Home » Archived » BIRT » The extension point [org.eclipse.birt.report.model.encryptionHelper] is not foun
The extension point [org.eclipse.birt.report.model.encryptionHelper] is not foun [message #132185] Fri, 17 February 2006 09:26 Go to next message
Originally posted by: harikrishnan_j2003.rediffmail.com
Sir,
When i run the sample code given in RunTimeEngine API which will
convert the .rptdesign file into HTML file,i am getting the error
not found. Error code:EXTENSION_POINT_NOT_FOUND
I am using birt-runtime2_0_0
Eclipse3.1.1
JDK1.5.0
EMF2.1.1
GEF3.1.1
how to resolve this.
Thankyou
Harikrishnan J.
Re: The extension point [org.eclipse.birt.report.model.encryptionHelper] is not foun [message #132301 is a reply to message #132185] Fri, 17 February 2006 11:00 Go to previous messageGo to next message
This is a known issue. It doesnt hurt anything.
Jason
"Harikrishnan" <harikrishnan_j2003@rediffmail.com> wrote in message
news:4af6c11af4a1f8e24d47dc1e3e21b300$1@www.eclipse.org...
> Sir,
> Eclipse3.1.1
> JDK1.5.0
> EMF2.1.1
> GEF3.1.1
> Thankyou
> Harikrishnan J.
Re: The extension point [org.eclipse.birt.report.model.encryptionHelper] is not foun [message #132495 is a reply to message #132301] Sat, 18 February 2006 01:51 Go to previous messageGo to next message
Sir,
I Thankyou for your reply to my mail,but why i asked that doubt is
Why i want to resolve that Error:
I have option to send the report to anyone as a mail in my project,but
when i create report using BIRT,it is saved as .rptdesign file ,which
cannot be sent as mail,so i hard-code to convert into HTML & PDF format,so
that it can be sent.
What i used:
I used that example given under RunTimeAPI in the Integration page for
conversion after doing all work prescribed in that to successfully run
it,then why i am getting error.
ErrorMessage:
Message:The extension point
[org.eclipse.birt.report.model.encryptionHelper] is not found. Error
BIRT_HOME i set:
I set BIRT_HOME path as d:\eclipse3.1.1\eclipse\plugins in the Eclipse
preferences which too resulted in vain.
My configuration is:
Eclipse 3.1.1
BIRT Report Designer Framework 1.0.1
JDK 1.5.0
EMF SDK 2.1.1
GEF SDK 3.1.1
birt-runtime-2_0_0 which has Report Engine2.0 to run the example
JAR files i included:
axis
jaxrpc
axis-ant
saaj
commons-discovery-0.2
wsdl4j-1.5.1
itext-1.3
prototype all these files were placed in the corresponding location as
mentioned in the Integration Page.
ENGINE Home i set:
EngineConfig config = new EngineConfig();
config.setEngineHome("D:/birtruntime/birt-runtime-2_0_0/ReportEngine ");
How to run that program successfully?
Thankyou
Harikrishnan .J
Re: The extension point [org.eclipse.birt.report.model.encryptionHelper] is not foun [message #132517 is a reply to message #132495] Sat, 18 February 2006 09:19 Go to previous message
Sir,
I Apologize for the reply i have sent in response to your
answer,Although it throws that error ,it didn,t place any Hurdle in
Executing the code successfully and i got output in HTML & PDF Format,
which i didn't seen ,when i sent the first reply to your answer.Ignore the
Reply i have sent to you
asking how to Execute that code successfully.
I once again Thankyou for guiding me.
Thankyou
Harikrishnan J.
Previous Topic:How to Share DataSource & Styles Accross reports
Next Topic:values in row has to be displayed as columns
Current Time: Sun Jul 27 09:25:29 EDT 2025
Powered by FUDForum. Page generated in 0.04321 seconds
