| Can't create Dynamic Web project using WTP [message #134824] |
Thu, 25 August 2005 04:29  |
Originally posted by: yinjun0510.gmail.com
I am using Eclipse 3.1 and WTP 0.7 under WinXP SP2
I have installed emf-sdo-xsd-SDK-2.1.0.zip,GEF-SDK-3.1.zip and
JEM-SDK-1.1.zip
I have installed Tomcat 4.1 and it works.
But when I try to create a Dynamic Web project,after I enter the name
for this Dynamic Web project,an error msg came out:"The selected version
is not supported by the server."
Why?
| Re: Can't create Dynamic Web project using WTP [message #135299 is a reply to message #135250] |
Fri, 26 August 2005 08:26  |
The J2EE version is something separate from the JDK version. When
creating a Dynamic Web Project, be sure to display the Advanced section
so you can see the Module Version, which is the same as the Servlet spec
version. The following table maps the J2EE version to the Module Version:
J2EE 1.2 = Module Version 2.2
J2EE 1.3 = Module Version 2.3 (also supports 2.2)
J2EE 1.4 = Module Version 2.4 (also supports 2.3 and 2.2)
The Dynamic Web Modules default to Module Version 2.4, which is a
version that Tomcat 4.1 does not support. You would need Tomcat 5.0.x
or later for such a web module. You need to switch the Module Version
to 2.3 or 2.2 for it to run on Tomcat 4.1.
Larry
Jun Yin wrote:
> Thank you!
> I installed JBoss4.0.2,the error went away!
> When I typed something in and select "Run on server",then I tried to
> select Tomcat as the server, another error msg showed up: "Tomcat
> version 4.1 only supports J2EE 1.2 and 1.3 Web modules". My JDK version
> is 1.4.2, I think that is why I can't create the project before Jboss
> installed.
> Or should I use JDK 1.5 instead to avoid such problems?
> BTW: lomboz-3.1 doesn't work in my Eclipse, also because of the JDK
> version? ........
FUDForum. Page generated in 0.03164 seconds
