Home » Newcomers » Newcomers » moved eclipse, now says jre should be in eclipse folder
moved eclipse, now says jre should be in eclipse folder [message #130347] Wed, 18 January 2006 12:25 Go to next message
Originally posted by: paulg002.earthlink.net
Eclipse won't even start up since i moved it, i get this error messsage: A
java runtime environment (jre) or JDK must be available in order to run
Eclipse. No Java virtual machine was found after searching the following
locations: C\Program Files\eclipse\jre\bin\javaw.exe 'javaw.exe' in your
current PATH
I HAVE CHANGED THE BUILD JAVA BUILD PATH TO THE REAL LOCATION OF JAVA JRE
AND IT STILL DOESN'T WANNA TRY THERE, SEE ERROR MESSAGE! ( it wants to
look in eclipse folder, why?) I moved it to C\program files\ and now it
thinks the jre should be in its own folder. Thanks all.
Re: moved eclipse, now says jre should be in eclipse folder [message #130398 is a reply to message #130347] Wed, 18 January 2006 14:05 Go to previous messageGo to next message
My coworker got it. go to control panel->system properties->advanced->
system variables, change path this way: insert this before whatevers in
there: \Windows\System32;
Re: moved eclipse, now says jre should be in eclipse folder [message #130549 is a reply to message #130398] Wed, 18 January 2006 18:58 Go to previous message
That is a very bad idea - that way you have no control over what JVM
Eclipse is using (or any other Java programs on your system).
See this page for the recommended way to get Eclipse to use a specific
JVM to run in:
http://eclipsewiki.editme.com/StartupProblems
Eric
Previous Topic:Can't Specify Build Directory
Next Topic:how to build a java project with eclipse
Current Time: Fri Jul 18 17:39:04 EDT 2025
Powered by FUDForum. Page generated in 0.27668 seconds
