Home » Language IDEs » Java Development Tools (JDT) » Huh? "A class file was not written. The project may be inconsistent, if so try refreshing this
Huh? "A class file was not written. The project may be inconsistent, if so try refreshing this [message #125556] |
Tue, 09 December 2003 11:30  |
Originally posted by: natgross.rentalsystems.verizon.net
I added an inner class to a source, and now get this error Task.
A complete rebuild does not help.
I should note that the coding was done while in the midst a debugger session, I
had forgotten that the debugger was active.
After saving I also received some error about the debugger, terminated the debug
session, rebuilt All, but am still left with this.
Any advice will be appreciated.
-nat
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #125685 is a reply to message #125556] |
Tue, 09 December 2003 14:49   |
Can you narrow it down to a simple, stand-alone example and post?
I also suggest checking Bugzilla to see if it is an open/known issue.
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #125723 is a reply to message #125685] |
Tue, 09 December 2003 19:47   |
> HTH,
> Eric
> Eric Rizzo
> Software Architect
> Jibe, Inc.
Its kinda hard to narrow down, although the inner class is rather simple, but
implements Comparator.
Due to time constraints on this, I factored it out into a regular class, and
everything is fine. (But of course does not solve the problem.)
As far as Bugzilla goes, I tried before posting here, and what a PITA to use that
interface! Are they for real?
I have to set who-knows how many parameters (including version numbers of
modules!!) to get a query?
I still feel I must have overlooked the obvious query sheet. Can't one just input
Eclipse/JDT/inner class and SEARCH?
Anyhow....
thanks
-nat
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #125899 is a reply to message #125723] |
Wed, 10 December 2003 09:43   |
Originally posted by: wegener.cboenospam.com
Check out but 23373
https://bugs.eclipse.org/bugs/show_bug.cgi?id=23373
It talks about a file name path length issue on Windows.
Text searches of open bugs can be performed quite simply off of the Bugs
page on the Eclipse site. If you want to search all bug reports, you can
click the Edit Query and add the Resolved, Verified, and Closed entries to
the Status.
> > HTH,
> > Eric
> > Eric Rizzo
> > Software Architect
> > Jibe, Inc.
that
input
> Anyhow....
> thanks
> -nat
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #125964 is a reply to message #125899] |
Wed, 10 December 2003 14:29   |
Thanks for the pointer on the bug. If the bug status wouldn't have been "resolved
WONTFIX", I would tell them that it happens with very short path names as well,
and the path length is NOT the cause [in my case]. It is nested classes, even one
level deep.
Ta
-nat
"Dave Wegener" <wegener@cboenospam.com> wrote in message
news:br7bfd$71t$1@eclipse.org...
> Check out but 23373
> the Status.
> > > HTH,
> > > Eric
> > > Eric Rizzo
> > > Software Architect
> > > Jibe, Inc.
> that
> input
> > Anyhow....
> > thanks
> > -nat
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #126875 is a reply to message #125964] |
Fri, 12 December 2003 13:09   |
What is is the path to your file ?
Do you use any plugins? Do you have anything special in the log file?
Genady
> level deep.
> Ta
> -nat
>>Check out but 23373
>>the Status.
>>>>HTH,
>>>>Eric
>>>>Eric Rizzo
>>>>Software Architect
>>>>Jibe, Inc.
>>that
>>input
>>>Anyhow....
>>>thanks
>>>-nat
Genady Beryozkin
http://www.genady.net/
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #127696 is a reply to message #126875] |
Mon, 15 December 2003 14:35   |
The name of the file is EzModelBase.java and it resides in:
F:\Data\MyJavaProj\1.4.2\libs\ez\swing\tables
The workspace location is: F:Data\MyJavProj\Eclipse\Main.
When I created the project, I simply pointed the wizard to
F:\data\MyJavaProj1.4.2\libs and it eloquently read and rebuilt all the packages
whose outermost level is "ez".
I must admit that I didn't realize that the source was 7 levels deep, since my
Eclipse Title Bar (I set the startup parameters to display) says:
F:Data\MyJavaProj\Eclipse\Main which is only 4 levels deep.
So. maybe it is related after all to the aforementioned bug.
Plugins? I tried two, but deleted both. (Still hesitant on installing a new
database plugin.)
Logfile: I recall reading a quick way of getting the log but it is eluding me now.
Thank you much.
-nat
"Genady" <eclipse@genady.org> wrote in message news:brd04a$4d2$1@eclipse.org...
> Genady
"resolved
well,
one
> > level deep.
> > Ta
> > -nat
> >>Check out but 23373
> >>the Status.
> >>>>HTH,
> >>>>Eric
> >>>>Eric Rizzo
> >>>>Software Architect
> >>>>Jibe, Inc.
