tried also
> source.getName()
This is an error message in your *.xcore? Where are the *.xcore's
located? In the same project? Different projects? How are the
projects related (via MANIFEST.MF dependencies) if different?
It even works to have two mutually referencing models, if they're in the
same project...
> you point me to it?
That's it.
> enough.
I can answer your questions, but you need to provide complete specific
details.
Re: [XCore] Can I reference a EAtribute of a Xcore model on another Xcore model (within the same pac [message #1429553 is a reply to message #1429028] Tue, 23 September 2014 07:45 Go to previous messageGo to next message
I apologize for the lack of information and the simple statement of the problem.
I have both .xcore files in the same package.
I have a resource.xcore which is something like this:
package project1.basic
class Resource
	String name
	int ID
	contains Position[1..1] pos
And a application.xcore:
class Transfer
	String name
		source.name + "_" + target.name
The error I am getting is the following:
(The error is on the application.xcore file and on the exact line of "source.name + "_" + target.name")
"Could not resolve reference to JvmIdentifiableElement "name""
If I try to do it via an operation, creating an op for Resource getResourceName(). The error is:
"Could not resolve reference method getResourceName()"
I am sorry to bother with this sort of errors, but I cannot find any information about it, I am also the only one in my group working with this.
I expect something like defining the methods public or private in Java,
but I don't know how to define this in Ecore language.
Can you please give me some insight?
Also can you direct me to some literature I can find on XCore or Ecore?
I have an EMF book, which does not help much with this.
Thank you in advance.
Joao Bastos
[Updated on: Tue, 23 September 2014 07:46] by Moderator
Re: [XCore] Can I reference a EAtribute of a Xcore model on another Xcore model (within the same pac [message #1429569 is a reply to message #1429553] Tue, 23 September 2014 08:10 Go to previous messageGo to next message
João,
If I have a file A.xcore containing this:
package project1.basic1
class Resource {
String name
int ID
class Position
And a file B.xcore containing this:
package project1.basic2
import project1.basic1.Resource
class Transfer
And they're both in the model folder of the same project, it all works
correctly.
So the basic problem with your example is that you can't have two
different *.xcore resources with the same package name, i.e., you can't
split a package across multiple files. You also can't have two features
named "name" in Transfer.
> the problem.
> class Resource {
> String name
> int ID
> class Transfer
> String name
> this.
> Java, but I don't know how to define this in Ecore language.
> Joao Bastos
Re: [XCore] Can I reference a EAtribute of a Xcore model on another Xcore model (within the same pac [message #1429573 is a reply to message #1429569] Tue, 23 September 2014 08:17 Go to previous messageGo to next message
Ahhhhh, I see. Now I feel kind of stupid.
But that is really helpful, and thank you for the time you took to help me.
Can I ask you a different question also on this thread ?
Re: [XCore] Can I reference a EAtribute of a Xcore model on another Xcore model (within the same pac [message #1429578 is a reply to message #1429573] Tue, 23 September 2014 08:22 Go to previous message
João,
It's best to ask unrelated questions on a different thread...
> help me.
Previous Topic:EMF complete model
Next Topic:[CDO] Legacy model changes not comitted
Current Time: Mon Jun 16 00:09:32 EDT 2025
Powered by FUDForum. Page generated in 0.04746 seconds
