Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT 4.4 M5 and XULRunner 24
SWT 4.4 M5 and XULRunner 24 [message #1263453] Tue, 04 March 2014 08:47 Go to next message
Hi!
I am testing SWT 4.4 M5 and XULRunner 24 (64b)
My setup: Windows 7 64b, JDK7u51 (64b)
When I try to execute some javascript on the page using:
browser.execute("some javascript");
or even...
browser.evaluate("some javascript");
Than nothing happens...first one returns false and second one returns null...
Everything is working on XULRunner 10 (64b)
Any ideas?
Adam
[Updated on: Tue, 04 March 2014 10:34] by Moderator
Re: SWT 4.4 M5 and XULRunner 24 [message #1264503 is a reply to message #1263453] Wed, 05 March 2014 04:19 Go to previous messageGo to next message
you may want to check the javascript execution as follows:
1. register a BrowserFunction for callback from Javascript
2. enclose your javascript code in a try/catch clause, and in the catch clause call back to your BrowserFunctionn to report the error
we are embedding XULRunner 24 and have encountered cases where the javascript we execute via Browser#execute would randomly throw errors of the kind "permission denied when accessing property XXX". Our solution was to enclose the javascript code in question with
setTimeout(function(){/* code here */}, 10);
thus forcing javascript execution onto the JS UI thread. After that, no more errors. Of course, one could argue that this should really be the job of Browser#execute..
Re: SWT 4.4 M5 and XULRunner 24 [message #1264520 is a reply to message #1264503] Wed, 05 March 2014 04:33 Go to previous messageGo to next message
Ok but why it is working with XULRunner 10?
I simply do not do any "MAGIC" there...
I simply want to call something like this:
browser.evaluate("return $('#ID').val();");
Which is working in XULRunner 10 but not in 24...
SWT version is the same: 4.4 M5
[Updated on: Wed, 05 March 2014 04:35] by Moderator
Re: SWT 4.4 M5 and XULRunner 24 [message #1264598 is a reply to message #1264520] Wed, 05 March 2014 05:48 Go to previous messageGo to next message
we also had code that worked in XULrunner 10, but threw those "permission denied" errors in 24. I dont know why, and I do think this should be adressed by the SWT XULRunner integration sometime. I suggest you first check whether an error occurs in JS execution as I describe, and then report to the SWT Bugzilla. You are on the bleeding edge with 4.4M5 and Xulrunner 24.
Re: SWT 4.4 M5 and XULRunner 24 [message #1264762 is a reply to message #1264598] Wed, 05 March 2014 08:33 Go to previous messageGo to next message
BrowserFunction implementation:
public class ExceptionHandler extends BrowserFunction {
    private static final Logger LOGGER = LoggerFactory.getLogger(ExceptionHandler.class);
    public ExceptionHandler(final Browser browser) {
        super(browser, ExceptionHandler.class.getSimpleName());
    public Object function(Object[] arguments) {
        if (arguments.length > 0) {
            LOGGER.error("JavaScript exception caught={}", arguments[0]);
        return null;
JavaScript:
try {
    return window.document.getElementById("hplogo").title;
} catch(e) {
    ExceptionHandler(e.toString());
Run on: www.google.pl
Expected output is: Google
On XULRunner 10 it is working...when I mees with JavaScript than my handler is logging exception
On XULRunner 24 it is not working...no output and no exception...no nothing
I am invoking browser.evaluate(); function.
[Updated on: Wed, 05 March 2014 08:36] by Moderator
Re: SWT 4.4 M5 and XULRunner 24 [message #1264797 is a reply to message #1264762] Wed, 05 March 2014 09:08 Go to previous messageGo to next message
I have just tested your example. It works flawlessly with me, I get the expected output
Re: SWT 4.4 M5 and XULRunner 24 [message #1264824 is a reply to message #1264797] Wed, 05 March 2014 09:32 Go to previous messageGo to next message
Can you send me the example code and setup?
I have tested on Windows 7/8.1 64b if that any helps....
