Home » Modeling » GMF (Graphical Modeling Framework) » Change lable name on creation
Change lable name on creation [message #124907] Wed, 09 May 2007 05:15 Go to next message
Originally posted by: DolphinS.Rambler.ru
Hi everybody,
I need to generate label names automaticaly on element creation. For
example every element have to have a sequence code such as "sc0", "sc1",
etc and this name have to be saved in xml file wich describes EMF model.
How can I do it?
Re: Change lable name on creation [message #124929 is a reply to message #124907] Wed, 09 May 2007 05:28 Go to previous messageGo to next message
I have a problem with a label wich consist of 2 features. I define an
edit pattern as >{0}<, and vew pattern as >{0} cl: {1}<. So I expect to
have somting like this in my diagram:
Feature1 cl: Feature2
but instead I have 2 time Feature2:
Feature2
And if I try to change the name of Feature2 on cration programmatically
I have:
Feature2_changed
I change the label text in elementEditPart by metod createContents().
Re: Change lable name on creation [message #125092 is a reply to message #124929] Thu, 10 May 2007 04:41 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Are you sure that this is a single label? Maybe there is one more label
below for Feature2? Could you please attach a screenshot?
> Feature2
> I have:
> Feature2_changed
Re: Change lable name on creation [message #125100 is a reply to message #124907] Thu, 10 May 2007 04:43 Go to previous messageGo to next message
Find command that creates the element that has the label; modify the
command to setup label attribute appropriately.
Dmitry wrote:
> Hi everybody,
> How can I do it?
Re: Change lable name on creation [message #125256 is a reply to message #125092] Thu, 10 May 2007 05:57 Go to previous messageGo to next message
--------------010902020401020203010406
Hi dmitry,
I'm sure that there is a only one label, I was quite surprise then I've
seen this. Here is the screen shot you've ask about. The label below is
that one which I can change programmaticaly, but it doesent saves in xml
file. The label above I can change from propeties view and in this case
it saves in xml.
here is the parts of xml code which describes EMF model of this elements:
<functions Name="Feture1">
<functions Name="Faeture 1" clockName="Faeture 2">
So, I wonder!
Content-Type: image/jpeg;
name="LocBild.jpg"
Content-Disposition: inline;
filename="LocBild.jpg"
/9j/4AAQSkZJRgABAQEBLAEsAAD/2wBDAAMCAgMCAgMDAwMEAwMEBQgFBQQE BQoHBwYIDAoM
DAsKCwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYUGBIUFRT/2wBDAQMEBAUE BQkFBQkUDQsN
FBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQU FBQUFBT/wAAR
CAFpA4oDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD9U6KKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigApCwX
qQPrS18q/t/z3T6H8GtKh1C/sLPWfiRpOmX40+8ltZJ7aVZlkiLxsrAEehHQ HqBQJ6H1R5if
3l/OjzE/vL+deF/8MffDf/nn4n/8K/Vv/kmj/hj74b/88/E//hX6t/8AJNXy Mw9vE908xP7y
/nR5if3l/OvC/wDhj74b/wDPPxP/AOFfq3/yTR/wx98N/wDnn4n/APCv1b/5 Jo5GHt4nunmJ
/eX86PMT+8v514X/AMMffDf/AJ5+J/8Awr9W/wDkmj/hj74b/wDPPxP/AOFf q3/yTRyMPbxP
dPMT+8v50eYn95fzrwv/AIY++G//ADz8T/8AhX6t/wDJNH/DH3w3/wCefif/ AMK/Vv8A5Jo5
GHt4nunmJ/eX86PMT+8v514X/wAMffDf/nn4n/8ACv1b/wCSaP8Ahj74b/8A PPxP/wCFfq3/
AMk0cjD28T3TzE/vL+dHmJ/eX868L/4Y++G//PPxP/4V+rf/ACTR/wAMffDf /nn4n/8ACv1b
/wCSaORh7eJ7p5if3l/OjzE/vL+deF/8MffDf/nn4n/8K/Vv/kmj/hj74b/8 8/E//hX6t/8A
JNHIw9vE908xP7y/nR5if3l/OvC/+GPvhv8A88/E/wD4V+rf/JNH/DH3w3/5 5+J//Cv1b/5J
o5GHt4nunmJ/eX86PMT+8v514Wf2PvhuP4PE/wD4V+rf/JNcXefAv4T23iq2 01f+EilsGXbP
qC+M9VMUMrfcRm+04BPH/faZILIHynJU7OTKjVUtkfVHmJ/eX86PMT+8v514 Ddfsm/DSHTJb
2JPEs0aRGVSvjHVsOAMjB+0968i+Hnwt8L694LtPG3izw9c+GvCN3pseoRT2 XxL1y/vP3gUx
xmDbHlm3YwjMS2FUMTWvLv5f8H/Jh7VNXSPtvzE/vL+dHmJ/eX86+KPFPhv4 K+Hx4Pnt9L+I
Oo2mv6nLpsix6v4j+12TJBJKd9qGMwY7FwjKpKvvGVUmuytvg38DLu20y4i1 DxQYtSv7nTLU
nxRrQMlzbiUzR4M/G3yJeTgHZwTkZbg0rsPaLTR6/wDB/wAn9x9S+Yn95fzo 8xP7y/nXx1b+
E/2erzQbPWbS68d31jesBaGz1PxJNJcrsDmSKNHLvGoIDSKCqMdrENxWh4l+ DPw10Txh4D0e
00Lxfqmm+K53hi1yHxvqItYcW8s68fay7swi4wu3BJ3ZAUig27f13D2q7dG/ kt/uPrXzE/vL
+dHmJ/eX868L/wCGPvhv/wA8/E//AIV+rf8AyTXLeOfgV8Gfh0tiNYPjN7i+ kaO2s9N1/Xb+
5lKjLFYYJnkKqOrbcDIyRkZlxtuJVk9kz6d8xP7y/nR5if3l/Ovjnw18J/hf Nq/i2LXv+Ejs
bLT/ABFbaFpzJ4n1rzJWntraSMSD7SSGMk5GcKAAM4wTWb8T/ht8NPDeqx6N o8Xilrh5mtpL
5Nf1/USkqqHZIrW2naWYqpBZhtRNwBfd8tTU/dJOXW1vmk7etmjsw1KWJm4Q 0SV23oku7/S1
23ok2fbHmJ/eX86PMT+8v518GaF8JNC8K+NrmOS58U694Xs9Us9G1LUb/wAW 3kMtveXKxtGs
VqVy0YM8AJeYMNzYVtvP0ddfsu+CLmBo1bXoSwxvj1683D6ZlrJe2a5lCy83 r0fZ9GmdkoZf
TfJPENv+7Btfe3F/gey+Yn95fzo8xP7y/nXylqf7D2n2F5Jf6V4n8Satk7m0 3WfEeoRxMP7q
SQTIY8/3mWTHpWx4O/Zt+Gnii3uYp7HxXpur2LiG+0+bxjqrPA5AIwwuiGVg QQw4I9CCA4yb
fLJWf9f13Mq1CMKbrUZqpFb2vdeqaTt0urq9le7PpXzE/vL+dHmJ/eX868L/ AOGPvhv/AM8/
E/8A4V+rf/JNH/DH3w3/AOefif8A8K/Vv/kmt+Rnl+3ie6eYn95fzo8xP7y/ nXhf/DH3w3/5
5+J//Cv1b/5Jo/4Y++G//PPxP/4V+rf/ACTRyMPbxPdPMT+8v50eYn95fzrw v/hj74b/APPP
xP8A+Ffq3/yTR/wx98N/+efif/wr9W/+SaORh7eJ7p5if3l/OjzE/vL+deF/ 8MffDf8A55+J
/wDwr9W/+SaP+GPvhv8A88/E/wD4V+rf/JNHIw9vE908xP7y/nR5if3l/OvC /wDhj74b/wDP
PxP/AOFfq3/yTR/wx98N/wDnn4n/APCv1b/5Jo5GHt4nunmJ/eX86PMT+8v5 14X/AMMffDf/
AJ5+J/8Awr9W/wDkmj/hj74b/wDPPxP/AOFfq3/yTRyMPbxPdPMT+8v50eYn 95fzrwv/AIY+
+G//ADz8T/8AhX6t/wDJNR3P7IHw4jtpWVPE4ZUJH/FX6t6f9fNHIw9vE95B BGQcilr5p/4J
xa7qXiT9jvwLqGr6hdapfyvfiS7vZmllcLfTqu5mJJwAAPYCvpaoOgKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACikBz05oLBQSSAB3NAC18p/t9fd+AH/ZVtD/9rV9S/bbf/nvF/wB9ivlf 9va4ilHwACSo
5/4WtofCsD/z2prcT2Z9SUUUVueWFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFADZY0mja
ORQ6MCrKwyCD1Brzi9+EVtJ4khECBPDkiM11ZlySznOVB6hXJBZQcNhum5xJ 6TRWNSjCrbmX
9dvQuM5Q2M+bSY4tDm060RYYzC0Ua9hkEc/n1r54H7Gug2vwI03w7p2iaFo/ jq2s7H7RrWlR
mze8uLeSKZle6iVJwkkkQy4+cZDAbgBX0vRWqSirR02/C9vzBTkj500/4E+J /D+keHtV0fTN
Li8Taf4ibW7nT9Q8S39/FcBrN7Qhr+eJ5SwRlYfugo2hcfxmPTvgb47g8QaF ZyHQU8M6N4h1
TW47pbuZry4W8ju8IYvKCRmN7oDO9t4GfkI2n6PrmfFXxE0bwjcRWlzLNdan Mu6LTbGFp7mR
em4RqCQueCxwozyRSqVEovnem34JfpodNCFfEyVKjFyl2Su/tfpJ/wBI8K13 9mXxA3hT4Wi1
ki1DWvCuiHRLyzg8R3+iwzo6Q75EubVTIcPAuEZNrBiTtKiur8S/C/xbptz8 JLPwnpWgyaL4
OmWWdb3VbiB9otZbby4l8mYsAsu4M75O3B67h1y+NvG+p/NpvgH7LH2Ot6rH bsfwiWakHin4
iR5aTwbos6L95LPX2eT8A1so/UVm8Wm3LXV3+F+fl3bPQeWYnZyhs1/Fp9dP 5+2h6GOnPWvM
/iN4R8UHx34d8ZeEbbStU1HT7S602407Wb2SzieCZonLpKkMpV1aFeNmGDHk ECrtr8X7SzuI
