Home » Modeling » EMF » [code-gen] How to make EMF to add extra comments to the generated code
[code-gen] How to make EMF to add extra comments to the generated code [message #1392746] Wed, 02 July 2014 15:55 Go to next message
I would like to make the generated code in EMF, to have extra comments, in specific, by surrounding a method with a special tag in form of a comment, such as BEGIN-GENERATED and END-GENERATED.
The reason: I want to exclude these blocks in Sonar.
An example could be:
    // BEGIN-GENERATED
     * @Generated
    public get getName() {
        return name;
    // END-GENERATED
It would also be useful if I could also apply the same technique to fields, but having these for methods at least would already be sufficient.
Note 1: I cannot exclude the entire class/file because we have, in our legacy model, a lot of non-generated code mixed in the same class.
Note 2: I know there is a request (here) for Sonar to support the @Generated annotation, but this is still not implemented, and I'm afraid it won't get any priority since Sonar has already several options to exclude blocks using start/end tags and regular expressions.
Is there any way to extend the generator without need to rewrite the JET templates by my own?
[Updated on: Wed, 02 July 2014 17:19] by Moderator
Re: [code-gen] How to make EMF to add extra comments to the generated code [message #1392963 is a reply to message #1392746] Wed, 02 July 2014 23:39 Go to previous messageGo to next message
Silvestre,
Comments below.
> // BEGIN-GENERATED
> * @Generated
> */ public get getName() {
> return name;
> } // END-GENERATED
> sufficient.
You could only do this by modifying the templates, and even then, it's
pretty much impossible to get these to merge properly.
Can you take an inverse approach of putting // BEGIN_GENERATED at the
start of the class and mark your modified methods with // END-GENERATED
- // BEGIN_GENERATED pairs?
> Note 2: I know there is a request for Sonar to support the @Generated
No, and as I mentioned such free floating tags won't play nicely with
merging in general.
Re: [code-gen] How to make EMF to add extra comments to the generated code [message #1393093 is a reply to message #1392963] Thu, 03 July 2014 04:23 Go to previous messageGo to next message
Ed Merks wrote on Wed, 02 July 2014 23:39
What you mean by "merging". Do you mean when re-generating the code? I was expecting that the generator was agnostic to the content, and it would be just some extra lines of code.
[Updated on: Thu, 03 July 2014 04:26] by Moderator
Re: [code-gen] How to make EMF to add extra comments to the generated code [message #1393153 is a reply to message #1393093] Thu, 03 July 2014 06:18 Go to previous message
Silvestre,
If methods/fields must be deleted because they've been removed from the
model, such tags will remain; maybe that's okay. It's also not clear
what will happen if new methods/fields must be generated that it will
insert that correctly in the "comment white space cloud"; probably that
will work.
Previous Topic:Generating code for packages that only contain other packages
Next Topic:XMI id attributes not being exported
Current Time: Sun Aug 31 01:15:40 EDT 2025
Powered by FUDForum. Page generated in 0.04399 seconds