> >>that
> >>input
> >>>Anyhow....
> >>>thanks
> >>>-nat
> Genady Beryozkin
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #127761 is a reply to message #127696] |
Mon, 15 December 2003 21:57   |
Genady, Darin, and others.
We got him!<g>. The logfile reports the REASON for that message: "Resource exists
with different case". And I understand it, and possibly stumbled on a different
Eclipse bug.
I remember that when I coded that inner class, I mistakenly named it with a name
beginning with a lowercase letter. Later, I simply uppercased it. And the fun
started. Evidently Eclipse did not delete the old class file (Outer$inner.class).
So, it complained when it had to create a class with the same name but different
case (since the os does not differentiate them). A refresh/rebuild should
definetly catch that.
To be honest, although I now found that old lowercase useless .class file, and
deleted it, I have not re-tested. I am confident that this is the reason.
thanks, (oops...Thanks gg)
-nat
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #127926 is a reply to message #127761] |
Tue, 16 December 2003 15:45   |
Tell us whether it's the problem.
I believe opening a bug would be appropriate to request such situation.
Genady
> Eclipse bug.
> -nat
Genady Beryozkin
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #128002 is a reply to message #127926] |
Tue, 16 December 2003 19:51   |
Yes! Reproducible (simply) and happens ALWAYS.
Anyone can try it.
1. Create a class.
2. Inside the class create another (inner) class with a mixed-case name.
3. Save/Compile.
4. Change the CASE of the inner class name. And SAVE.
* voila, you get the error AND the inner class is indeed NOT compiled. *
5. From the os, externally, locate the inner class .class file (which should have
been deleted via refresh), and DELETE it.
6. You can now save, and the previous error/Todo will be cleaned up. And the new
inner class file will be written.
-nat
"Genady" <eclipse@genady.org> wrote in message news:brnqtg$eq5$1@eclipse.org...
> Genady
exists
different
> > Eclipse bug.
name
different
> > -nat
> Genady Beryozkin
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #128041 is a reply to message #128002] |
Wed, 17 December 2003 05:19   |
Which build are you using? Which platform? In I200312162000 and on Windows
2000 I tried your steps and I could not reprodice the problem.
Jerome
"natG" <natgross.rentalsystems@verizon.net> wrote in message
news:bro99a$tg5$1@eclipse.org...
> Anyone can try it.
> 1. Create a class.
> 3. Save/Compile.
should have
the new
> -nat
> > Genady
"Resource
> exists
> different
> > > Eclipse bug.
with a
> name
the fun
> different
should
file, and
reason.
> > > -nat
> > Genady Beryozkin
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #128181 is a reply to message #128041] |
Wed, 17 December 2003 10:43   |
Version: 2.1.2
Build id: 2003110308002
Windows xpPro
-nat
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:brpajf$su3$1@eclipse.org...
> Jerome
> > Anyone can try it.
> > 1. Create a class.
> > 3. Save/Compile.
> should have
> the new
> > -nat
> > > Genady
> "Resource
> > exists
> > different
> > > > Eclipse bug.
> with a
> > name
> the fun
> > different
> should
> file, and
> reason.
> > > > -nat
> > > Genady Beryozkin
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #128246 is a reply to message #128181] |
Wed, 17 December 2003 12:28   |
So I guess this is fixed in the 3.0 stream...
Jerome
news:brptht$kt6$1@eclipse.org...
> Version: 2.1.2
> Windows xpPro
> -nat
Windows
> > Jerome
> > > Anyone can try it.
> > > 1. Create a class.
name.
> > > 3. Save/Compile.
> > should have
And
> > the new
> > > -nat
situation.
> > > > Genady
> > "Resource
> > > exists
on a
> > > different
> > > > > Eclipse bug.
it
> > with a
> > > name
And
> > the fun
but
> > > different
> > should
..class
> > file, and
> > reason.
> > > > > -nat
> > > > Genady Beryozkin
Re: Huh? "A class file was not written. The project may be inconsistent, if so try refreshing t [message #775364 is a reply to message #125556] |
Thu, 05 January 2012 16:08  |
In case anybody else in the world encounters this error from Eclipse, I just ran into a very similar issue as this thread.
In my case, I had many levels of nested classes with LONG class names. The resulting .class file exceeded the 255 character file limit on NTFS! It caused Eclipse to silently give me the "A class file was not written..." error.
I was able to find the root cause by checking the log under <workspace>/.metadata/.log. It had a java.io.FileNotFoundException with a message "The filename, directory name, or volume label syntax is incorrect". Another clue was that other inner classes (with shorter file names) did compile.
Cya,
Jason
Current Time: Fri Sep 05 18:39:36 EDT 2025
Powered by FUDForum. Page generated in 0.09380 seconds