7fxNo+peEZZGCpLqSK1sxPA/fxs0a5PADlSewrvlYOoZSCDyCKcKkajvB6r7 +23ocGIwlfB2
VaFlLZ7p+jWjt5M8s8O+CPF/hfVvFupWR0Yza/4ittReO4eR1jtBbW0M6ghR +9/cybP4eVJx
yB55d6Nr/gX4oafc6XFpEuuxXGqpb2mvXsllbaja3twtzuhuEhlxNG6BDHty VBbgbSfpeqGu
aBpviXT5bDVrC31GylGHguYxIjd+QaKkZNxnB2cdvSyjb7l+ZthcVCEalHEJ uE7Xtumr2kuj
td6aJ907NeJ6n8GPE1/4x1FIYtGPhXXdesPE2oXTXkn2u2uLZYP3MUQi2yKz WsX7xpEIDt8r
YAPvdee/8KZs7BidE8ReItAHaO11AzRqPRUnEiqPYACnH4X6w42y/EjxTInd cWSZ/FbYH8jU
KrVUVFw+5rsl1t0SXyN5YXB1HzRxSS/vRkn90VJXf+I7TVdYsdDsprzUbyCx tIVLyTXEgREU
dSSeAK4vwAJPEHjHxH4vihkg0rUba0srIzIY3nSEzMZtrAEKxnKjIBITd0YG rGlfBvw3YX0N
9dxXWu30LB4rjWbuS7MTj+JFclYz7oBXbqoUAAAAdAKSjOclKelum/l/X5hO thcNRqUsK3Nz
Vm2lFJXUrJXbvdLVtaXXL1FooorpPFCiiigAooooAKKKKACiiigAooooAKhv f+POf/rm38qm
qG9/485/+ubfyoA+bP8AgmR/yZT4B/66aj/6cLivqSvlv/gmR/yZT4B/66aj /wCnC4r6krnP
VCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK+M/2o/iH8cPBv7V /wAKdO8JeItK
0b4Z6xJZQahaX95pkMt7L9rIuUhW4InkbyXhGIQTll2/Ma+zK/PH/gp1a3Oo fH79liyspo7a
7u/EE9vFPIrsImeexUP8jo/BOco6NxwynBFwSlJKTsiZNpNo9Jk+J/7WgkYL 8P8ATiuTj/iU
2nT/AMHlN/4Wh+1r/wBE/wBO/wDBTaf/AC8r1r4Z/CzVbXxRH4j1ifWtHWzj a3t9CfxLeajD
NIRtkuJTJJtdeoiTaMKfMkAkZY7f2Kt6lKEJWi7/ANfM4Y16jXvJHyH/AMLQ /a1/6J/p3/gp
tP8A5eUf8LQ/a1/6J/p3/gptP/l5X15RWXIi/byPkP8A4Wh+1r/0T/Tv/BTa f/Lyj/haH7Wv
/RP9O/8ABTaf/LyvryijkQe3kfIf/C0P2tf+if6d/wCCm0/+XlH/AAtD9rX/ AKJ/p3/gptP/
AJeV9eUUciD28j5D/wCFofta/wDRP9O/8FNp/wDLymS/FX9rKGNpJPAOmoij LM2lWYAHqf8A
ieV9f15t8Xb3WI7F4DDHD4ccL9pvEfEinOQCcgopOAXH3R3XJePGs1Sg5f18 /IuFWU5W0PCx
8Uf2tSP+Sf6d/wCCm0/+XlMf4r/tYRth/AemKfRtLsx/7nK+jPhjea5c6NGu pWypYRxqtlcO
Nk00f8LOnY4x2XsdqklU8N+IPgSTxv8AtO+JNvw68G+PltfDulk/8JbcmL7J unvOYf8ARZ87
sc/d+6vXtVK1VJrS5TnJc17af5pd/MyB8Uf2tSMj4f6cR/2CbT/5eUH4o/ta AZPw/wBOA99J
tP8A5eVrR/GbXNP+NGg22jXviPV/Curalf6SYdRh02PTllt7eZ2jtBGEu90c tuY8yqUI3cn5
CeBv/iL8QviX8BvG95rCa9ZaZrfg++1My30mlCK1mQIfIso4GacxbXkVzcAu u1OVYmtFC+3a
/wCf46f1dFRc3NQdldpfe7fg/RnUD4o/takf8k/07/wU2n/y8pf+Fofta/8A RP8ATv8AwU2n
/wAvK2fEvxJ8TfDPw78S7RvGdxqR0HwVZ6rpmpapFaCX7TK94N58uJEbmOFA NuPlHBJJNXxh
8VPHmj6d8Sdftdbv7uDSdbsNDsdKsrazUQJcw2PmXG+VQGdDPIyb3WME/vNy 421KnZtLX/h0
vzZEZ1Gk3bX/ACT/ACkUP+Fofta/9E/07/wU2n/y8pYvij+1m0ig+ANO25G7 /iU2nH/lcr27
4D654n1fw9q0HimDUorixvjBbTa3LYvfzQmKOQNOLJjCjBndQFwSioSMnJxP 2fNOt9G8W/F+
ytrm6uIk8Uqym8vJbqQbtPs2I3yMzYBPAzgDAGAAKPZrmav0v+MV+v4E+1ly t9jxPw7q/wC2
JpHxa+KV5qNhFqnguMXP/CJWksWmyq5N9EIcqk8EhxamY/vJV6c7mwpu6n8Z /wBqfRYEn1Dw
Vo9lC8scCyXGm2SK0jsERATrn3mYhQOpJAHJr7A1C4e0sbieOMzSRxs6xr1Y gZA/GvlrVLzW
vFHwR8LeLtZ8W3euTa9r3h+8OlGG3jtdNZtSgYww7IllO3Ow+a7n5OxzShBS mo+cV97t/n+p
Sqyepnf8LR/a1Az/AMK/07H/AGCbT/5eVUuvjR+1NZKWuPBejwqO8mnWQ/8A c5XqPxY+Iuqe
CPDGqpZ+I7XX73VteOk23lxRj+x91sX8lwpO5l2Fst82JRxgCvnD4R/AnRPC /wAGtP8AF/iP
wlp2kQatploLPV/D1+t3qVzPO0SwRfZbi0FurSM6gtI7qGOWOMuOOU5Sm4Uo 3aS/8mvZeb06
b9PP38NgaawsMZjanJCbaikuaT5XZvdJJPu7+Rdn/bH+PNtqP2GTQtHNznGy LRYJTn/gGtHN
dHb/ALQn7TF9ErWng61kZhlQ/hORQfx/tQio9D+LXi7Q/Bknhqw0vW4L2Pxl /wAI59qt4dGT
V4IPsQu1BwwsPMLHywem0/d8zFdLpzeL/E3xV+HWp6vrmseGtVtvD+uI9sh0 +Z7oQXtsqrOY
0kjDyoEMqwsNrLhCnIL9jWesppLfRdOXn6vXTT9CvreXU9IYZyf96fm1tGKt ez6v1ME/GD9s
a45tPh54ekHbz9MEP89TpP8AhaX7bP8A0TTwl/36j/8AlnWvrf7QHi6H4beH L608QxDWbn4Z
X/iK6YQQs326NbXy5ym3AAaSX5QAp5BBwMW/HXxD+Jvhrxm/h7SrvxF4gn0r RIddF1bjR7a3
vZZZJcxXRuDGUtk8pVzB+8Adi7k7SbeDqKSi6r1bX2baNp9P7rCWZ0Iq6wVP 5ur5f9PEvtI5
t/it+2tEMv8ADfwgg9WjjH/uTpy/F39suMbrj4d+GVX1gsVl/lqdfRHxu/4Q iXwZZTePNBtv
EsInU2Ghz2y3b3l4yMEjihb5ZHwXwTwoDMSqqzC78CPCN74H+F+kaRqHlRXE RllFnby+ZFZJ
JKzpao3GUiVljU4AwgwAOKhYabv+9en+H/5H+tO6Mv7Yw/Km8DT186qf/px/ 18z5rb48/tQ2
qE3ngmziI6+T4VklH5jU65m+/bG+PGnXotJ9A0uGcnAWfQIoT/4/rAr75qvd afa30TRXFvFP
G33kkQEGl7Gstp39V/lYX9o5bU/iYVx/wzf/ALcpHx3pfxw/ai1qJZLDwbo1 2rDI8rTbJuP/
AAeVof8AC0P2tf8Aon+nf+Cm0/8Al5XumsfALwpdTvd6VayeHNQ+8txo8rWu W9WCEA/jXn3h
D416/wCGPjXpfwp8ROut3l4JZE1VFCbEWJ5FBA6nCYz71nKs6Moxrq3M7JrV XZ2UssjmVOrV
yqfM6cXOUZLlkoxV2002mkt9U+yZxn/C0P2tf+if6d/4KbT/AOXlH/C0P2tf +if6d/4KbT/5
eV9eUV38iPlPbyPkP/haH7Wv/RP9O/8ABTaf/Lyj/haH7Wv/AET/AE7/AMFN p/8ALyvryijk
Qe3kfLHhT4kftQXfifSYNd8D2Fnokl1El9cLplqhigLASMGXWJCMLk5CORj7 rdDl/wDBO74g
fG34jWfjrUfiz4i0vxLpkNxbW+j3Wk3mmXUSSASG4QtYkgMA1ucPzhhjqa+t b3/jzn/65t/K
vhf/AIIy/wDJtfi3/sb7r/0mtaiSsbUpud7n3zRRRUm4UUUUAFIRkEHvS0UA eYNPcfBa7P2i
SS4+H8z5Ezks2hsT0Y97Unof+WPf91/qof2n9Qh/4Zr+KbxXKBv+EX1IqySD P/HrJ0q3r6a3
8UNSvNBt47zw/wCE4HMGoai6tBdagejQ22cNHH2afgkcR9RIvnfx3/ZZ+GsX wK8ep4b+Ffhs
68nh+9Gnf2focBuvtAgfyvKKpuMm7btxznGOaAPJ7f4FfDhreInwF4bJKg/8 gqD0/wB2vLvj
Z8OPCngvxl8DrzQPDWk6Jdy/EfRoJJ9Pso4HeMyMxQlQCVyqnHTKg9q9gg+I UKQRqfDHjYEK
Af8AijdV9P8Ar2ryf47eKo9d8X/AyBNH8RaeU+JOjP5ur6Be2ER+dxgSTxIp bn7oOcAnGAcN
biezP0kooorc8sKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAZMxWJyvUKS
K8/+B1rBdeA9O1+ZFl1zWIVu9TumAMrTkfNGx6gRklAp+6FA7V6HXCap4C1X SdSudT8H6sml
S3LmS40y8iM1jM5OWcKCGidj1ZDgkksrHmuaompxqJXtfT1tr/Xc9nBVKcsP Vws58jm4tN3t
7t/ddruzuns1dK/dcnp2r+IvF/xH8cuPFN5pFn4YuFsrbw5aQ23l3oa1SUTz NJE0vzNKQvlu
oxEOp3V59+zZptppXiT4dXum2drbX/iLwXNqPiS4twBLe3oltSstxjl5N0tw NzAkbmHHIr0S
90zUH8VWniTXvg9pWteJbNPLtta0qe1nuYV54SW4ETqPmbgH+I+tS+H2k8L6 jql94c+Ckuh6
nqsnm315G2nWxupMk7pnilZnOWY5IJ+Y+pp08RCGrT2/ll2a7db3a2ukl5aT yuu4uKlCzt/y
8p2/9K6dOvc9ZvLODULaW3uoY7i3lUpJFKoZWU8EEHqK4b4Ru1uvinSYXMmk 6TrD2mnZOQkP
kxSGNT/dSSSRAB90IF/hqE6X4/8AF4MWqXlj4R05+JItIka5u3HtM6qsfocI x9GB5rtdB0Gx
8NaVBp2nQCC1hBwuSxYk5ZmY8sxJJLEkkkkkk1KvUmppWS79f68xz5MFhamH lUU5TtpF3UbO
977N20XLdWbu+hoUUUV1HghRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFQ3v/Hn
P/1zb+VTVDe/8ec//XNv5UAfNn/BMj/kynwD/wBdNR/9OFxX1JX52/sI/Gjx 14S/Zc8H6Vof
gzQdX0yB73yry+8QTWk0hN5Mzbols5AuGJA+c5AB4zge1eKP2rviJ4P8N6rr uofDfw49hplr
JeXC2/iqdpDHGpZgoNgAWwDgEgZ7iuc9U+qKKh+0f6H5+P8Alnvx+Ga+XvC3 7V/xC8XeHNK1
6y+G/h5dO1K2ivIVl8UzCYROoZQyixIDYI43Yz370AfU9Fcx8PfiFpXxI0Bd S01njdHMN1ZX
ACz2kwALRSKCcMMg8EgghlJVgT09ABRRRQAUUUUAFFFFABRRRQAUUUhyAccm gBaK5nwd43h8
USXtjcWz6VrunsEvdMmbLx5zskRv44nAJVx1wQQrKyq34o+Nh8Nfhr4q8Wta G/GhaXc6kbQS
bDN5MTSbN2DtztxnBxnpQB1Ffn9/wUd/5Od/ZD/7Gtv/AEqsK9rT9o74nyIr D4c+FsMMj/ir
Lj/5X18mftcfEXxN4/8A2nP2Wv8AhJfDul+Hza+Kk+z/ANmarJf+cWu7Ldv3 28OzG0Yxuzk9
MctbiezP0+ooorc8sKKKKACiiigAooooAKgvbKDUbWS3uYlmhkGGRuhqeik0 mrMNhkUSQRJF
GixxoAqoowAB0AFV4tIsYNTuNSjs4E1C4jSGa7WMCWSNCxRGbqQpdyAeBubH U1bopgcta/Cr
wXY+J5fElt4T0WDxDLL50mqx2ES3TybSu8yhdxbazDOc4Yjual0z4aeEtFu9 autP8MaRY3Ot
EnU5rexjje+JznziFzJnc33s/ePrXSUUrK1um3yHd9zh2+Bfw4e00+1bwH4b a206OWKzhOlQ
FLZJM+asa7cIH3HcBgHJznNdFJ4S0SWz1S0fSLF7XVc/b4Wt0KXeUEZ80Yw+ UVU+bPygDoK1
