Home » Eclipse Projects » Remote Application Platform (RAP) » IE8 & Autosuggest does not work
IE8 & Autosuggest does not work [message #1252751] Fri, 21 February 2014 10:14 Go to next message
hi all,
i'm using RAP 2.2 and and the autosuggest addon (0.2.0). with firefox everything works perfectly, but not in IE8 - i don't get any suggestions.
every time i type a letter into the corresponding text widget the debugger says
Error: Error in scripting event type Modify: Das Objekt unterstützt diese Eigenschaft oder Methode nicht.
which means "the object does not support this property or method"
my javascript knowledge is not the best, but as i understand it the error happens in a function in Autosuggest.js:
function handleTextEvent( model, event ) {
  var userAction = getUserAction( event );
  switch( event.type ) {
    case SWT.Modify:
      syncTextText.apply( model, [ event.widget, event, userAction ] );
    break;
  setUserAction( event );
i'm using autosuggest in a really simple way as shown here including a ColumnTemplate.
am i doing anything wrong, or could this be a bug? is there a workaround? any hints?
thanks in advance, martin
Re: IE8 & Autosuggest does not work [message #1255485 is a reply to message #1252751] Mon, 24 February 2014 08:41 Go to previous messageGo to next message
Hi Martin,
The error is located in function
function onChangeCurrentSuggestions( event )
in line
this.set( "currentSuggestionTexts", currentSuggestions.map( template ) );
The map-function is not supported by IE8.
You can replace it with:
this.set( "currentSuggestionTexts", map( currentSuggestions, template ) );
Then it works.
Did you open a bug for it?
Re: IE8 & Autosuggest does not work [message #1278605 is a reply to message #1255485] Thu, 27 March 2014 11:28 Go to previous message
Many thanks, Stefan!
it took me a while to come back to here (low prio bug). your fix works for me.
i filed a bug
regards, martin
Previous Topic:DirectoryDialog RAP
Next Topic:EclipsVirgo Nano and RAP
Current Time: Sat Jul 26 12:42:52 EDT 2025
Powered by FUDForum. Page generated in 0.03829 seconds
