Home » Modeling » GMF (Graphical Modeling Framework) » Can not view .ecore_diagram in editor but see in outline
Can not view .ecore_diagram in editor but see in outline [message #13388] Wed, 09 August 2006 19:44 Go to next message
I am trying GMF tutorial 1. After install all plugins and load
mindmap.ecore, I tried to "initialize ecore_diagram diagram file" to the
mindmap.ecore file. After the mindmap.ecore_diagram file generated, I saw an
diagram in the outline tab, but not in the ecore editor tab. The diagram
seems to be there in the editor but just not visible to me. I can do arrange
all and other actions in the menu, but not seeing the diagram. Anyone knows
why?
I am using a Window 2000 w/ service 4. No special configuration added. What
I did is starting from a fresh eclipse 3.2 build and utilize the Callisto
update to load GMF and its dependencies. Exactly like the tutorial said.
Lisa
Re: Can not view .ecore_diagram in editor but see in outline [message #13409 is a reply to message #13388] Wed, 09 August 2006 19:50 Go to previous messageGo to next message
I guess you got your newsreader working!
For Windows 2000, do a Google search for GDI+ and install this library. It
is similar to the problem with the Cairo library missing on Linux machines,
from what you describe (assuming I interpret you correctly).
Rich
On 8/9/06 7:44 PM, in article ebds0k$54d$1@utils.eclipse.org, "Lisa Huang"
> why?
> Lisa
Re: Can not view .ecore_diagram in editor but see in outline [message #14409 is a reply to message #13409] Wed, 09 August 2006 20:33 Go to previous messageGo to next message
Rich,
Thank you for your reply. I downloaded the gdi+, but I am not sure how to
use the dll and how it related to ecipse. I restart my eclipse, but nothing
changed.
I attached the screen shot to this email. Basically, I can select the
diagram or part of the diagram, and see each class properties. I can even
add new EAnnotation to the diagram. The only thing I did not see is the
diagram itsef.
I tried the exactly steps in Linux. Diagram generated and shown fine in
Linux. Thanks,
Lisa
"Richard Gronback" <richard.gronback@borland.com> wrote in message
news:C0FFECED.8ABE%richard.gronback@borland.com...
machines,
> Rich
saw an
arrange
knows
> > why?
What
Callisto
> > Thanks,
> > Lisa
  • Attachment: Doc2.doc
    (Size: 114.00KB, Downloaded 173 times)
Re: Can not view .ecore_diagram in editor but see in outline [message #14435 is a reply to message #14409] Wed, 09 August 2006 20:41 Go to previous messageGo to next message
Perhaps this will help:
http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03973.html
- Rich
On 8/9/06 8:33 PM, in article ebdut4$1fc$1@utils.eclipse.org, "Lisa Huang"
> Rich,
> changed.
> diagram itsef.
> Linux. Thanks,
> Lisa
> machines,
>> Thanks,
>> Rich
> saw an
> arrange
> knows
>>> why?
> What
> Callisto
>>> Thanks,
>>> Lisa
Re: Can not view .ecore_diagram in editor but see in outline [message #14495 is a reply to message #14435] Wed, 09 August 2006 20:48 Go to previous message
That helps. Thanks a lot.
Lisa
news:C0FFF8DF.8AC6%richard.gronback@borland.com...
> - Rich
> > Rich,
to
nothing
> > changed.
even
> > diagram itsef.
> > Linux. Thanks,
> > Lisa
It
> > machines,
> >> Thanks,
> >> Rich
Huang"
the
> > saw an
diagram
> > arrange
> > knows
> >>> why?
> > What
> > Callisto
said.
> >>> Thanks,
> >>> Lisa
Previous Topic:Compartment children
Next Topic:Is it possible to separate the widgets into Palette?
Current Time: Wed Sep 03 03:27:19 EDT 2025
Powered by FUDForum. Page generated in 0.05435 seconds