qKb1TTC73Mnwx4T0TwVo0WkeH9IsdD0qEsY7LTrdIIULElsIoAGSSTx1NZ3h b4X+DvA2pX2o
+HfC2jaDf3/N3dabYRW8lxyT+8ZFBbkk89zU/jTxYPCmnW7xW5vdRvZ1s7Gz DbfOmYEgFsHa
oCszHBwqsQCRg8N4n8NCx8P3fiH4keLr1bG2j82az0mWS0tYuwRBEfOmYkhQ pY7yQFQE7awn
VtL3Vd/db1Z6eHwUZ01VxE+SDeml5St/LHTbu2l2baaPVTPEODIn0LCuU074 U+BdOv7+9sfC
eg215qFwl3eXEFhCslzMknmJJIwXLOr/ADhjkhuRzXj/AIpHw30Pwv4f12x+ Fcmu2mrava6U
9xq2l/Y5bQzXCQ+bMl2qzEZfjajbiB0U7h6fJ8CPBa86fpTaFJ2k0W4ksm/8 hMuaSdde/wAq
7bvyfbzRv7LLbW9tPX/p3H/5YP8AiD8HtG8b6HLaQQwaTeG9Gppd28C5N0EM YlcDG9tpxknO
AOeK4ZoPEPhDwnH4Q8SeAbLxl4TjgFrt02ON0khXgK1oyhAoAGFzjiusu7jX /hRH9uv9Wk8R
+E4yPtMt4qi9sVJA8zcoCyxr1bcAwALbnPFekqwZQRyCM1h7NVZNq8ZaX226 aaprt9x3/Wp4
KhCjVUa9BtuO6s9OazXLKL1TaemqdndM8J03xV8Ex4euPCdz4c0rQ9LvGVrn QL3RljgkZQoX
zIwhjJARAM5xsX0Fdqum/C7WrHQoDZ+GLq10Rkk0mF4YCtgy42NApH7ojAwV xjArub3TLPUY
Wiu7WG5ibqksYYH8DXJXfwT8BXsjSSeEdHErcmRLREb8wAa0/wBpj1T+9bbd zm58nq7xqU/R
xmvxUGvvYzSvhh8OLZr99O8LeGojqKzLeNbWMA+0iXb5okwvzh9i7s53bRnO BWx4g8AeFvFt
5pV3rfh7StYutKk83T5760jme0fIO6JmBKHKqcrj7o9K51/gF4Jb/V6ddW3/ AF66lcw4/wC+
JBTP+FAeER0Our9PEN+P/a1NSxCt7q083/8AImbpZU9q9T/wXH/5adL4y+H/ AIV+IlhBZeKv
D2leI7OCTzorfVbOO5jjfBG5VcEA4JGR6mn+G/Dnhn4e6Qul6DpumeHdLRmc WdhDHbQqx5JC
KAMnua5f/hQPhLu2un6+ItQ/+PU5PgD4MB+ezv7j2uNWu5R/49KaOautor73 /wDIi9llXWvU
f/cOP/y06y48Y6DaA+drNhFjqGuUH9a5TVfj94G0mcwNrS3Nz/DDaxPIzfQg Y/WrMPwM8AQs
GPhLS53HR7m3WVvzbJrqtL8PaXocIh07TrWxiH8FvCqD9BS/2mX8q+9/5Gl8 mp62qT/8Bh/8
mebyfE/xd4qYweF/BN3bxSDAv9bkFsgH95VAcn9Kj8E/AK20vxha+NPEd82t +MIC/l3qp5ax
qyFSm3JzgMRmvXAMUUvqylJSqvma27L5FvOp0aU6GApqjGaalZtykno05Nt2 fVKyfVMKKKK7
D5wKKKKAIb3/AI85/wDrm38q+F/+CMv/ACbX4t/7G+6/9JrWvui9/wCPOf8A 65t/Kvhf/gjL
/wAm1+Lf+xvuv/Sa1rOZ1UOp980UUVmdYUUUUAFFFFADXdY0Z2IVVGST0AqD TdStNZ0+2v7C
6hvbG5jWWC5t3DxyowyrKw4II5BHBqPWnaPR75kJDiByCOoO018RWuqeIdb+ HOr6/c+KPEa3
+gfDTRtdshBq1xEjXxS7ZppVVx5xby13K+5XA+YNgYuEee/lb8b/AORrGm5K 63/zaX6n2/Jq
9jFqcOnPeQJqE8bzRWrSASuiFQ7KvUhS6AntuXPUV8vft9fd+AH/AGVbQ/8A 2tXQaj4g8GaZ
+2D4ML32iWXivUPC17b3S+bFHeTu0tm0EbjO9iVWUop7K+Ohrn/2+vu/AD/s q2h/+1qLe7GX
e/4Sa/QwbVtOyf3q59Q0UUVqeYFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFQ3v8A
x5z/APXNv5VNUN7/AMec/wD1zb+VAH53fsMf8mw+Ev8Arpe/+lk1d/8AHjP/ AApLx9jr/YV7
/wCiHrn/ANgb9nqXx1+yp4N1tPiH4o0Fbl77/QNNj08wRbb2dflMtrI/O3Jy x5JxgYA921v9
jKDxJo19pOp/FPxtdadfQPbXMBTS18yN1KsuVsgRkEjIIPpXOeqdfL4h+Mw0 5xH4F8FvCIiF
dvF10GK7eCR/Zpwfzr56+A+f+FJeAc9f7Css/wDfhK+3vIX7N5P8OzZ+GMV5 f4S/Zz8N+DfC
+kaDZ3mpS2emWkVnC88qGRkjQKpYhACcAZwB+FAHkWhTX2kfErQ5vDc0kWvX 0scF1awxealz
ZBwJHnTcoCxBiyyEgqx2jd5nlv8AS/2TxD/0E9O/8AH/APj1Z/gH4a6R8PLW 5WwEt1fXbB7r
Ubwh7i4IztDMAAFXJARQFXJwBk56ugDE+yeIf+gnp3/gA/8A8eo+yeIf+gnp 3/gA/wD8erbo
oAxPsniH/oJ6d/4AP/8AHqPsniH/AKCenf8AgA//AMerbooAxPsniH/oJ6d/ 4AP/APHqPsni
H/oJ6d/4AP8A/Hq26KAMT7J4h/6Cenf+AD//AB6j7J4h/wCgnp3/AIAP/wDH q26KAMT7J4h/
6Cenf+AD/wDx6j7J4h/6Cenf+AD/APx6tuigDy74zG00qx0vVbe5eHx1Cxh0 YWEIee9lIBe3
MRYb4X2guGYKoXeXQoHXzL9onxD8X7n9nf4jLqvgjwhZWEnhq/F1Nb+Krmaa KM2z72WM2Ch2
AzhS6gkY3DrXvWi+A7DSPEeo6/LLcanrN5lPtl6wZreHORBEAAEjBA4AyxAL FjzUvj7wbZfE
XwN4g8K6jJPDp+t2E+nXElswWVY5YyjFCQQGAY4JBGexoA+cbX/j2h/3B/Kv lf8Aas/5Od/Z
b/7GtP8A0qs6+1V/ZKmRQo+LXjbAGB+60r/5Br4//bH+Ez/C79p39lbf4s1v xT9t8Vrj+2Ut
F8jZdWX3Ps8EXXdzu3fdGMc5a3E9mfprRRRW55YUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAcf8AEfQL7U4NF1TS4hc6hoV+NRitCwX7QPKkieME8BikrlckDcFyQMmu P8eapp/xl8HS
aToWpW1h4psLq11OHS9Z3QOk9vOkyRzxkFlRmj271DDB3LuwM+wVh+JfA/h/ xjEket6NZaoq
Hcn2qBXKH1UkZB9xXPKE4y56b10fzWz8vxPYo4qhUpRoYuLtG9pRtdJ6tNOy krt9YtXer2PM
fil4e+JXxC+HuiWlroXhe31yHWLPUbqB9enNskdtcxzqElFnucv5e05RQuc/ NjB9gjvPIsop
L5oLWbYDKolyitj5gGIGQPXA+griv+FG+FkOITrVqnaO116+hQfRVmAH5U6P 4GeCy4a70qTW
MHIGsXk18AfpM7ijmr2a5Vvfd9ku3kinTyzS9aen/TuP/wAsMnxp4ns/irpG o+DvDD/2quox
taX+qQDdaWcTfLLmXo0u0kBFyQ2N20c16jGnlxqv90AVHZ2Vvp9ukFrBHbwo AqxxKFVQOgAF
TVUINNyk7tnNisTTqQjQoR5acW2ru7bdrtuyXRWSWluru2UUUVsecFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAQ3v/HnP/wBc2/lXwv8A8EZf+Ta/Fv8A2N91/wCk1rX3Re/8 ec//AFzb+VfC
/wDwRl/5Nr8W/wDY33X/AKTWtZzOqh1PvmiiiszrCiiigApDkA45NLRQBzPg /wAbQ+KHvrC5
tm0vXdPYJe6ZMwZo852SIf44nAJVx1wQQrKyrH8UfGUfw1+GvirxabIX66Hp dzqRtA4jM3kx
NJs3YOM7cZwcZ6VzXxrax0u207VrOeW28bRO0WiLZRiW4vJCAWtjHuXzIWCg uGZVULv3IUDr
5h+0T4h+L9z+zv8AEZdV8EeELKwk8NX4uprfxVczTRRm2feyxmwUOwGcKXUE jG4daAJU/aH+
JcoSUfDXwpkgEE+K58/+m+vEf2nPit4w8da/8CrHxH4U0bQbOP4maLNHcabr ct87yB3AQo9r
EAuGY7txOQBt5yPWrX/j2h/3B/KvF/2kv+Rl+BP/AGUzRf8A0KSmhPZn6FUU UVueWQX17Dp1
pLczuEhiUszH0ri7rxFq+pPvhmGlwH7qKivIR6sTkD6Afia0/Hzk2mmw5+SW 8UMPXajuP1UV
iV/MvivxrmmR4ujlmWz9nzR53Jbu7aSXbZ3Po8swdKtB1aiv0D7ZrH/Qcu/+ /UP/AMbo+2ax
/wBBy7/79Q//ABuiiv59/wCIgcU/9B8/vX+R7v1LDfyI5PWviVqui+P9K8Nv f3sqXul3mpNd
RpEzILd4F2CMREsW8/PBz8uMHPE3w7+Js3xN8NDXNJ1fVobM3VxahL+yjt5t 0MzxOTG0YZcs
hwGAbGMgHIGL4i8Pao/xj8O+I7exe602w0LUraVo5EDedJLatGgDMMlhE/PQ Y5IyKzf2ebTX
dL8JapZ6/wCGr/w3cnWdQvY472a3k82O4upZkIMMsgBCyAEHHOcZHNfQ1ON8 /wD7PVaGYT9o
uW/vx6uon7u97KG2y3WtyZYPDJq0Fv28v8z1L7ZrH/Qcu/8Av1D/APG6Ptms f9By7/79Q/8A
xuiivnv+IgcU/wDQfP71/kV9Sw38iJ7XxDq+mvvlnGpwfxRuipJj/ZIwM+xH 4iu0sL6HUrOK
6t33wyruU/571wlbXgFiLfVI8/JHeEKPTMaMf1Yn8a/oDwn41zXPMZWyzMqn tLR51J7qzSaf
fdWPDzPB0qUFVpq2tjqaKKK/pw+bCiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigAooooAKKKKACiiigAooooAKKKKACob3/jzn/wCubfyqaob3/jzn /wCubfyoA+af
+CZ0qwfsS+A5HYKiNqTMT0AF/cV6BbftSeH30jWNVutD1vT9OtNIm12wnuEg I1ixiI3zWwWU
nHzRnbKI2xKhx1x55/wTTto739iDwNbyruilOpIynuDf3ANdbZfsu3F1ot5o viDxOmp6TbeH
rnwzoa2tgYJrK0m2hmmdpXE8oWKEBgsY+Rsqd3GEbcz5tv8AgP8AW3la/kez Hl05u6+66/S9
+u1rl74y/tEz+A1msvD/AIfvNd1q2uNFaaBREEe3vrtoAELyxjzMRuBkhQzR k5Xdjds/iX4m
n+Mvh/wxeaBbaToeqaBc6qGnufMv454pLZTDIiAxIF89gSkkgYjgqB83IXX7 NvibWxr2oa14
3sbvxBfQ6StrcWuitDa2smn3T3ETGE3DM6sXAZTIDw2GGQF6qT4ZeNbv4s+G PGN14r0R4NK0
uXTbmwi0OVWuPOMTTOkhuj5eXgQqCr7QWBLnDDSPImk+7+7lsvulq/l5ktrl 87L79L/rb/hj
1eiiisiQooooAKKKKACiiigAooooA8w+NXjPxN4cvvBOk+FrzSdOvvEGrPYS XusWUl3FDGtr
POSI0miJJMIH3+Mng1zHh39pG5HhDTpL/wAO3fibxPLc6jA1l4YEQWeGynaG W8jFxMgWIkIQ
u9mBkCgvgtXbfFf4N6P8YLrwouv29nqOk6LqTahNpmoWa3MN5m3liCMrcDBl DgkHlBxzkZ3j
f4OXd3caFfeBdT07wbqGk2E2kQrLpZubRbKUR5jWFJYtpUxRlCGwuCNpB4L2 jpv/AMDT5X3t
0u97Gj5W4+mv3v8ASz+SXVnG/FT9q+Lw94S1688F+G9T8V39l4ci8RRXcMcI so7eZZTFJKZJ
o2K5hO5Fy+CNoODtp237S3iaP4t22iaz4W/4R7w5caNbyn7eyNe2uoTvc+Ss phlki8qRbZgM
NkM8YJy2B0sP7Mmm2egeJdDttVli0vV/Cdp4WjRog0kCQLcATFs4dm+0Zxgc r3zxHL+zte+J
tP8AFK+LvEVtqWoa7olppLXOlac1mttJbSzyQ3MStNKQ6mZCPm4aLPfC6VOV KXJr2/Fff69b