[Updated on: Wed, 05 March 2014 09:33] by Moderator
Re: SWT 4.4 M5 and XULRunner 24 [message #1264831 is a reply to message #1264824] Wed, 05 March 2014 09:37 Go to previous messageGo to next message
what code are you referring to? I am creating a Browser(parent, SWT.MOZILLA), and call evaluate() on it, thats all. Beyond that, I cannot send code, as I don't own it. You'll have to dig yourself, and/or ask specific questions
Re: SWT 4.4 M5 and XULRunner 24 [message #1264837 is a reply to message #1264831] Wed, 05 March 2014 09:43 Go to previous messageGo to next message
But I do the same Smile
On what OS you are testing?
What JDK?
Are you sure that it is 64b version?
Did you set these:
org.eclipse.swt.browser.XULRunnerPath
org.eclipse.swt.browser.DefaultType
We ca not just say that it is working and it is done Smile
                final Shell shell = new Shell();
                Browser browser = new Browser(shell, SWT.NONE);
                browser.setJavascriptEnabled(true);
Object result = getBrowser().evaluate(instruction);
.... this one I have also tried:
[Updated on: Wed, 05 March 2014 09:44] by Moderator
Re: SWT 4.4 M5 and XULRunner 24 [message #1264849 is a reply to message #1264837] Wed, 05 March 2014 09:52 Go to previous messageGo to next message
Adam Dec wrote on Wed, 05 March 2014 09:43
What JDK?
Windows 7 64bit, 32bit JDK 1.7
no, my app is 32bit
Did you set these:
yes, no
I can! Razz
my code looks like yours
Re: SWT 4.4 M5 and XULRunner 24 [message #1264870 is a reply to message #1264849] Wed, 05 March 2014 10:11 Go to previous messageGo to next message
ok...now go back to my first message Smile
I mentioned 32b or 64b?
On 32b version of XULRunner 24 everything is working well... only pages that are using ext.js are frozen...or not loading... Smile
Please read my posts once more, ok?
simply...please try on JDK 7u51 64b and XULRunner 24 64b
Get it from here: http://wiki.mozilla-x86-64.com/Download
[Updated on: Wed, 05 March 2014 10:19] by Moderator
Re: SWT 4.4 M5 and XULRunner 24 [message #1264875 is a reply to message #1264870] Wed, 05 March 2014 10:20 Go to previous messageGo to next message
you never mentioned that it worked on 32b version of XULRunner 24. I realize I wasted my time. Have fun
Re: SWT 4.4 M5 and XULRunner 24 [message #1264881 is a reply to message #1264875] Wed, 05 March 2014 10:24 Go to previous messageGo to next message
But I have mentioned on which version is NOT working Smile
Yes I have wasted mine also... have fun you too Smile
Re: SWT 4.4 M5 and XULRunner 24 [message #1265475 is a reply to message #1263453] Thu, 06 March 2014 01:23 Go to previous messageGo to next message
There is already bug reported to this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=426710
and mine was a duplication:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=429680
Now I will check it the problem still exists in version:
swt-I20140305-2000-win32-win32-x86_64
Re: SWT 4.4 M5 and XULRunner 24 [message #1265481 is a reply to message #1265475] Thu, 06 March 2014 01:31 Go to previous messageGo to next message
Now it is working fine:
jQuery 1.10.2 - loaded
FireBug lite 1.4 - loaded
JavaScript execution - so far so good Smile
Thanks SWT team !!!
[Updated on: Thu, 06 March 2014 01:31] by Moderator
Re: SWT 4.4 M5 and XULRunner 24 [message #1265540 is a reply to message #1264503] Thu, 06 March 2014 03:23 Go to previous messageGo to next message
Ok now I am having issues like:
Permission denied to access property 'nodeName'
Permission denied to access property 'disabled'
After adding this:
...code...
}, 1);
It is working... but my question is this only a temporary workaround or?
I have reported a bug for it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=429739
[Updated on: Thu, 06 March 2014 03:32] by Moderator
Re: SWT 4.4 M5 and XULRunner 24 [message #1268591 is a reply to message #1265540] Mon, 10 March 2014 14:09 Go to previous messageGo to next message
Still no response from SWT team Sad
Re: SWT 4.4 M5 and XULRunner 24 [message #1336567 is a reply to message #1268591] Tue, 06 May 2014 09:02 Go to previous message
It is now working for SWT 4.4 M7 (64b)
Previous Topic:Unity menu integration in 4.4M7
Next Topic:SWT dependency on Linux libaries
Current Time: Sat Jul 26 11:36:59 EDT 2025
Powered by FUDForum. Page generated in 0.26387 seconds
