Home » Language IDEs » C / C++ IDE (CDT) » Help: CDT Java build Path issue
| Help: CDT Java build Path issue [message #140283] |
Mon, 07 March 2005 18:11  |
I'm using eclipse 3.0.1 SDK. (I've tried 3.1a5, and get the same results.)
I've downloaded and checked out via CVS all the files with
"org.eclipse.cdt-*" from the repository HEAD. NOTE: I tried looking for
CDT2.1 under the CVS "Versions" tree, but I didn't see them.
For example, if I open java source
org.eclipse.cdt-core/org.eclipse.cdt.ui/src/org/eclipse/cdt/ internal/ui/editor/CMarkerAnnotation.java,
and then select MarkerUtilities, try to "Open Declaration" or "Open call
Hierarchy", I get the following "Cannot Perform Operation" diaog: "The
resource is not on the build path of a java project.". I tried to search
this news group and google, but can't understand what exactly am I missing.
When I check these files out, aren't these already project files?
Strange... I looked at each project "properties", and I don't see any
"Java Build Path", "Java Compiler", "Javadoc Location", or "Java Task
Tags" properties in the cdt projects listed in the PDE Navigator.
What I'm trying to do is debug some part of the CDT editor, to learn
about how the code works. Specifically, in the right hand side of the C
Editor's margin, there are some rectangular markers for warnings and
errors, that takes you to the line of code, when you click on them. I'm
trying to find the code that handles these markers.
I'm running and using Eclipse/CDT under linux.
Anyone have instructions for running cdt in the runtime workbench?
In the CDT FAQ, under "Working ON the CDT", I've tried SDK and CVS
methods, but get the same error dialog...
Any help is greatly appreciated.
Frank
| Re: Help: CDT Java build Path issue [message #140289 is a reply to message #140283] |
Mon, 07 March 2005 19:10   |
Don't checkout org.eclipse.cdt-core, open it and checkout the folders in it as projects.
Same goes for org.eclipse.cdt-build and org.eclipse.cdt-debug
Frank Parrott wrote:
> Frank
| Re: Help: CDT Java build Path issue [message #140319 is a reply to message #140289] |
Tue, 08 March 2005 10:34   |
Hi Dave,
Thanks... I grabbed the source from HEAD, and running into "undefined"
errors with PlatformUI.getWorkbench()."getHelpSystem()". Currently I
can't use Eclipse3.1a5, since I'm running a very old linux (RH7.3
Enterprize, per our IT dept. for stability reasons. Eclipse 3.1m5a
requires a libc.so.6 library for launching, that I don't have.) Since
I'm using Eclipse 3.0.1, I would like to checkout the source for CDT
version 2.1. Generally I look in the CVS Versions repository, but I'm
not seeing any source projects folders for the different verions of CDT.
I'm using::pserver:anonymous@dev.eclipse.org:/home/tools.
Where is the source for build 2.1 located?
Thanks for your help.
Frank
> it as projects.
>> Hi,
>> results.)
>> for CDT2.1 under the CVS "Versions" tree, but I didn't see them.
>> call Hierarchy", I get the following "Cannot Perform Operation" diaog:
>> "The resource is not on the build path of a java project.". I tried to
>> search this news group and google, but can't understand what exactly
>> am I missing.
>> C Editor's margin, there are some rectangular markers for warnings and
>> I'm trying to find the code that handles these markers.
>> Frank
| Re: Help: CDT Java build Path issue [message #140327 is a reply to message #140319] |
Tue, 08 March 2005 11:24   |
Originally posted by: mark_melvin.amis.com
Right-click your projects, and go Team > Replace With > Another Branch
or Version...
Then refresh from the repository and you should get a list of branches
and versions. Select CDT_2_1 from Versions and you should be good to go.
Mark.
> Hi Dave,
> Frank
>> in it as projects.
>>> Hi,
>>> results.)
>>> diaog: "The resource is not on the build path of a java project.". I
>>> tried to search this news group and google, but can't understand what
>>> and errors, that takes you to the line of code, when you click on
>>> them. I'm trying to find the code that handles these markers.
>>> Frank
| Re: Help: CDT Java build Path issue [message #140352 is a reply to message #140327] |
Tue, 08 March 2005 16:24  |
Thanks Mark, that did it!
Frank
> or Version...
> Mark.
>> Hi Dave,
>> CDT. I'm using::pserver:anonymous@dev.eclipse.org:/home/tools.
>> Frank
>>> in it as projects.
>>>> Hi,
>>>> results.)
>>>> any "Java Build Path", "Java Compiler", "Javadoc Location", or "Java
>>>> Task Tags" properties in the cdt projects listed in the PDE Navigator.
>>>> the C Editor's margin, there are some rectangular markers for
>>>> warnings and errors, that takes you to the line of code, when you
>>>> click on them. I'm trying to find the code that handles these markers.
>>>> Frank
Current Time: Thu Nov 06 15:23:23 EST 2025
Powered by FUDForum. Page generated in 0.07496 seconds