PyBcril6f+2b/wDk2i6aLe4lh+0Xd6V8KPCPjHXvCWp3mn6jo1vqmqato5th aaeHRWkLRy3A
mKqCW+RJDtHc8V8WftzfGGH4hftCfsyapo3hvWprXSvGF1bQtKIIzqM8N/ax vHb7pRzui4aT
Yh8xfmyHCfTPjH9iSbxb4N0Tw5P4m0q+ttP8NQeH/P1nQPtsls8SMv2uyBnV baR8rv4ckRoA
RtBr51/bF+Hf/CsPjd+yLof27+0d3jq+vfP8ry/+PjU7SbbjJ+75m3OecZwM 4Fz5G5OL6u3p
fT8Pn3M525Vbfr93+en5H2BH+1P4euLWGe30TWbhYYXuNaVfsynQokmkhd7r dMAdrwzjEPmk
iJiARt3ezRusqK6kMrAEEdxXzPc/sT6VJ4j/ALYMvhzVrm5mujfHxD4aj1E+ TLezXKC23yAQ
yp9okQuRIrYQmP5cV9MRRiKNUXhVAAq9OXzu/wDgHm1FFStB3X9f193mOooo qSAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAhvf+POf/AK5t/Kvhf/gjL/ybX4t/7G+6/wDSa1r7ovf+POf/AK5t/Kvh f/gjL/ybX4t/
7G+6/wDSa1rOZ1UOp980UUVmdYUUUUAFFFFAHN6L4DsNI8R6jr8stxqes3mU +2XrBmt4c5EE
QAASMEDgDLEAsWPNS+PvBtl8RfA3iDwrqMk8On63YT6dcSWzBZVjljKMUJBA YBjgkEZ7Gti/
uPsljcT5x5UbP0z0GeleF2n7WGmW+gWF3PoGuawE0Cx8QanqFhaQQW9paXAk /fOklwSAvlMT
GjSOBjbvwSGk5Xt5fjf/ACZVnbm/rp/mRL+yVMihR8WvG2AMD91pX/yDXgv7 VXwQk+Gmt/Af
Un8ceIvEwl+J2i2/2TV0sliTLSNvHkW8TbhtxyxGGPGcEfTHj/xp468FeKNG 1CPUPD174X1X
V7TTLbQ1sJhqUqTYDyLcefsLJ+8lKCE/u42+bqw81/b6+58AP+yraH/7WoSu ubzt89H+TRnL
t5X/AD/yZ9Q0UUVueYcr49+5o3/X7/7RlrGrZ8e/c0b/AK/f/aMtY1fxJ42/ 8lFQ/wCvMf8A
0uofY5R/u79f8gpHdY1yzBR6k4pa8v8A2oNMsdW/Z88fw6hbQXcKaNczKlwg ZVkSMsjgHoys
AQeoIBFfhGDoLFYmnQk7Kckr2va7te11f70e9FczseoKwYZBBHqKTcMkZGRX F+HLKDRtX8P6
bp2sWWnaVBo5WLwxbwRoWAaMLOmPmVEGU2gbf3gzyBXMaif7d+LHj/RLqRoL IeGdOkEtm5tb
kFpb0HFxGVlA+QYG75ctjG5s9UMCpylaekVzbO9uZR2011vo2ulzKnLnjf0/ G3+Z64CCMg5F
Fecfs3sG+APw8w+/GhWY3Fsn/Ur1Nej1yYuh9VxFShe/LJq/ezsOLukwrZ8B fc1n/r9/9oxV
jVs+Avuaz/1+/wDtGKv3jwS/5KKv/wBeZf8ApdM8XN/93Xr/AJnVUUUV/bZ8 cFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFQ3
v/HnP/1zb+VTVDe/8ec//XNv5UAfNn/BMj/kynwD/wBdNR/9OFxX1JX52/sI /Gjx14S/Zc8H
6VofgzQdX0yB73yry+8QTWk0hN5Mzbols5AuGJA+c5AB4zge1eKP2rviJ4P8 N6rruofDfw49
hplrJeXC2/iqdpDHGpZgoNgAWwDgEgZ7iuc9U+qKKh+0f6H5+P8Alnvx+Ga+ XvC37V/xC8Xe
HNK16y+G/h5dO1K2ivIVl8UzCYROoZQyixIDYI43Yz370AfU9Fcx8PfiFpXx I0BdS01njdHM
N1ZXACz2kwALRSKCcMMg8EgghlJVgT09ABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABX5/f8A
BR3/AJOd/ZD/AOxrb/0qsK/QGvz+/wCCjv8Ayc7+yH/2Nbf+lVhTW4nsz72o oorc8sKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
oAKKKKACiiigCG9/485/+ubfyr4X/wCCMv8AybX4t/7G+6/9JrWvui9/485/ +ubfyr4X/wCC
Mv8AybX4t/7G+6/9JrWs5nVQ6n3zRRRWZ1hRRRQAUUUUAQX9r9tsbi33bPNj ZN2M4yMZrw3T
v2XPsHgfXfDv/CSb/wC1PB9l4T+0/YseX9nWdftG3zOd3n52ZGNv3jnj3miq jJxvbrb8L2/N
lxnKO39ap/mkeKT/AAa8cJ8WD4vt/GOg3FrFFHa2Flqvh+a4l0632oJo4JEv I0VpGUs0hjLH
KqSVRVHn37fP3P2f89f+FraH/wC1q+rK+U/2+vu/AD/sq2h/+1qS2SMmtD6h ooorc8w5Xx79
zRv+v3/2jLWNW149/wBXo/te/wDtGSsWv4k8bf8AkoqH/XmP/pdQ+xyj/d36 /wCQVmeJPC+j
+MdIm0rXtKs9a0yYqZLO/gWaFyCCuUYEHBAI46itOvC9Y+LXjRdB8R+O9Pj0 YeC9Bu7mGTS5
7eVr68gtpGjuJlnEgSM5SQohjfcEXLKX+T8QwGEr4mfNQlytNWd7e8/hSfdt adFa7aR7cnZb
XPX9M8JaJohsjp+kWNibG2+x2pt7dE8iDIPlJgfKmVX5Rx8o44puq+ENC11b 9dS0ewv11CBb
W8FzbJJ9ohUsVjkyPmUF2IU5A3H1NM0jxQmsazeWEdhexR29vBcLfSxYtpxL uwsT5+Zl2/MO
25fWuW0v416ZqvjKPQ00vUYbS4u59Ps9ckEP2K7u4QxlgTEhk3L5cvLIqkxO Ax4yQo42cpTj
e8Vdu/T4u/ztvo30ZClBRutv6/yOt8MeEdD8E6UumeHtHsdD05WLi0063SCI Mep2qAMn1rWr
gfhf441zxbrHjix1ywsdPl0LWBYQJYTvMHiNtBMrM7KuWPmnICgDgfNjce+r DF0q1Ks413eT
s273vdJ79dGWrLRBWz4C+5rP/X7/AO0Yqxq2fAX3NZ/6/f8A2jFX7t4Jf8lF X/68y/8AS6Z4
mb/7uvX/ADOqooor+2z44KKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKhvf+POf/rm38qmqG9/485/+ubfyoA/ O79hj/k2Hwl/
10vf/Syau/8Ajxn/AIUl4+x1/sK9/wDRD1z/AOwN+z1L46/ZU8G62nxD8UaC ty99/oGmx6eY
Itt7OvymW1kfnbk5Y8k4wMAe7a3+xlB4k0a+0nU/in42utOvoHtrmAppa+ZG 6lWXK2QIyCRk
EH0rnPVOvl8Q/GYac4j8C+C3hERCu3i66DFdvBI/s04P5189fAfP/CkvAOev 9hWWf+/CV9ve
Qv2byf4dmz8MYry/wl+zn4b8G+F9I0GzvNSls9MtIrOF55UMjJGgVSxCAE4A zgD8KAPJPDs9
3o/xP0Gfw/LMutXs0cF7Z28fmLdWIcea8y5ACxBmZZSQVYhRu8zy3+sK5TwD 8NdI+HlrcrYC
W6vrtg91qN4Q9xcEZ2hmAACrkgIoCrk4Ayc9XQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAV
+f3/AAUd/wCTnf2Q/wDsa2/9KrCv0Br8/v8Ago7/AMnO/sh/9jW3/pVYU1uJ 7M+9qKKK3PLC
iiigCC+vYdOtJbmdwkMSlmY+lcXdeItX1J98Mw0uA/dRUV5CPVicgfQD8TWn 4+cm002HPyS3
ihh67Udx+qisSv5l8V+Nc0yPF0csy2fs+aPO5Ld3bSS7bO59HlmDpVoOrUV+ gfbNY/6Dl3/3
6h/+N0fbdY/6Dl3/AN+of/jdFBr+ff8AiIHFP/QfP71/ke79Sw38iPKrb4++ JLvQW1Kz0HxN
rmy+1G0lj0cWDCFbS5aDe7TmIZfbuCLuPUc4ydhfjvazXfgeC31rWrkeMRv0 24i05PI2+Q8+
ZJTEEQ7UOEJ3knhcAkeV32j/ABE8M+Co/DGneFtWuLPVdb1e61S+0W6sxdwW kt7JJEkXnTxh
WmST/WAlowD8ocgp0Pi2y1wXnwj/ALC+HmsR6Zol99pubSOexU2EP2Se3WNg bjDMDKh+QsNo
POcA/c1OMM6lJqOYNJupy2qx2Sly8127Xkko7XW795Mxng8OpStBac3Tz0t3 /wCG31PcPtms
f9By7/79Q/8Axuj7ZrH/AEHLv/v1D/8AG6ByKK+G/wCIgcU/9B8/vX+Rt9Sw 38iJ7XxDq+mv
vlnGpwfxRuipJj/ZIwM+xH4iu0sL6HUrOK6t33wyruU/571wlbXgFiLfVI8/ JHeEKPTMaMf1
Yn8a/oDwn41zXPMZWyzMqntLR51J7qzSaffdWPDzPB0qUFVpq2tjqaKKK/pw +bCiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigCG9/485/+ubfyr4X/ AOCMv/Jtfi3/
ALG+6/8ASa1r7ovf+POf/rm38q+F/wDgjL/ybX4t/wCxvuv/AEmtazmdVDqf fNFFFZnWFFFF
ABRRRQAUUUUAFfKf7fX3fgB/2VbQ/wD2tX1ZXyn+31934Af9lW0P/wBrU1uJ 7M+oaKKK3PLM
nxPo7azpZjiIW5icTQk9Nw7H2IyPxri4btZHaKQGC4Th4ZRh1P0/r0r0qqd/ o1hqhU3llb3R
XoZog+PzFfk3G/h9heMZU67qulVhpzWumuzV18tUepg8fLCJxtdM4fev94fn Xjur/A3Vb2HW
vD9p4rhtPAet3ct3f6S2n77sec5e4ihufMCpHIxYkNG7DzHCsBt2fR3/AAh2 g/8AQGsP/AZP
8KP+EO0H/oDWH/gMn+Ffm+F8Fq+CbdHM7XtvRT1WzV5uzXRrVHpSzlSVnD8f +Aed6bpl/Za7
f3EurCfSJYIYrTTfIVfszLu3v5g5fflOD93Zx1NcBo/wVudM8X2VzJr0E/hb TNTuta07SVsy
s8V3OJN5ecykPGDPOVQRqRuX5jt5+g/+EO0H/oDWH/gMn+FH/CHaD/0BrD/w GT/CqpeDGIoq
Sp5mlzKz/crtb+fR2b95a6vXVi/teNrez/H+tPLY8Q+G/gHxB4P8VeMNU1bx Bpuq2uv3ovxb
WmmPbPbuIo4QN7TyBhsiT+EfNuOcEKPQ96/3h+ddZ/wh2g/9Aaw/8Bk/wo/4 Q7Qf+gNYf+Ay
f4VhifBKpiqntauZK9ktKKWiSS0U0tkUs5Sv7n4/8A46a7SNljXM078JDGNz ufYf1rotG0rV
dDsQYUtp5ZmM1xFI5Qhz2VgDwAAOnatqx0XT9LZms7G3tWbqYYlTP5Crtfpf BPh5heDp1MR7
V1as1bmtypLsld79dWebjMfLFJRtZGN/wkf2fi+sLuz9X8vzU/NM4H1xV+y1 Sz1FN9rdRXCj
qY3DYq1VC90HT9QfzJ7SNpR0lA2uPow5FfrR5ehforG/sO7tObHVZ0HaK6Hn p+Zw3/j1H2/V
7P8A4+NOS8Qfx2Uo3f8AfD4x+DGmFuxs0VkxeKNPZxHNK1lKeAl2hiJPtuwD +Ga1VdXAKsGB
6EGgVrC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFQ3v/HnP/wBc2/lU1Q3v/HnP/wBc2/lQB82f8EyP+TKfAP8A101H/wBO FxX1JXy3/wAE
yP8AkynwD/101H/04XFdl8X/AIw+KfCviDxKnh4aVHpvhDRodd1aLUrZ5Zr+ J2l/cwOsqCFg
lvJ87LICzqNvBzzrVpHrqLe39dPzPcqK8I1T48a3b2fime3tbIDTfFulaDbC WNwTb3Qsi7ON
3+sH2qTBGAMLkHBzyHgNL7WfhFr+s/FPx1dHw/p/iHU2gfRJ73TLseXe3MIh eeK5aSZSSgih
jCkYRMSHFU4tR53t/wABP8pIfLon3dvz/wAj6morgPgRZ69YfC/SIvEbXp1D MrxpqUvm3cVs
0rm3jncklpViMauxJJYHJJ5Pf0SXK2jNO6CiiipGFFFFABRRRQAUUUUAFFFF ABRRRQAV+f3/
