Home » Language IDEs » C / C++ IDE (CDT) » CDT 2.1 Bug ? All References and All Decleration Retriever not working
CDT 2.1 Bug ? All References and All Decleration Retriever not working [message #134431] Tue, 11 January 2005 11:34 Go to next message
Originally posted by: s.sch.a
The message in the Status is "The operation is unavailable on the current
selection"
Is this a Bug or have I a configuration error ?
Thanks for your help ! I really need this feature !
Re: CDT 2.1 Bug ? All References and All Decleration Retriever not working [message #134504 is a reply to message #134431] Tue, 11 January 2005 20:00 Go to previous messageGo to next message
Could be either.
Please describe what your workspace/project looks like.
- Compiler
- C vs. C++
- Are your include paths set up?
JC
"Sascha" <s@sch.a> wrote in message news:cs0v6u$7od$1@www.eclipse.org...
> selection"
Re: CDT 2.1 Bug ? All References and All Decleration Retriever not working [message #134537 is a reply to message #134504] Wed, 12 January 2005 02:24 Go to previous messageGo to next message
Originally posted by: an.nym.us
Compiler is GNU
Code is 90% C++ (*.cpp and *.h)
"Include Path and Symobls" is set up with many paths
Discovered Paths are none (make files are external)
in "Project Paths" :
"Source" only has the entry of the CurrentProject with an
exclusion filter.
"Output" only has the entry of the CurrentProject with an
exclusion filter.
The Rest is empty
Did I missconfigure something here ?
johnc wrote:
> Could be either.
> - Compiler
> - C vs. C++
> JC
>> selection"
Re: CDT 2.1 Bug ? All References and All Decleration Retriever not working [message #134574 is a reply to message #134537] Wed, 12 January 2005 08:20 Go to previous messageGo to next message
If you run g++ -v on one of your .cpp files, you'll see there are a bunch of
intrinsic include paths that our discovery feature finds for you.
I would suggest enabling the Scanner Discovery feature.
JohnC
"Sascha" <an@nym.us> wrote in message news:cs2jbq$uc4$1@www.eclipse.org...
> Compiler is GNU
> exclusion filter.
> exclusion filter.
> The Rest is empty
> johnc wrote:
> > Could be either.
> > - Compiler
> > - C vs. C++
> > JC
current
> >> selection"
Re: CDT 2.1 Bug ? All References and All Decleration Retriever not working [message #134584 is a reply to message #134574] Wed, 12 January 2005 10:52 Go to previous messageGo to next message
I checked it is enabled !
> Thanks
> JohnC
>> Compiler is GNU
>> exclusion filter.
>> exclusion filter.
>> The Rest is empty
>> johnc wrote:
>> > Could be either.
>> > - Compiler
>> > - C vs. C++
>> > JC
> current
>> >> selection"
Re: CDT 2.1 Bug ? All References and All Decleration Retriever not working [message #134704 is a reply to message #134584] Wed, 12 January 2005 20:20 Go to previous message
Yet there are no discovered paths?
Are the Discovery Options set up to point at the compiler used in your
makefile?
"Sascha" <an@nym.us> wrote in message news:cs3h4n$jp8$1@www.eclipse.org...
bunch of
> > Thanks
> > JohnC
> >> Compiler is GNU
> >> exclusion filter.
> >> exclusion filter.
> >> The Rest is empty
> >> johnc wrote:
> >> > Could be either.
> >> > - Compiler
> >> > - C vs. C++
> >> > JC
> > current
> >> >> selection"
Previous Topic:Building and debugging VC++ code in Eclipse
Next Topic:Environment variables during build
Current Time: Sat Jul 19 06:57:10 EDT 2025
Powered by FUDForum. Page generated in 0.04796 seconds
