Home » Modeling » EMF » [CDO] Increase prepared statement fetch size in DB Store
[CDO] Increase prepared statement fetch size in DB Store [message #1386362] Tue, 17 June 2014 02:03 Go to next message
Hello!
I wonder, if there is any way to configure CDO Db Store, to use user-specified fetch size for it's prepares statements?
I've into a major performance problem with OCL, where calling
SomeClass.allInstances() -> select(predicate)
was almost always leading to signal time out. After some profiling i've discovered that the problem lies into org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchingClassMapping.handleRevisions(IDBStoreAccessor, CDOBranch, long, boolean, CDORevisionHandler).
ResultSet size there is almost 300,000 elements, which is perfectly fine, since it only contains CDOIDs, but result set iteration is extremely slow, due to a low fetch size.
I've measured the performance by performing the same query, on the same DB with different fetch sizes, and here is the result:
Quering 300,000 CDOIDs:
FetchSize/Time to iterate (ms)
10/38,580
100/2,918
1,000/1,196
5,000/600
10,000/530
20,000/521
100,000/406
I haven't find any way to configure fetch size in CDO Db Store. Is there any?
Thanks in advance!
Re: [CDO] Increase prepared statement fetch size in DB Store [message #1386409 is a reply to message #1386362] Tue, 17 June 2014 07:29 Go to previous messageGo to next message
On 17-06-14 08:03, Leonid Ripeynih wrote:
> Hello!
Have you checked out this?
http://wiki.eclipse.org/CDO/Tweaking_Performance
> 10/38,580
> 100/2,918
> 1,000/1,196
> 5,000/600
> 10,000/530
> 20,000/521
> 100,000/406
> any?
> Thanks in advance!
Re: [CDO] Increase prepared statement fetch size in DB Store [message #1386439 is a reply to message #1386409] Tue, 17 June 2014 10:35 Go to previous messageGo to next message
Christophe Bouhier
Sure, but i haven't found any way to set JDBC Statement's fetchSize via cdo-server.xml
Here is a related topic to this problem:
http://www.eclipse.org/forums/index.php/t/781797/
To set fetch size author if this topic was forced to patch CDO as well...
Re: [CDO] Increase prepared statement fetch size in DB Store [message #1386538 is a reply to message #1386439] Wed, 18 June 2014 04:05 Go to previous message
In my case the problem was that everything was fetched. This means, as soon as the iterator started it should run fast.
I don't know how the OCL-statement internally works:
But further more the CDOServerExporter uses repository.handleRevisions. This really streams all data from some stored EClasses.
The default procedure for fetching revisions works differently.
[Updated on: Wed, 18 June 2014 04:06] by Moderator
Previous Topic:[EMF] Consuming org.eclipse.emf.ecore.generated_package
Next Topic:[CDO] Problem loading older revisions of object with 4.3
Current Time: Mon Nov 03 19:06:02 EST 2025
Powered by FUDForum. Page generated in 0.03513 seconds