AAUd/wCTnf2Q/wDsa2/9KrCv0Br8/v8Ago7/AMnO/sh/9jW3/pVYU1uJ7M+9 qKKK3PLCiiig
DlfHv3NG/wCv3/2jLWNWz49+5o3/AF+/+0Zaxq/iTxt/5KKh/wBeY/8ApdQ+ xyj/AHd+v+QM
wUZJAHqaRHWQZVgw9Qc1meKdOs9X8N6pZahbQ3ljcW0kc1vcIHjkQqQVZTwQ fQ15F+z9Y22j
fB34O2+l6vY+HrWbT4pptLSCMHVXe2Lsqk4IcMfNZlBJ2nPBJr8Qo4ONbCzr 89nGSVraaxlL
dXd/dttbW7aR7Um42PccjOMjPpRXh3xO0u/uf2h/BF1a+ItQ0VIdA1STy7VI Ck+yazYxt5kb
HDgjdtIbCDaV5JwPhf8AEHxWP+EBvfEPiyXUbfxD4Ru9aulube3ghinjFnt2 FEUgASyE5Y5L
E8AKq+jDJJ1cNDEU6sXeN7e9f7ei0aekG912Hd83Lb+tP8z6Qor5Ej+N/wAR dd0rwsdNi1e9
vY/CFj4gkn046ZDb6hcS794ujdMhWAGNcm3AYCRjkfJX1xbu0kEbuu12UErn ODiubMsprZXy
qtKLcr6J3at3XS97r/O5EZqTsv66/qh9bPgL7ms/9fv/ALRirGrZ8Bfc1n/r 9/8AaMVfs/gl
/wAlFX/68y/9Lpnj5v8A7uvX/M6qiiiv7bPjgooooAKKKKACiiigAooooAKK KKACuT8S/EfS
/D3iKx8O7zP4gvraW8t7IAgGGNkV3Z8YUAyIPU54BwcdZXyr8SPEH/CM/HzQ PFGoadrF5po0
/V7CS40rSbm/8p/tFqI0ZYI3KgrE5BIA4PevguNM+r5BljrYSN6s7xjpf3uS Ulp1+HY9HA4e
OIqNT2Wv4o9ubxTrjPjztOhY9IzC7n894/lSHxRrgYqbvTdw6j7M+f8A0bXy v4h0qfxD8SJd
Th8P6nN4svta0u98Pa7Lo86Cy0oLCbiJ5mjAt+Fuw8EjKzGXG0lwK2PDdrZa BcePp9R8CXPi
D4lhtTmF3c6RIU1O1LM1vbpfGIx7DD5MflbuNpBU4Of5inxvxbGmpxzDVpPl 9lSur211XwJu
zk3pJNNdT6VYDCuXKodV1fW/+Wnqtj3zxD8T7rwrp8d9qeqaZb2slzBaLILO R8yzSLFGvyyH
q7qM9BnJwMmrVp461a9lvI47mzU2sgikaXT5o1JKhsozOA4ww+ZSRkEZypA+ GrT4fXer6R4y
im8HRT+Flm8P6mNM07wZdaVbSNHev9s8uymLvJKIFAYqoLrtG05Ge8m8LReX rE8nhW+f4ct4
qtbq40QaLMfP08aRBHEFsvL3uiTiLMYTKmM5A2EV6dXjDiamnBZm3Jf9OqXa m1FJxvze81Z7
tbrUlYLDNX9n+L83/l8z6zPinXFAJu9NAPQm2f8A+O1zUvxuig8dv4NfW9LX xIunf2r9hNjK
Cbbfs8wNv2n5hjAOfbFfOvhn4UP4n1Dwba+I/DEt74ah0nX2s9P1KzYxWtvJ eW7WMEsbDCss
IG2NwCvl4wDHxlaB8PvF99p9v4gGl6gvizRvBmhXFm17E8b3N1ELwXNozMB8 7xyFGB5UyIxG
QKxp8bcRJT9pmt2tP4dJK7m4xbfK7rS8tFZPRsr+z8O1dU106vuv0bs/wPrb w38Rr/xVoOna
3pd3p9/pmoQJc20v2WWLzI3AZThmyMgjgjI9K7HQPEqau7W80Rtb1F3NETuD D+8p7j8iPSvm
z4F+L7zw98J/A+h6h4U8RW19aafpthP5lgVWN5LcMzHJBCxkbXJHytgYr1Dw 74hbXbLRdajs
b3SZJLqNRbahF5U6BpPLYOuTjIJP5GvR4e8Q+IKWfU8FmM1Wo1Kipp2in7zt FrlSXrocuIwG
HlRcqas0rnq97/x5z/8AXNv5V8L/APBGX/k2vxb/ANjfdf8ApNa190Xv/HnP /wBc2/lXwv8A
8EZf+Ta/Fv8A2N91/wCk1rX9cTPnaHU++aKKKzOsKKKKACiiigAooooAK+U/ 2+vu/AD/ALKt
of8A7Wr6sr5T/b6+78AP+yraH/7WprcT2Z9Q0UUVueWFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFADJYY50KSIsiHgqwyDWU3haxRi1p5unv1zaSGNf8Avn7p/EVsUUBd oxvs2tWX+qu4
NQQfwXSeW5/4GvH/AI7R/wAJBLa8X+m3VsO8kS+cn/juT+YFbNFId+5TsdZs dSz9lu4piOqq
43L9R1FXKpX2jWOpYNzaxTMPuuyjcv0PUVT/ALAmtebDU7m39I5m89P/AB75 vyYUBobNFY32
rWrP/XWcF+g/jtZNjn/gD8f+PUqeKbFWCXRk09+mLuMxjPsx+U/gaLhZmxRT Y5UmQNG6up5B
U5Bp1MQUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVDe/8 ec//AFzb+VTV
De/8ec//AFzb+VAHzZ/wTI/5Mp8A/wDXTUf/AE4XFe3+Nfg54V+IOsWep63Y zz3Vsqx/uL6e
3juIw4cR3Ecbqs8YYZ2Shl5bj5jnxD/gmR/yZT4B/wCumo/+nC4r6krn2afV Hq9Gu555r/wB
8EeJvFR8Q6jplxNqBuLa8ZE1C4jt3uIGQwztAsgiMi+Wg3ld21dpJXis3W/2 Y/AOvzzy3Nrr
EJl1I6wFsvEF/bJDeESBpoVjmURM3mybvLChixJycGvVaKNlb+un+S+5dh3b /r+u7MTwj4Rs
fBOjJpmnzajcWysXD6pqNxfzZPXMs7u5HoN2B2rboopt3JtYKKKKQwooooAK KKKACiiigAoo
ooAKKKKACvz+/wCCjv8Ayc7+yH/2Nbf+lVhX6A1+f3/BR3/k539kP/sa2/8A SqwprcT2Z97U
UUVueWFFFFAHK+PfuaN/1+/+0Zaxq2vHv+r0f2vf/aMlYtfxJ42/8lFQ/wCv Mf8A0uofY5R/
u79f8irquk2Wu6bdadqVpBf2F1G0M9rcxiSKVCMMrKeCCOCDWXovgDwz4cs9 OtNK8PaZptrp
0jy2UNpaRxJbO4IdowoAQsGYEjGdxz1rG+KHjHU/DUOhaboMVrJr2v340+zk vgzQW+I3lkmk
VSGYKkTkICu5tq7lBLDA0T4na9oF94s0PxTZJr2taDZwalG/hqzdWv7eYyKo jt3kdlkVonUr
vYEbTkbto/F6OExc8NzUpe69eW9m1fk5rbWu+Xvv0TPYk4p+8v8Agf1/XQ77 xB4N0HxXLYSa
1othq0lhMLi0e9tklNvKOkkZYHaw9Rg1V1P4c+FNZ03TNOv/AA3pN7YaWyPY Ws9lG8VoyjCm
JSMIQOBtxiuf+NnxF1T4beCbTWdI0eTWbubU7CzNouzcUnuI42xvkQbsOQuW wGKk/KGIxz+0
TYw393a3PhTxBafYb+y0u+mkW2Mdrc3X2fyo2KzHcR9pXcU3AbG5wU36YbB5 jVowrYdtxTaV
pWaasnpfS7kku7duo249ex2198NPCOqRaLHeeGNHuo9FKnTEmsY2FjjbjyQV /d42rjbj7o9B
XSdK871n43aRpU2r2kWn6hqGqWGqpo0WnW4iWW9uWt0ucQl5FTAicsS7JjY3 tnqvB/iu18aa
BBqlrHLbh3khltpypkt5o3KSxPsZl3I6sp2sRkcEjBPHiMPjI0o1MQny9Lv+ bXRdnvfZu/VM
eiduv9f8H8TarZ8Bfc1n/r9/9oxVjVs+Avuaz/1+/wDtGKv3DwS/5KKv/wBe Zf8ApdM8XN/9
3Xr/AJnVUUUV/bZ8cFFFFABRRRQAUUUUAFFFFABRRRQAV5pZ/fvf+v25/wDR z16XXmln9+9/
6/bn/wBHPX8+eNv/ACT1D/r9H/0ioe9k/wDGl6fqixRRXkfibTmk/aV8HONQ 1SKF9C1G4kso
tSuEtJJIpbZY2eBXEbECeTqpzkZztXH8ZYTDrEzlBytaMpbX+FN23W9tz653 Suj1yiuctG8Q
nwffnVZtOi1sLc+XLYq7wIu5vJJDEMSE2bhkfNuwQMV4L8J/HvxK/wCEY+GW kT63oupT6x4b
l1mbUbzT52mWKEWgCNm4Pmyt5z7pCVGSG2/KVfuw2VTxUKk4VIrkduuvuyk2 mk9EovzfQV9E
7b/8D/M+naK+fj+0fqeleDvC3iHUtPtp4b7wTe+KL6C0VlczQLbMI4iWO1T5 z9Qx4Xng56r4
H/EzXfHU2q22t280v2aKC4i1H/hHb3RoX8zeGgVLolpGTYCZFOCJFG0EHN18 kxmHoTxNRLlj
p90uV+Wj72vfS+tk5pW8/wDgf5o9Xqveffsv+v22/wDRyVYqveffsv8Ar9tv /RyV28Jf8lDl
/wD1+pf+lxMsT/Bn6P8AI9Fvf+POf/rm38q+F/8AgjL/AMm1+Lf+xvuv/Sa1 r7ovf+POf/rm
38q+F/8AgjL/AMm1+Lf+xvuv/Sa1r/S6Z8JQ6n3zRRRWZ1hRRRQAUUUUAFFF FABXyn+31934
Af8AZVtD/wDa1fVlfKf7fX3fgB/2VbQ//a1NbiezPqGiiitzywooooAKKKKA CiiigAooooAK
KKKACiiigAooooAKKKKACiiigAooooAKa6LIpVlDA8EEU6igDJk8LaeXLwRN YynnfaOYsn1I
Xg/iDTPsOsWf/HvqEd4g/gvIsMf+BpjH/fJrZooHdmN/bl1a8X2l3EY7yW37 9PyHzf8AjtWr
LXbDUWKW91G8g6xZw4+qnkVfqre6VZ6kgW6tYbgDp5iA4+npSDQtUVjf8I4b bmw1C7s/9gv5
qfk+cD6EUedrdl/rILbUUH8ULGF/++WyD/30KAt2NmisceKbSI4vY59Nbv8A aoyqD/gYyv61
qQXMN1GJIZUlQ9GRgQaYrWJKKb5qGQx718wDcVzzj1x+Bp1ABRRRQAUUUUAF FFFABRRRQAUU
UUAFQ3v/AB5z/wDXNv5VNUN7/wAec/8A1zb+VAHzZ/wTI/5Mp8A/9dNR/wDT hcV9SV8t/wDB
Mj/kynwD/wBdNR/9OFxX1JXOeqFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAV8F
ft4N4c8UftZfs1aPP4x0rRNf0PW4dSOlX8F20t5HPeW6xCF4oHj3FraRcSOg B2kkA5H3rXwV
+3gvhzwv+1l+zVrE/g7Stb1/XNbh006rfz3ay2ccF5btEYUinSPcGuZGzIjg naCCBggnsfdV
FFFdB5YUUUUAZPifR21nSzHEQtzE4mhJ6bh2PsRkfjXFw3ayO0UgMFwnDwyj Dqfp/XpXpVU7
/RrDVCpvLK3uivQzRB8fmK/JuN/D7C8Yyp13VdKrDTmtdNdmrr5ao9TB4+WE Tja6Z418RvBD
+NrHTXsdSGka3pN4uoabfmITJFMFZCHjJG9GR3RlBU4Y4ZWAYYOj/DPxBZQ+ JtVufFsB8ba3
BFbDWLTTglvZxxbvKWK2eR8gGSRjvdiWc8gYA93/AOEO0H/oDWH/AIDJ/hR/ wh2g/wDQGsP/
AAGT/Cvzqn4M4ilS9jHM1y+dGL6p2u5t8t1fl2b6anoyziMnd0/x/rueTfEv wTJ4/wDBzaRD
qKadfJcWt5b3kkPnJHPBMkyFowy7l3RgEbhkE8jrXH3PwRvtR8PeKILvxFbN retarZa2t7DY
FILe6to7YJ+5MpLRl7UMV3g7XK7sjcfon/hDtB/6A1h/4DJ/hR/wh2g/9Aaw /wDAZP8ACrw/
g5isLBU6OaWSd/4Ket4vdzva8Y6baepX9sr/AJ9/j/wD5X1r9mJ/FWk6q/iD WtJ13XbvXY9f
ikvtFEunxyrax2zRPatKTJGUViMyBlLKdxK5PrPw88I2/gLwjY6LBHp0CwBm ZNKsksrUOzFm
8uFSQi5JwCWPqzHJPp//AAh2g/8AQGsP/AZP8KP+EO0H/oDWH/gMn+FXivB/ GYykqFfNbwTu
l7FJKytpaasrdNif7Xhfm9nr6/8AAOOmu0jZY1zNO/CQxjc7n2H9a7Hwto76 PppWYg3M7mab
HQMccD6AAfhVux0XT9LZms7G3tWbqYYlTP5Crtfe8EeHuF4OnUxHtXVqzVua 3KkuyV3v11Z5
+Mx8sWlG1kgooor9bPKCiiigAooooAKKKKACiiigAooooAK80s/v3v8A1+3P /o569LrzSz+/
