Installation with p2 director fails and it's really slow [message #1309257] |
Tue, 22 April 2014 11:29  |
I'm trying to create an automated installer in the command line. Currently I'm trying to install the Xtend SDK.
This is the script I'm running:
site_kepler="http://download.eclipse.org/releases/kepler"
site_xtext_releases="http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases"
eclipse/eclipse \
-data $HOME/workspace-automated \
-clean \
-consolelog \
-noSplash \
-application org.eclipse.equinox.p2.director \
-repository $site_kepler,$site_xtext_releases \
-installIU org.eclipse.xtend.sdk.feature.group \
-profile SDKProfile \
-followReferences \
-bundlepool $HOME/.eclipse_bundlepool \
-destination $PWD/eclipse
But it fails:
!ENTRY org.eclipse.equinox.p2.touchpoint.eclipse 4 0 2014-04-22 17:15:14.544
!MESSAGE Error while loading manipulator.
!STACK 0
java.lang.IllegalStateException: The framework persistent data location (/home/andras/installer/eclipse/configuration) is not the same as the framework configuration location (/home/andras/installer/eclipse/configuration).
at org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxManipulatorImpl.checkConsistencyOfFwConfigLocAndFwPersistentDataLoc(EquinoxManipulatorImpl.java:65)
at org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxManipulatorImpl.loadWithoutFwPersistentData(EquinoxManipulatorImpl.java:348)
at org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxManipulatorImpl.load(EquinoxManipulatorImpl.java:319)
at org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManipulator.loadDelegate(LazyManipulator.java:55)
at org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManipulator.getConfigData(LazyManipulator.java:108)
at org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.SetProgramPropertyAction.execute(SetProgramPropertyAction.java:38)
at org.eclipse.equinox.internal.p2.engine.ParameterizedProvisioningAction.execute(ParameterizedProvisioningAction.java:38)
at org.eclipse.equinox.internal.p2.engine.Phase.mainPerform(Phase.java:183)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:95)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:75)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:41)
at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:23)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.executePlan(DirectorApplication.java:783)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.planAndExecute(DirectorApplication.java:776)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.performProvisioningActions(DirectorApplication.java:763)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.run(DirectorApplication.java:1063)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.start(DirectorApplication.java:1245)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Installation failed.
An error occurred while configuring the installed items
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Configure, operand=null --> [R]org.eclipse.equinox.ds 1.4.101.v20130813-1853, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.SetProgramPropertyAction).
Caused by: Application failed, log file location: /home/andras/workspace-automated/.metadata/.log
I've seen a post that mentioned that the -destination and the -bundlepool arguments need to be absolute paths but using those hasn't helped. Also, the process is very slow. Much slower than in the GUI.
I'd highly appreciate someone helping me figure out a solution. Thank you.
[Updated on: Tue, 22 April 2014 11:30] by Moderator
FUDForum. Page generated in 0.03835 seconds
