Home » Eclipse Projects » Sirius » Xcore dynamic instances support(Trying to use Xcore-defined models without code generation)
Xcore dynamic instances support [message #1408512] Fri, 15 August 2014 04:48 Go to next message
Hi all,
I am experimenting with Sirius and I am really impressed by its capabilities.
One thing I would like to try out is using models defined in Xcore. This works if EMF code is generated and the generated package is available in the package registry, but does not if the Xcore model is defined in the same workspace with the VSM.
The first issue is that in the Sirius Specification Editor, Representation properties, on the Metamodels tab, the selection dialog opened by "Add from workspace" button does not show the Xcore files (only *.ecore).
The second issue is that the Model Explorer does not show the content of the dynamic instance XMIs that were created from the Xcore model. (I can open the XMIs with the Sample Reflective Ecore Editor).
The reason for using Xcore is that it enables me to define derived properties using Xbase expressions. These do not work only in the generated classes, but are evaluated even in the Reflective Ecore editor.
I am wondering whether it would be possible to have the same in Sirius-defined modelers.
Csaba
Re: Xcore dynamic instances support [message #1409610 is a reply to message #1408512] Mon, 18 August 2014 10:27 Go to previous messageGo to next message
Le 15/08/2014 10:48, Csaba Koncz a écrit :
> Hi all,
> capabilities.
Thanks for your feedback!
> (only *.ecore).
> Best regards,
> Csaba
Did you take a look to the previous topic about XCore [1] ?
Let us know if this topic answers your question.
[1]
https://www.eclipse.org/forums/index.php/mv/msg/627956/1219344/#msg_1219344
Laurent - Obeo
Need professional services for Sirius?
Re: Xcore dynamic instances support [message #1413263 is a reply to message #1409610] Thu, 28 August 2014 03:09 Go to previous messageGo to next message
Hi Laurent,
Thank you for your reply.
I checked the thread you mentioned and my scenario is the first one described in the message of Alex Lagarde: I am trying to define Sirius views on an Xcore-based metamodel.
I do have the "org.eclipse.sirius.runtime.ide.xtext" feature installed in my IDE.
However, the plugin contained in this feature (o.e.sirius.common.xtext) only contributes a resourceSet factory, it does not help in locating Xcore models in the workspace (which was the first problem I encountered).
What I then tried is to edit the .odesign file by hand and indicate the Ecore model location inside the .xcore file like this:
 <metamodel href="xm1.xcore#/EPackage"/>
This seemed to work, at least I get content assist for domain classes and features in the Specification Editor.
I am also able to create a representation file for the dynamic model instance I created from the Xcore model, but the view does not show correct data.
I am attaching a project that shows what I try to achieve. There are an .xcore file, an .xmi file containing an instance of the model, an .odesign and and .aird file, all in the model subfolder.
Thank you,
Csaba
p.s. Problems I currently see:
1. Lots of resources representing Java types (like java:/Objects/org.eclipse.emf.ecore.EPackage) being displayed in the Sirius Specification Editor. (Sometimes a see these also in the Model Explorer under the aird node.)
2. When saving the Specification Editor, A "Problems encountered in file java:/Objects/..." is reported for each Java type resource.
3. "Transaction aborted due to concurrent write" exception from the emf.transaction plugin when double clicking the aird file in Model Explorer.
I am using Sirius 2.0 stable snapshot from http://download.eclipse.org/sirius/updates/stable/2.0.0-S20140817-113443/luna
Re: Xcore dynamic instances support [message #1582930 is a reply to message #1413263] Sat, 24 January 2015 18:13 Go to previous messageGo to next message
This sounds like what I'm trying to do: create a Sirius Viewpoint Specification based on an xcore model. So I tried what Csaba tried: I added a metamodel element to the .odesign file by hand. And I'm seeing the first two problems that Csaba mentions as well, so that's probably not the right approach. However, absent any documentation as to how exactly we're supposed to point a Diagram Description to a .xcore file--they don't show up in the list of metamodels in the workspace--I don't have any other idea how to do this.
I'm also seeing something else that's rather disturbing: Sirius is eating my .xcore file. It's happened twice now and is getting tedious. The .xcore file is in a separate Xcore project. Whenever I save my Viewpoint Specification file from the Sirius Specification Editor, I get all of the problem complaints that Csaba mentions, plus one more telling me there's a problem with my .xcore file. And when I go to look at it, it's completely empty. So yeah, there's a problem with the file.
I'm a pretty patient guy, but when something destroys another file for no apparent reason, I get a bit upset. This should NEVER happen.
I'm removing the metamodel element now. It's just too much trouble. I'll deal with the diminished validation later.
Re: Xcore dynamic instances support [message #1608400 is a reply to message #1413263] Mon, 09 February 2015 08:44 Go to previous messageGo to next message
Hi Csaba,
Le 28/08/2014 09:09, Csaba Koncz a écrit :
> Hi Laurent,
An other option could be to deploy you xcore plugins, and to reference
it using the add from registry button (metamodels tab in the properties
view when you select a Diagram/Table/Tree description).
You could also open a bug to ask if it is possible to improve the add
from workspace wizard to make it propose xcore files [1].
> Thank you,
> Csaba
Thoses resources are loaded during the load of xm1.xcore, they
corresponds to types and resources referenced from your xcore model. The
editor displays all loaded resources.
This seems to be a bug occuring during the save: we/Sirius/the Xtext
bridge/the saving policy should detect that some files have been loaded
as library/external readonly resources and there should be no save
attempt on those files.
Could you create a bug for poblems 1 and 2 on the Sirius bugzilla [1] ?
I did not get this error.
Maxime - Obeo
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Sirius
Re: Xcore dynamic instances support [message #1608411 is a reply to message #1608400] Mon, 09 February 2015 08:55 Go to previous messageGo to next message
Le 09/02/2015 14:44, Maxime Porhel a écrit :
> Hi Csaba,
>> Hi Laurent,
>> in my IDE.
>> correct data.
>> Thank you,
>> Csaba
>> Explorer.
(Sirius 2.0.4-S20150206-085250/luna and also tested on master)
> Regards
Maxime - Obeo
Re: Xcore dynamic instances support [message #1608423 is a reply to message #1582930] Mon, 09 February 2015 09:00 Go to previous message
As explain to Csaba, the wizard "add from workspace" only display ecore
files. I think you could create a bug on the Sirius bugzilla to ask for
an improvment of the wizard to give it the possibility to show xcore files.
If you deploy you xcore plugins, you should be able to reference your
metamodel with the "add from registry action".
Could you open a bug for this problems with a small sample showing your
issue ? I was not able to reproduce the issue.
Maxime - Obeo
Previous Topic:How to add Ecore types as a platform resource to a Sirius design project
Next Topic:How to create an editor/diagram editpart without opening it?
Current Time: Sun Jul 20 04:20:26 EDT 2025
Powered by FUDForum. Page generated in 0.05280 seconds
