Home » Archived » Visual Editor (VE) » SWT components Dont appear in VE pallette
SWT components Dont appear in VE pallette [message #131493] Wed, 27 September 2006 08:41 Go to next message
Originally posted by: hkjonus.yahoo.com
Ive downloaded the SWT package from the eclipse website. Unfortunatley there
are NO installation instructions, and when i try to use Help>Software
Updates, it tells me there is nothing in the folder that can be installed.
Some how (Import I think) I did manage to get the components to show up in
the Naviagtor under Junit.junit.org.eclipse.swt, however I dont think they
are truley installed as I cannot see them in the VE palette. Someone
please!!!
Re: SWT components Dont appear in VE pallette [message #131509 is a reply to message #131493] Wed, 27 September 2006 09:33 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
You don't need to separately install SWT to develop SWT classes in the
VE. The most straightforward to way to use SWT in VE is to create a new
Java project, then create a new Visual Class extending one of the SWT
classes (Shell, Composite, etc). By doing this, your project will be
configured to have the SWT library accessible, and the SWT items will
show up in the VE palette.
Hope this helps,
- Jeff
> please!!!
Re: SWT components Dont appear in VE pallette [message #131550 is a reply to message #131509] Wed, 27 September 2006 15:21 Go to previous messageGo to next message
trying to do what you sugested. a little confused though. i tried to enter
"extends org.eclipse.swt.shell" in the class definition.
cant seem to find that class and everything i type is red underlined.
"Jeff Myers" <jefmyers@us.ibm.com> wrote in message
news:efduic$5fn$1@utils.eclipse.org...
> You don't need to separately install SWT to develop SWT classes in the VE.
> The most straightforward to way to use SWT in VE is to create a new Java
> project, then create a new Visual Class extending one of the SWT classes
> (Shell, Composite, etc). By doing this, your project will be configured
> to have the SWT library accessible, and the SWT items will show up in the
> VE palette.
> Hope this helps,
> - Jeff
>> there are NO installation instructions, and when i try to use
>> Help>Software Updates, it tells me there is nothing in the folder that
>> can be installed. Some how (Import I think) I did manage to get the
>> components to show up in the Naviagtor under Junit.junit.org.eclipse.swt,
>> however I dont think they are truley installed as I cannot see them in
>> the VE palette. Someone please!!!
Re: SWT components Dont appear in VE pallette [message #131561 is a reply to message #131550] Wed, 27 September 2006 15:45 Go to previous message
Go to New->Visual Class. In the Style tree on the left, expand SWT and
select Shell. Name the class and press Finish. The VE will open with a
class containing the SWT shell. If you want the class to be runnable,
check the create main stub check box in the new Visual Class wizard.
- Jeff
>> VE palette.
>> Hope this helps,
>> - Jeff
Re: SWT components Dont appear in VE pallette [message #614664 is a reply to message #131493] Wed, 27 September 2006 09:33 Go to previous message
Hope this helps,
- Jeff
> please!!!
Re: SWT components Dont appear in VE pallette [message #614667 is a reply to message #131509] Wed, 27 September 2006 15:21 Go to previous message
> VE palette.
> Hope this helps,
> - Jeff
Re: SWT components Dont appear in VE pallette [message #614668 is a reply to message #131550] Wed, 27 September 2006 15:45 Go to previous message
- Jeff
>> VE palette.
>> Hope this helps,
>> - Jeff
Previous Topic:ve debugging
Next Topic:ve debugging
Current Time: Sat Nov 08 04:07:12 EST 2025
Powered by FUDForum. Page generated in 0.04232 seconds