e/8AX7c/+jnr+fPG3/knqH/X6P8A6RUPeyf+NL0/VFiuV1H4ZaFqvjzTvGNw l8de0+3e1t5I
9RuEhWJjl1MCuIm3EKTlTkohP3Vx1VeO6v8AHXVrKHWvEFp4Wiu/AeiXctpf 6s2obLs+S5S4
lhtvLKvHGwYEtIjHy3KqRt3/AMc4Chi60pfVHZ2s/eUb82nLdtX5tuXd66H1 srJe9t/T/Q9N
8OeFtM8J6T/Zml2/2ay82Wbyi7P88sjSSHLEnlnY47Z44rn/AAl8G/Cngi9t rrSbK5iltYp4
LYXF/cXCW8UxjMkUayOwRMwx4RQFXb8oGTne07xZpera5faPa3PmajYwQ3Fx DsYbI5d3lncR
g52N0JxjnGRXncP7Snhq18ReMtM1qDUNHh8O6jFYNfSafcvbzGRYNp80RbFY yXAUJuJKjf8A
dORvQpZnXdWNBTbaTkle7UtE2t3fm03un2ZKcOW62Nvw/wDAXwR4Y1Jr6y0i Rpjaz2Cpd3k9
zFFbTFDJAkcjsiRExriNQFGDgDJzt+CPh3ovw9tZrfR0vBHLtBN9qE946qow qK0zuVRcnCKQ
oycDk1QsfjF4Vv8AS7m/W+uIILW+ttMnW7sZ4JYrmfyvJjaN0Dgt58XUYG7n GDizYfFHw7qf
i6fw3bXVxJqUTNGXNnMLV5FGWiS4KeU8ijJMauWG1sj5Ww6zzWtGar+0a+1f mei11v2vfXa9
+o/d3Orqveffsv8Ar9tv/RyVYqveffsv+v22/wDRyV38Jf8AJQ5f/wBfqX/p cTLE/wAGfo/y
PRrobrWYZxlCM/hXxB/wSQk8OaF8JvG3hTSPGGl+LtRtNeOpXUmkwXccUEc8 KRxAm5giJYm3
l4UEAAZPNfb90dtrMcZwhOPwr4g/4JIR+HNd+E3jbxXpHg/S/COo3evHTbqP SZ7uSKeOCFJI
iRczykMDcS8qQCCMjiv9LpnwtDqfd9FFFZnUFFFFABRRRQAUUUUAFfKf7fX3 fgB/2VbQ/wD2
tX1ZXyn+31934Af9lW0P/wBrU1uJ7M+oaKKK3PLCiiigAooooAKKKKACiiig AooooAKKKKAC
iiuU+IHxO0H4ZW2nTa5Je51G5+yWkGnadcX080uxpCqxQI7nCI7E4wApo2Gk 3sdXRWJ4X8X6
f4u0aLU7NL61tpGZVTVLCewmyDg5inRHA9CV56jNOtvGGkXnii+8OxXitrFj bQ3lxbbWGyKV
pFjbdjByYpOASRt5xkZdhdL/ANdjZopgnjKlhIpUdTuGKw9U8c6NpGu2+i3F 4BqtxZT6hDbB
STJDCUWRg2NowZYxgnJ3cdDiW7f18/yGk3ojforB8DeM7D4geD9G8R6cJIrL VbOK9hiuNolR
JFDKHAJAODzgke9biSJICVdWA6kHNVJOLae6EOopizRvna6tjrg5xWRrHjPR tA1HR7G+vkhu
tXuWs7JMFvNlWJ5SuQCF+SNzk4HGOpApBZs2qKo6brVrqtqbiEyxxiV4f9Jh eFiyMVOFcAkE
g4bGGGCCQQTbaaNSAZFBPQEigB9FFFABRRRQAhUMMEAj3rmfENvomk4leBob yXOxbEmOWQj/
AHSOPc8etdPXnMlw2oatqF3KcsJ3gT/ZRGK4H4gn8a/O+O+KJcJ5Q8bThzTk 1GKe13d6+iTZ
6GBw31mryt2SMm81rxJJdobW0YCI/u57udDIo9AVA4PcNn+RrpoPGesiFPN0 qzaTA3FbtgCf
p5Zx+ZqlRX8s1PGTieduX2cfSH+bZ9N/ZeG6p/eXpfHOpwRPI+lWgRAWJ+2t wB/2yrjIv2oP
C7x6E0mseHbOTXIIrrTbe91gW891HKcRskUkYc7jwBjOeOtbeq86Zd/9cX/k a+SdQ8WeHov2
XvDXht9a0a01298KWiXGhXUOdR1mBrcqltaHcG8x2LIrBJcMxGwmveyjxO4m zBPnmn70Y+7B
aJqWr0e1l2XdrdTPK8MldLv19PNfmj7RHjXVCMjSbTH/AF+t/wDGqP8AhNNV /wCgTaf+Brf/
ABqsbTjnT7bMbQ/ul/dseV46H6VYr5x+MHFKdueH/gC/zCOV4ZpOz+9miPG2 pKcvpEBX/pnd
kn9UFb+i+ILbW0byt0U8f+sglGHT/Ee4yK4+o1new1PT7uI7ZBcRwN/tI7BS D+YP1Ar7LhHx
azfG5tRwOaRjOFWSjeKs027L110ObFZXSjSc6ejR6PRRRX9enygUUUUAFQ3v /HnP/wBc2/lU
1Q3v/HnP/wBc2/lQB82f8EyP+TKfAP8A101H/wBOFxX1JXy3/wAEyP8Akynw D/101H/04XFf
Ulc56oUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABX5/f8FHf+Tn f2Q/+xrb/wBK
rCv0Br8/v+Cjv/Jzv7If/Y1t/wClVhTW4nsz72ooorc8sKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAK891W0OiazcRS/LBdSNNBIe hLcsn1zk+4Ps
a9CqG8soNQt3guYkmhcYZHGQa+J4v4Yo8WZZLAVZcrvzRl2kvL8H5HZhMS8L U50rnBda8L1j
4S+NG0HxH4E0+TRj4L167uZpNUnuJVvrOC5kaS4hWARlJDl5AjmRNodcqxT5 /pY+AtH7R3Kj
0W8mAH4b6P8AhAtH/uXf/gbN/wDF1+A4PwbzbBNunjKb1T1jJ2a+F+q+7o00 e+84pNfC/wAD
gtItdXs9avIZlsF8Px28CWHkhvtO8bhL5mfl248vbjn72e1eUeJvhD4q1LxH 4nisxpLaFrOv
6X4gW7nu5FuIntntBJCYhEVIKWzFX3/eYKVxlh9Kf8IFo/8Acu//AANm/wDi 6P8AhAtH/uXf
/gbN/wDF1eG8Hs3wlR1aeMp3aS+GXRpp773SfnqJZvSUeVRdvkfMvi/4P+Md R8Sa7DpR0Y6B
rHiHS/EE11d3Mq3MRtmtRJAsSxlTlbbcHLjltpX+Km+BP2fLzwl8TJNSuI1v tIg1W81iyvpf
EF+7xyXHmFk/s8n7MhUzyr5oJJX+AMxYfTn/AAgWj/3Lv/wNm/8Ai6P+EC0f +5d/+Bs3/wAX
Xf8A8Qrz5UHh446motWdozV9FG7s9fdVrbd0KWbUZbxf4ef+b/qxztGnWja3 q9vBFzDbSrPP
IOilSGVfqSAfoPpXRf8ACBaP3juSPRryYj/0OtqysbfTrdILaFIYV6IgwK6O GPB6eUZnSx+P
xKmqbUkopr3ltdvs9dDHEZsqlNwpxtfuLe/8ec//AFzb+VfC/wDwRl/5Nr8W /wDY33X/AKTW
tfdF7/x5z/8AXNv5V8L/APBGX/k2vxb/ANjfdf8ApNa1/S0zxqHU++aKKKzO sKKKKACiiigA
ooooAK+U/wBvr7vwA/7Ktof/ALWr6sr5T/b6+78AP+yraH/7WprcT2Z9Q0UU VueWFFFFABRV
e/v7fTLV7i5lEUKdWP8AL3PtXMS+OLuRybTSQ0XZrmfyyffAVsfjXz+a8QZV kij/AGjiI0+b
a71fy3N6WHq1v4cbnX0Vxv8Awmmq/wDQJtP/AANb/wCNUf8ACaar/wBAm0/8 DW/+NV87/wAR
B4W/6D4fe/8AI6PqGK/kZ2VFeQan+0doWhLqr6te6Jo8Ol3q6fdzalqZto47 holmWMPJGAxM
bq3BPfuDjotI+Jc+v6ZbajplrpuoafcxiWC6tdRMkUqEZDKwjIII7iuifHPD lKKnUxkUn1d7
bX3t219A+oYm9uQ72iuN/wCE01X/AKBNp/4Gt/8AGqP+E01QddJtce162f8A 0XXP/wARB4W/
6D4fe/8AIPqGK/kZ2VFYGjeLodRnW2uYWsbtvuo5DLJ/usOv0OD7Vv19lgMw wmZ0FicFVVSD
6p3RyVKc6UuWaswrwj9qW0vmufhvf2tz4i02Cw195rrU/DGlHUbu0jNlcoHE IgnyCzqhJjYD
f2OCPd6K9D0FGXLfzTX3qx8vX/gSy+LHi7whJrNlrnjnQbfw5rMcl34u0RrR 5Lg3FqYlmgaC
FA2FbYDGM+XuGSN1cDo3w61pFkv28L3cPxL1f4cWFrouv3GkSNNaanHBcrOs l1s/0aUq0S5k
ZC3AycYr7fopu3K4W3/+2/8AkvuVjRVWun9XT/TU+JPDnw01HUfhtf2trpjr pV5rXh8TaJpf
g278PRxPHfI11MYpZXkkcxlfMmXCbYl+ZtrY9L+K3wx8MaR8Xfh7fyeBYb3R rHRb3S7BtP0I
3cen3RltmtTiKNvIVds22Q7VTLcrnnsJoDd/tEa/e3N9qjQ6F4bsbq0sIdSn itPMklvVkZ4F
cRyErGgy6tjaCMEVwt9+2JcaV4V8I6lq2keGPDV54osjqmnweIPFIs7cWipG XMk5tyBKWlUJ
GqtuUFiyEFQTfMtd9/vjy/km1263S1tKcZWWun5pS/yv3fqcR4W+EHiXwp4I 8NxeCdBuPDfi
fU/hreQX94LdoJH1NVtRbrcSHBEq5mCbyCo3AYAOPRv2VPDd5oGn+IruG2is tPmgt1XR7Twh
ceG4EukV/Ncx3ErtLKwaNWlHyERphmIONS4/aVtPEHiDwhpGj22ltZeKNOtb +KTVta/s66uI
bgniyj8tvtEkags6h0K5TBO4V03wKsm0ceNtJW+1K+s9O1+SC1OqahPfTRxm 3gfb5szu5G52
OCxxmtG3KU1a2j/Ceq+Tlp6ffhUqaRTW7X4xum/lH8WuunzJ4T0Pxle+KPE1 94X8KxeBrrVf
COppNaaT4YudES31HzITBFLdSt5d3Mu+UJOiKv3yMg4HUeIPBfww1jQPhzqe k/CyZPDeka95
mtabN4LuBP8APYzJ5jW7Qb5wJDDukVXGVBJO3I9j/aRtYbjTfCsmsaVd694O h1YNrumWlg9/
58HkyiPzLdFZpY1mMLFVVsEKxGFJHhXwmb/hEtP8KeILDw3rA8NPH4r0uztN K0iZ2gebVFe2
jaFEzChSJgGcKi4AYrWUZcsb2+H9LyS76t8q36O7d0+nSWt7OV/xTV/VJfj5 k9x4VhttE0g+
OvCOpa/4QF94mK6OujzXzreTag72k5t0jdsGLzdku3avmA5G8GovEHwl13Vv D3iy98T6FPrn
jDTPh7pK6dePC1xImqxC8LNA3Ia4Rinzp8w3DGA3PMfEfQPElx8HPBekR+AR F4m0vwXZyafq
k/hG61PUxeqhJt4Z4in2CWJkVt0hO5pBtUlSG9G8R/DK5uLb4qeILvw1fXd7 P4hsBLJDZvJd
3Wk/Z7D7bFbj7zI6pKrrHy+wrhmAFbW5HJaaN6+krX/8md+yS7aty9671vrb 5qVvR7W6u99d
vorwL47svGE2uWFsk63Og3Uen3bTBQrym3imymCcjbMo5wcg8dCerrwv9lvQ NP0NviM+ieF5
/Cfh298QrcaZZTaU+mq0JsbVS6QMiFQXV+qg5DZGc17pUSS0fdJ/NpN/icVl H3V0CiiioAK8
0s/v3v8A1+3P/o569LrzSz+/e/8AX7c/+jnr+fPG3/knqH/X6P8A6RUPeyf+ NL0/VFiiiiv4
lPrw60wwRkgmNSR0JUcV5Vpuo+I1+PPjGy/t6+1HSLLQ7O+s9CeO2SFZpnuE YCQRCT/l3XG5
yAXfORtC73jnxjqXh74La14nvLGbSdWtNGlvprK3uI3ktpViLGNZSjoSpGAx RlOM7SOK9WeX
VY1adKMk3PktZ/zpNKzs+urSa8xLWfJ1/wCG/wA/6sd1RXiHxC1nxJ4Y8UeH 9QsvF+q41XUL
ONNGuNOhGkR27PFHMJbrydyykM7IDMpeQoqow+U+31licHLDU6dVyTU72tfS 297pel1db2ZE
ZqTsvJ/eFV7z79l/1+23/o5KsVVv3Ef2N24Vby3J/wC/yV7fCX/JQ5f/ANfq X/pcTPE/wZ+j
/I9NoryPTf2pPBGtadbahp1r4vv7C6jWa3urbwXq8kU0bDKujC1wykEEEcEG rP8Aw0j4U/6B
Xjb/AMIfWf8A5Fr/AEv54dz895Jdj1OivLP+GkfCn/QK8bf+EPrP/wAi0f8A DSPhT/oFeNv/
AAh9Z/8AkWjnh3Qckux6nUN7/wAec/8A1zb+VeZf8NI+FP8AoFeNv/CH1n/5 FqK5/aO8KyW0
