Home » Language IDEs » Java Development Tools (JDT) » Eclipse Ant and cvs problem
Eclipse Ant and cvs problem [message #135332] Fri, 16 January 2004 04:44 Go to next message
Originally posted by: patni76.yahoo.com
Hii All,
I encountered the following problem, when i deploy using ant and took the
resources dynamically from cvs.
get:
[cvs] Caught exception: CreateProcess: cvs
-d:server:name@cvs:/data/to/cvs checkout some_src error=2
I am stumped why=??
can someone help??
regards
guest
Re: Eclipse Ant and cvs problem [message #135421 is a reply to message #135332] Fri, 16 January 2004 10:59 Go to previous messageGo to next message
Have tried running the Ant build using -verbose or -debug to get more
information?
Does the Ant build work from the commandline?
Have you tried the Ant User mailing list?
HTH
Darins
"guest" <patni76@yahoo.com> wrote in message
news:bu8bql$4pg$1@eclipse.org...
> Hii All,
> get:
> I am stumped why=??
> can someone help??
> regards
> guest
Re: Eclipse Ant and cvs problem [message #135585 is a reply to message #135332] Sat, 17 January 2004 16:12 Go to previous messageGo to next message
Error=2 typically means "command not found".
Ant requires you to have a command-line cvs client on your PATH. Make
sure you have one installed and that it's on your PATH.
Nico
Re: Eclipse Ant and cvs problem [message #991400 is a reply to message #135585] Tue, 18 December 2012 17:12 Go to previous message
Awesome Nico...Thanks for the info.
Previous Topic:Problem Running htm With Java on Mac OSX
Next Topic:Potential deadlock when initializing Java tooling
Current Time: Mon Jun 16 09:13:22 EDT 2025
Powered by FUDForum. Page generated in 0.05170 seconds
