Home » Eclipse Projects » e(fx)clipse » Swing in JavaFX in SWT(Has anyone tried out embedding Swing in JavaFX in SWT)
Swing in JavaFX in SWT [message #1349958] Mon, 12 May 2014 08:34 Go to next message
Hi All,
I was interested to read Toms Schindl's blog on Embedding Swing into SWT on Java8. I've been testing the Albeiro project and the SWT_AWT bridge and have had problems with both (eg SWT_AWT bridge crash using GTK, refresh issues with Albeiro). Using JavaFX in embedded mode works without issues for me so far. Has anyone encountered any problems with using FXCanvas in embedded mode?
Cheers Don
Re: Swing in JavaFX in SWT [message #1356807 is a reply to message #1349958] Thu, 15 May 2014 04:21 Go to previous messageGo to next message
I've implemented a map-editor in a SwingNode, emmbedded in a FXCanvas, it worked fine so far. But it seems that the MapEditor is reacting slower.
Re: Swing in JavaFX in SWT [message #1356893 is a reply to message #1349958] Thu, 15 May 2014 05:14 Go to previous messageGo to next message
Just one warning on Luna & Gtk! By default Luna uses Gtk3 but JavaFX8
(and AWT/Swing) are linked to Gtk2 [1].
And just for me to understand. You are now embedding JavaFX into SWT and
inside JavaFX you use SwingNode to embed Swing?
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=434869
On 12.05.14 14:34, Don Smyth wrote:
> Hi All,
> Cheers Don
Re: Swing in JavaFX in SWT [message #1357362 is a reply to message #1356893] Thu, 15 May 2014 09:40 Go to previous messageGo to next message
Yes I was a bit hasty in my comment that all is OK - All works OK until exit... - where as you mention there is a GTK confict:
(SWT:3078): Gtk-CRITICAL **: IA__gtk_main_quit: assertion `main_loops != NULL' failed
This was using Efxclipse Kepler 4.3.2
I'm using SwingNode eg:
* Based on SwingJavaFxInteroperabilityDemo
* http://www.javaworld.com/article/2074496/core-java/integrating-javafx-2-0-with-swing-and-swt.html
final FXCanvas canvas = new FXCanvas(shell, SWT.NONE);
final Scene scene = SwingSceneCreator.createSwingScene();
canvas.setScene(scene);
public static Scene createSwingScene()
final SwingNode swingNode = new SwingNode();
createSwingContent(swingNode);
StackPane pane = new StackPane();
pane.getChildren().add(swingNode);
final Scene swingScene = new Scene(pane, 250, 150);
return swingScene;
private static void createSwingContent(final SwingNode swingNode) {
SwingUtilities.invokeLater(new Runnable() {
public void run() {
swingNode.setContent(new JButton("Swing button"));
I retried against the eclipse-SDK-4.4M7-linux-gtk-x86_64-efx-1.0.0-SNAPSHOT 15-May-2014 04:24
and got much more serious error:
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f68fe90a961, pid=3663, tid=140089735137024
# JRE version: Java(TM) SE Runtime Environment (8.0_05-b13) (build 1.8.0_05-b13)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.5-b02 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libgdk-x11-2.0.so.0+0x4f961] gdk_display_open+0x41
the fail happens in com.sun.glass.ui.Application on
protected static synchronized void loadNativeLibrary() {
// use the "platform default" name of "glass"
loadNativeLibrary("glass");
Cheers
D
Re: Swing in JavaFX in SWT [message #1357381 is a reply to message #1357362] Thu, 15 May 2014 09:48 Go to previous messageGo to next message
> NULL' failed
> return swingScene; }
> @Override
> public void run() {
Like I said - on 4.4 you need to force using Gtk2 by setting SWT_GTK3=0
in our env.
Tom
Re: Swing in JavaFX in SWT [message #1359631 is a reply to message #1357381] Fri, 16 May 2014 08:26 Go to previous messageGo to next message
OK, wasn't sure where to set it, there is a blog here:
http://blog.vogella.com/2014/02/21/using-eclipse-luna-on-ubunbu/
On Linux (Efx Kepler and Efx Luna) I still get the message below on exit, on windows there are no problems (Efx Kepler).
(SWT:3116): Gtk-CRITICAL **: IA__gtk_main_quit: assertion `main_loops != NULL' failed
Re: Swing in JavaFX in SWT [message #1359633 is a reply to message #1359631] Fri, 16 May 2014 08:28 Go to previous messageGo to next message
You need to file a bug against SWT and/or JavaFX.
Tom
> NULL' failed
Re: Swing in JavaFX in SWT [message #1359753 is a reply to message #1359633] Fri, 16 May 2014 09:37 Go to previous message
Done
https://bugs.eclipse.org/bugs/show_bug.cgi?id=435066 - Gtk critical warning when using JavaFX FXCanvas
Cheers
Don
Previous Topic:Problem with Tycho compiling with java8
Next Topic:How to retrieve a Scene in an e4 application?
Current Time: Sun Jul 20 13:00:27 EDT 2025
Powered by FUDForum. Page generated in 0.24854 seconds