qrpPjYsyED/ih9Z9P+vWjnh3Qckux59/wTI/5Mp8A/8AXTUf/ThcV9SV8Xfs LfEi2+Dn7L/h
Dwl4u8M+NtJ8QWD3pubT/hDdVm2eZeTSJ88dsynKOp4J646173/w0t4S/wCg V42/8IfWf/kW
sOaPc9I9Woryn/hpbwl/0CvG3/hD6z/8i0f8NLeEv+gV42/8IfWf/kWjmj3A 9Woryhv2mPCK
qSdL8bADkn/hB9Z/+Ra9C8K+J9N8a+GdJ8QaNcfa9I1W1ivbO42MnmwyKHRt rAMMqQcEAjuK
aaewGrRRRTAKKKKACiiigAooooAKKKKACiiigAr8/v8Ago7/AMnO/sh/9jW3 /pVYV+gNfn9/
wUd/5Od/ZD/7Gtv/AEqsKa3E9mfe1FFFbnlhRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAQ3v/Hn P/1zb+VfC/8A
wRl/5Nr8W/8AY33X/pNa190Xv/HnP/1zb+VfC/8AwRl/5Nr8W/8AY33X/pNa 1nM6qHU++aKK
KzOsKKKKACiiigAooooAK+U/2+vu/AD/ALKtof8A7Wr6sr5T/b6+78AP+yra H/7WprcT2Z9Q
0UUVueWFFFFAHE+LrhrrxDBaMf3FtAJ9vYuxZQT9Ap/OqVWfEf8AyN9x/wBe UH/octVq/wA/
/FatUqcWYqE5XUFBLyThGX5tn3WWpLCxt/WoUUUV+RHpnzdqHxO0D4Tat8Ut X1tbR7qfxXDa
6XFezJbxvctpdrgGaT5Yl2hyznooIAZiFb034B2+lWvw2s00nXtN8RxvcXFx cX2kTLJa/aJZ
nllSIqThFeQgDOQAM816C8Mcn3kVvqM05I1jGEUKPQDFe/i8yp4nDKjGm1L3 bvmunyx5Vpy6
dXvu3e+locW5c3r+ItFFFeAWQ3kH2i3ZQxRx8yOOqsOQR7g13eg3r6lolhdu AHngSVsepUGu
Jf7jfSus8Hf8ilo3/XnD/wCgCv6z8C6tSUMwpOXuxdNpdLvnu/wR8znSXuP1 Niiiiv6qPmAo
prSogJZ1UDqSaoXHiLSrQkTajaxH0eZR/WgLHDXXg/xJH8aNR1u3tdMuPC+s aLbaZeTSXskd
5bPC9y4McQhZZA3nqOZExgnB4B87/aC+A2j2H7Od5a6dqep6dceEvC15YWl9 CYWmuLT7Ntkt
5g8bIySeXGW2qrAqCpWvdj4t0w/6uaS4/wCveB5f/QQa5z4j2x+IPgDxH4at 7fULdtX0+exF
0bT/AFXmRlN+12TOM5xkZ9RSb0s/6tf/ADa/M66VRqtGctFdX+Vl+SPCfiz+ zL4T0fTvhnqu
j2qWcOhappVvYaKlraraqxukYuJDC00Rdjl/LdQ5GWVsnPuXwh8NeItBt/El 54nttNstS1jV
nv8A7Lpd493DEhiijA8x4oix/dk/cHXvXJat4N+JPiiw8JWWoX+kCDS72C91 DZpTQtdtDKJI
liP2uTyRhQG3CTPUbc4Hqfm6/L/y72Ft9Znl/wDZVq1Kyl5uX3Plf4uJwuMp OPN0S+9cy/Ji
+K/Bug+O9JbS/Emi2GvaYziQ2epWyXEJYdG2OCMjsavaVpNloWmWunabaQWG n2saw29rbRiO
KKNRhUVRwoAAAA4GKofYtcl+/qdrEPSG0OR+LOf5Uf2Fdyf67W71h/dRY0H6 Jn9ahabGnqzZ
prSogJZ1UDqSayP+EVtX/wBbcX05/wBu8kA/IMB+lOXwlo6kFtOt5WHRpUDk fic0BoTXHiLS
rQkTajaxH0eZR/WoD4t0w/6uaS4/694Hl/8AQQa0LfTrW0GIbaKED+4gFThQ OgAoDQx/+El8
z/UaZqE//bDy/wD0MrR/a2qS/wCq0WRP+vidF/8AQS1bNFAXXY4XVLnxBLqZ SxZIbw43wQzm
aNRjjfuQBeOcAgntmsjRhOLacXRRrn7VP5pjztLea2cZ7Zr1HFeaWf373/r9 uf8A0c9fz542
/wDJPUP+v0f/AEioe/k7vWl6fqixRRXOeOvHNl4C0mG7ure6v7m6uEtLLT7F A9xdztnbHGCQ
M4DEliFVVZmKqpI/iulSnWmqdNXbPrfMyIfhWIPiHr3i0eJdYM2r2EenSaf/ AKOtvDHHvMZj
IiEgZTJIQS55c5yAoXR1b4fWmufDW58F3+oahd2VzpraZNfTTB7uRDHsMjOQ QZCOSxHXnFUf
DHxa0rW7fWTqttc+Eb3RtrajY668Ub20bjKSM6O8ZRgDhlcjIYHBUgdJ4g8T 6P4T0eXVtb1S
z0jS4QDJe306wwpkgDLsQBkkD6kV6daePjWhCafOuXlsl0S5bNLXRqzV7pp6 6ERacudb/wBf
5HGar8GE13WIpdQ8V69d6El1Bef8I47wfYzLCVaM7vK8/aJEV9gl2kjBBUlT 6NXE+JfiadK0
7Tb/AEHw5qnjexvrdrpLrQJbVoViAUhzJNNGrBg2V2liQCeldF4V8TWHjPw1 pevaXI0unalb
R3du7oUZo3UMpKkAg4I4PNZ4pYudGFSt8K0W2j80tU3beSvK3Wwo8qdl/X9X /E1Ko6z/AMe0
P/XzB/6NWr1U9UjMsVsg6td26j/v6tevwl/yUOX/APX6l/6XEzxP8Gfo/wAj zb9l/wCJGo6L
+xX8PtZktTrWpiyttMs7XesCyOZhbwKz4wqD5NzYY4BOGbg9lp3xv8U63dy+ HNO8JaVJ46s7
qaHULC41qSPT4UjSGTel0LYu5ZbmDC+SOS4JG0FvHfA/wB8a/Cb4X2/h+bwH omv29vpsdnco
fiLqxgmkXaxnhtmtDHbyGRBIrR7WQ/dYdawpta8VjRbXSV+C3kraXElyl/bf EPU4r95H4cve
LbieQMAoIZyMIgxhVx/ovUw8pTnJR3em2n9a+vla58jGpT5Ur9/6/q1t7vY+ g/CMnivx9dXn
iybxpeaHp9hqdxaL4csLW1ktWitpmikE7vG0zO5RzlHjwCg2ZVi2MP2lNegX T/tfgu2hk16G
G78Pwx6vve4ge5hhJuf3IWB1+0wsVQyggsA2VGfG5fFPi6XxONeX4Jx2980s dxNFa+PdQhtb
mVAoWWe3S1EUz4VAXkRidi5J2jEeh6/4l8O3U09l8CLFS8kUkcc3ja+litRH KJUS3je1KwRh
wp8uIKh2qCCFAErDy5lzR0+X53/P9bodSHvNb9P6/wCBd90e0Q/tI+JFit1u /AsEF3dyG2tI
o9YDq86XyWc4djENsYeRXRwCzoDuSNsKaviP9qDXfDenahZ3HhLT5PGOmai1 leaJa395eK8Q
gjm8+BraxlldAs0QYvDGqs2C3KlvGvHHiPx34x0aGwj+DdnpZjufP+02njG8 jlCtdx3Myo6W
qshd4x8ykFf4cDikl1nxOmmWtv8A8KTCG0kknN2nxC1Nbu4L7d4nuBbeZOpC ICsrMuEUYwoA
Sw0uX4NdfzVuva6/q41Ugnq/6/rXp69D3LUfjt4o8V/Dnxnr/hbw/bWNtpmm +daX2oX+2V53
toZ0/dCJwAqzMCWP3kA2kMWWr/w05r9l45g8NXXgO5uDbSQWmq3mmJf3cUFx JGj5ilWy8lol
EibnllhYYc7MBd/h/wAHf2jNf+I3wfM/hn4D6YPCOvRSW8lpdeKZ28xI1+yl T/obYG2ELweg
z1JrRtNa8YWGrWupW3wblt7uBI0do/iNqirdbF2q1yv2fFywUBd0wdiqqCSA AB4d8ztDT+vP
+vzcXaHvb/8ADf8AB/rb2jRP2kPEV69jPqPgaCw0yZdOuZZ49XEskdvekpCQ nlDdIsikOmQo
XDK7nKDK8M/tb6v4mjmmh+HepR21y1t/Zk08V5bJKs1xHCBNLPaRxK4Eqvth kmBCvhsAFuFi
+InjeCCKFPgTpQiiitIUX/hLbo4S1cvbj/jz/hYk+/fNZWieIPF/h6eRrH4K IlsZY5o9Pk8f
6jJZW7RyCVPJtmtjFCFZRhY1UADbjbxTWH953g7X79NPPff+tjmXK++n63/T /gdfZtW+LHj+
+vtA0+38PaPYamuvTaVrFmdYd7doxZtOrQzfZdzfKytgpGdybc7TurU/Y28Y W/ib9nb4fQQq
Vax0Cxtnz/eS3QH+VeLa/wDEDx14j8x7r4IWCXDX66oLi28ZXkEqXKxCIOrp ZhlzGNhUEKyl
gQQxz6l+xZ4G1b4ffCfStG1iERXlpaxQSbc7SyoFJGQDjI9K6cNTcFqrbflr +N/60UPfR/1d
/pb+tX9DUUUV2CCiiigAooooAKKKKACiiigAooooAK/P7/go7/yc7+yH/wBj W3/pVYV+gNfn
9/wUd/5Od/ZD/wCxrb/0qsKa3E9mfe1FFFbnlhRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAQ3v/ AB5z/wDXNv5V
8L/8EZf+Ta/Fv/Y33X/pNa190Xv/AB5z/wDXNv5V8L/8EZf+Ta/Fv/Y33X/p Na1nM6qHU++a
KKKzOsKKKKACiiigAooooAK+U/2+vu/AD/sq2h/+1q+rK+U/2+vu/AD/ALKt of8A7WprcT2Z
9Q0UUVueWFFFFAHC+I/+RvuP+vKD/wBDlqtVnxH/AMjfcf8AXlB/6HLVav8A PnxT/wCSvxv/
AG5/6bgfd5d/usPn+YV5d8XL3XbTxt8NINJ8SX2i2epay9nfW1rDbutzELWa cBjLE7L80AXK
lflZu+0r6jXGeOvhoPHHiDwtqreINU0h/D94b6C3sBbmOeQo0Z8zzInbGx5F wpXhyeoUj87y
6pSpYjmrWtaS1XMruLS0s+tumm56EtYyXkzd0PUdTvrjVU1HSv7NitroxWkv nrL9rh2KRLgf
c+Ysu08/JnuK8g1DxPqPiP4dah4nk8eat4JstJv9VtZHt4bO4kuHivHhhX95 bsCMptSNF3sX
VSzty3sGh+H/AOxLjVZf7Qvr7+0Lo3Wy8m8xbfKKvlxDHyx/LnbzyzHvXm+r /s5WN9/ZBsPF
ev6L/Zmo3uqQrbC0lQ3FzM0rOyTwSLuQu6owAZVZhk7iT6OAq4KFVuq1HWLT 5eZWUZcys1Ld
2V7Oz1S0sGqj31/DX/gedu7O/wDAN7rGpeCNBu/EFstnrs9jDJfW6DAjnKAu oHOMNmt6qOh6
dPpOk21pc6lc6vPEm1768WNZZj/eYRoiA/7qge1Xq8GvJSqylG1m3ttv0vrb tcUE1FJiP9xv
pWv4Ws9Xm8M6SU1KCGE2kWxUtSWA2DqS5BP4Csh/uN9K6zwd/wAilo3/AF5w /wDoAr+qPAn/
AJmX/cL/ANyHzuc6Kn8/0E/sK7k/12t3rD+6ixoP0TP60f8ACK2r/wCtuL6c /wC3eSAfkGA/
Stmiv6usfMXZkL4S0dSC2nW8rDo0qByPxOav2+nWtoMQ20UIH9xAKsUUxXZw Xir42+D/AAP8
Q9D8Ga5q9rper6zayXVn9quIokfbIkYjG5gxd2k+RQDu2P6VraD8UPB/iq6a 10bxTo2rXKxm
ZobG/imcIFRi2FYnAWSM56YkQ/xDPD/FDw5rn/C2PCviPTPD9xr9iuk6ho11 9klgR7RriS2Z
JmEsibox5L7tm5umFNef6B8NPF3w60D4U3Nj4Pl1W70vwjceH9R06xubaJrW 5mFs3muzyKrR
hoXDlC7ZYEK+TSv+75nur/f71vyiv+3vI35IO1n/AF1/r/M94vvih4P0z+wv tfinRrX+3io0
nzr+Jf7QLbdogy373O9cbc53D1FdP1r4wX9n/wCIFrpvha0n/wCElhtL/wAG af4c1Gz8OXWl
qLGaEOJRPJdI7CM+d9+23ONjHa3yV9l28ZhgjQksVULknJPFayilez6tfJPQ ymkmktdP6/y+
XnorypFje6pnpuOKHmjjxudVz0ycZr58/a0spNdh0LSJPB2m67aXEdyy6rqX hafxALSYBFSF
IICrRNJuJ89nVF8rB5YEcf4E0Yf2l8Pbz4seFNV8RSN4V0qLS5bvQrjUhpup KT9qMqrG5tpS
Tbkyvt4jPzDYayj7yfrb8H+Om3mn1V6cLR5vK/4pfrd9rPzPp7wv4u0nxnp8 t9o92Ly2iuZ7
R3CsuJYZWilXDAHh0YZ6HGRkYNbFeE/ss+ENF8D2njDSrbwofD2vJrl9Je3I 0d7VLyB7ud7U
pOUCTqImGNrNsBwducV7tVO2lvImaUZyitk2vxCiiikSFFFFABXnd1bNpes3 trLwJZXuIWPR
1Y5OPoxIP4eteiVS1XR7TWbfyrqIPg5RwcMh9VPUGvgeNeFo8W5U8Dz8s01K L6XV1r8m0d2D
xP1Wrz2ujia8++Lnh3V9Qbwvr2h2Q1W/8Oap/aH9measbXcTQSwyIjPhRIFm LLuIBK7Syhiw
9b/4QJO2r6go7D90f5x0n/CBL/0GdQ/KH/43X82Ybwa4jw1VVYVqL30cp6pq zTtDqm1o79mf
RvN8O01Z6/13Pnyz0HxDrWo+OvGep+CPNk1LTbbTLLwlqd1bmS5jgaVyZ2Vp IV3tOwA3MAqg
nBYqOk+LWh6tex+EtX0vSptbOhamL6fRbaSNJLlDBLFhDI6JuRpVcBmA+Q45 xXr/APwgS/8A
QZ1D8of/AI3R/wAIEv8A0GdQ/KH/AON16EvCbiV1o1vaUFy6W5qtrcqjb4ey 3T5tb32tH9q4
fW99fJen5HzNb+H/ABFoXwxi0DUPA+v61Fqt1fajJaeH9Ygs5tOM1y80dtI5 uIsqFkCt5bup
KsMFcZ9c+Gukar4f+H/h3TNce1k1e0sIYLprFAkHmKgDbFCqAuRxhVHoB0He /wDCBL/0GdQ/
KH/43R/wgS/9BnUPyh/+N1OL8JeJcZBwlUoK8nJ2lU3d+8Wlv0SvZXu0JZph 0+bX7l/X6GNT
YLZ9T1aytIeSkyXEp7IiMG5+pAA/H0Nbn/CBJ31jUCO4/dD+Udbek6NaaLAY 7aPbuOXkY5dz
6sepr1uFfCDMMszWjjszrQcaTUkoNttrVbxjaz16mOJzWnOk4U07vuXWUMME ZHoai+xQf88k
/KpqK/q0+YIfsUH/ADxT8qPsUH/PFPyqaigCH7FB/wA8U/Kob2yg+xz/ALpP 9W3b2q5UN7/x
5z/9c2/lQB8z/wDBMu1hk/Yr8As0asxk1Hkj/p/uK+ovsUH/ADxT8q+Yv+CZ H/JlPgH/AK6a
j/6cLivqSuc9Ug+xQf8APFPyo+xQf88U/Kp6KAIPsUH/ADxT8qkjiSIYRQo9 hT6KACiiigAo
oooAKKKKACiiigAooooAKKKKACvz+/4KO/8AJzv7If8A2Nbf+lVhX6A1+f3/ AAUd/wCTnf2Q
/wDsa2/9KrCmtxPZn3tRRRW55YUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUVSvta0/TCBd3tvakjIE0qr/M1Lko/E7Ak3sXaKx/+Ex0H/oM2H/gSn+N H/CY6D/0GbD/
AMCU/wAaOaPcfK+xsUVj/wDCY6D/ANBmw/8AAlP8aP8AhMdB/wCgzYf+BKf4 0c0e4cr7GxRW
P/wmOg/9Bmw/8CU/xpf+Ew0I/wDMZsP/AAJT/Gjmj3DlfY16KgtL+21CPzLa 4iuE6bonDD9K
npqSkrp3FsFFFFMAooooAKKKKAIb3/jzn/65t/Kvhf8A4Iy/8m1+Lf8Asb7r /wBJrWvui9/4
85/+ubfyr4X/AOCMv/Jtfi3/ALG+6/8ASa1rOZ1UOp980UUVmdYUUUUAFFFF ABRRRQAV8p/t
9fd+AH/ZVtD/APa1fVlfKf7fX3fgB/2VbQ//AGtTW4nsz6hooorc8sKKKKAO F8R/8jfcf9eU
H/octVqv+MbZrTWYNQP/AB7zRC3duyMGJXP13MPrj1qhX8A+K+Gq0eK8TVqR tGag4vulCMfz
TPuctknhopdP8ypq+rWmg6Vealfzpa2NnC8888hwscaglmJ9AATXC+FfjVa+ Itb07Tr3w5rn
hoatG8uk3OsQxJHqCqu4hAkjPG2z5/LmWN8Z+XKsF6D4l+En8efD3xJ4cjnF rJqunz2aTMNw
RnQqGI7gE8jvXndnYeMPiD4p8DtrXhKfwra+F53vru5nvIJo7yf7PJAqW3lO WMf712LSrGcB
RsyzBfz/AAOHwtXDTnWa5lzbySatG8bK/vc0tHo7LtdM9Co2rW8/0t9+v9LX 13T9ZsNWsjeW
N7b3loGdDPBIHTcjFXG4HGVYEEdiCO1c0Pipomr+GLzWvCcqePEtp1tjbeG7 mC4dpSVBTcZF
RSAwY7mXC8+lZWqeFtR8V/BvxJoFto9v4M1HUbe/tobWCRWjjZ2kCylowB+8 yJDjkbznkE1w
1hH490ZfFvi/RvANzY6rNpmn6TY+HLi6tN0kkTy+ZdEpP5ZRVnG1TIjOIiDs ypGuGwGGqKbc
1zRkklKUUnqlq76p3fvRdoqLbdmmHM7Lz9f68/lZas9W+H/xAg8fWeosNNvt F1DTbo2V9pmo
iPz7eUIrgMY3dCCjowKsRhh0OQOprzj4H6deaX4dvI9S0HW9J1We5NzfXuvS WjT6hO4G6XFt
NIqqMBQvyhVVVAwK9Hry8wp0qWKnCj8KfR3Xyd3pfbW9t9bhBtq78/z0Ef7j fSus8Hf8ilo3
/XnD/wCgCuNvJmji2RrvnkOyKMdWY9B/ntXfaLYnTNIsrMncbeFIifXCgf0r +pfAuhVhSx9e
UXySdNJ9G489/wD0pHzmdSXuR66lyiiiv6oPmQooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACob3/jzn/wCubfyqaob3 /jzn/wCubfyo
A+bP+CZH/JlPgH/rpqP/AKcLivqSvlv/AIJkf8mU+Af+umo/+nC4r6krnPVC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAK/P7/go7/yc7+yH/2Nbf8ApVYV+gNf n9/wUd/5Od/Z
D/7Gtv8A0qsKa3E9mfe1FFFbnlhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FAHl37SfjzU/h98HfFOqaHOLbXINMuZ7Scor+S0cZbftYEHGBwQRkjPFcd4w 8Xz+EdL0BNN0
yHWvEuu3C2tpFe3JgSWTymld5ZgkjKoSNzkK3OABzx2vxq8J2njzTpPDl/JN DZarpl7ZzSW5
AkVH8tSVJBAOCcZB+ledSfBO6vNNit9Q8f8AiTUry0njudN1GaKwSfTpFV0L RbLVUbejsjCR
XGDwAea/kTxXzdVM3hl+Iq2p01fl960uZKzfLuk99U7fDqfX5ZTiqCnFavm/ Sxm2fxu1PxFb
6Fp/h/w1Z3fiu9a9W70++1Fre1s/scohuSZ1hdm/esqp+7BYNuO3BFN8f/Hh /hx450PRNVg8
NCDU57W2WBNexqm+dxErpZtCPMjEhwWEgO0M2ONtazfAjT7XTNCi0jX9Y0LV 9JNwy63Zm3a6
uDcNvufNEsTxt5kmJGAQAMo27QMVV1v9njTNd8Q3GpzeItbhhu9QstVu9PhN uIbm6tjCY5WY
wmQZEEYKq4Tg4UE5r8Rp1Ml9tea/d+9p7/Nfm01vayjt5pqXRnrtT5Xbfpt+ Pn+H5HF+Afi/
4xuG0VvFNtaRWl74r1PS4LqwvVdnig+3HZNG1suEQW6KpR9z4DMR8yNqN+0l eWPh2/1vUfC0
FvYz+H7rxHoQi1AvJfW0AUss4MK+RIVliIUGQYZufl56vTvgRpena7Df/wBs 6rPZ22rz63a6
VKYPs1tcTJOswUiISFXNzIxDOcELjAyDQh/Zs0IaXq2m3Os6xe6fdaVPoljb zPABpNlLjfFb
FYgcfLGAZTIQI1Geueqpi8jq1nOcLR00XMvtSdlrvZxvfSyko9DSz579L/8A tz/T59rHGfEn
4x+NZfC2u6Rp9pZ+DfGEU+jNZXUUy6hELe+vBApkVo1AcbJAyDcBkbXPUdX8 IPipf/EXx5rN
rcYtra00Swkm0xlUtZ3xnvIrpCwGSQ0AXk4+TI6nPR6/8FdE8R6xcalc3N8k 866YrLE6BQLG
5a4hxlT1dyG9RjG081Xh+BGiWPxD1rxlp2oarpep6xNZzX0NncBIJzbrIqhl 252uJPnGcNsU
8HJOEsblM8HOhGHLNq6aTdm/Z3V227aSa1dtUtJMz5Zpb3dl+jf+XpuegC3a zm+1WJFrdr0d
BgP/ALLDuP8AIrvdE1RNZ0uC8RSnmD5kPVWBww/AgivIvDHgT/hGby3uP7f1 rVPJtDaeXqN3
5qP+8L+awwMyc7d390Adq9K8Bf8AIuJ/18XH/o56/fvBjNMTVr4vL5VnUpRi pRvfR3tpfZW6
HgZvTioxnazv+h0NFFFf1QfMBRRRQAUUUUAQ3v8Ax5z/APXNv5V8L/8ABGX/ AJNr8W/9jfdf
+k1rX3Re/wDHnP8A9c2/lXwv/wAEZf8Ak2vxb/2N91/6TWtZzOqh1Pvmiiis zrCiiigAoooo
AKKKKACvlP8Ab6+78AP+yraH/wC1q+rK+U/2+vu/AD/sq2h/+1qa3E9mfUNF FFbnlhRRRQBH
cW0V3A8M8ayxOMMjjII9xXNv4Btw58jUb62j7RIyMF+hZSf1rqKK8rHZTl+a JLHUIVUtuaKl
b70zWnVqUvgk0cr/AMIEv/QZ1D8of/jdH/CBL/0GdQ/KH/43XVUV5H+qXDv/ AEL6P/gqH/yJ
t9bxH/Px/ecr/wAIEv8A0GdQ/KH/AON0f8IEv/QZ1D8of/jddVRR/qlw7/0L 6P8A4Kh/8iH1
vEf8/H95yv8AwgS/9BnUPyh/+N0f8IEv/QZ1D8of/jddVRR/qjw7/wBC+j/4 Kh/kH1vEf8/H
95j6P4Ws9HlMwMl1ckY8+4IZgPQYAA/ACtiiivocLhMPgqSoYWmoQWySSX3I 5pzlN80ndhRR
RXWSFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAVDe/8ec//AFzb+VTVDe/8ec//AFzb+VAHzZ/wTI/5Mp8A/wDXTUf/ AE4XFfUlfLf/
AATI/wCTKfAP/XTUf/ThcV9SVznqhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
fn9/wUd/5Od/ZD/7Gtv/AEqsK/QGvz+/4KO/8nO/sh/9jW3/AKVWFNbiezPv aiiitzywoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDjfGn/If0n/r3uP8A 0KKs6tHxp/yH
9J/697j/ANCirOr+DvGH/kqp/wCCH5H22Vf7qvVnNfEnxzF8NfBGreJ7jTL3 VrXTITcz22n+
X53lry7DzHRTtGSRuyQOATgG5ovim11aLTo51/svVby1+2DSbuWI3UcfAYlU ZgdpZQSpK5I5
5Fcz8ftM1bXfg14v0nQ9Jn1vVdR06ayt7O3kijZnkUoCWldFCjOTznAOATgG 7oLXt1rmhXNz
4Q+wsdIYS6ndSwm5s5N0f+iEIWyGwWJRymYx1yDX5ZChRlgVUdufmn9pXsox a0b2u3ra72Wu
h6k201b+tV/m/wA9inf/ABz8F6P8QdR8G6nr1jpWsWNjHqDrfXUUSvGwkZtu 5skokRd+MKrK
c4PG5Y/EfwpqdtqNzaeJdJubfTozLeyxXsbLbICylpCDhADHICTjlGHY15D8 Z/AnibVvEHj9
dI8OT6zB4p8IrpNvdwTW8aW1zF9rIWUSSK2H89ApUMAc7to5rP8Aiz8PPFcI 8ZWnhrwpJrEP
iTwdBodubW4t7eKynh+08SCR1IVhOoUorcqQ20c17cMry2vGly1uWUlG95xt f3OZu9uXeVk3
9nS90N6S8tP/AG3/ADf3Hul1468OWXiOx8P3GvabBrt9GZrXTJLpFuZ0AJLJ GTuYYVuQP4T6
Gtyvmy5+EXiwfFi+kmuPEc2gapqOnaor6bPpyWUBt0hBiuDKhuhhoMgQkqwc AlMu1fSdeHmO
Ew+FVJ0KqnzRTdnezstPJrVW12vfWyiEnLdWCui8Bf8AItp/18XH/o5652ui 8Bf8i2n/AF8X
H/o56/oDwN/5GWN/wR/9KPDzn+FD1Ohooor+xT5MKKKKACiiigCG9/485/8A rm38q+F/+CMv
/Jtfi3/sb7r/ANJrWvui9/485/8Arm38q+F/+CMv/Jtfi3/sb7r/ANJrWs5n VQ6n3zRRRWZ1
hRRRQAUUUUAFFFFABXyn+31934Af9lW0P/2tX1ZXyn+31934Af8AZVtD/wDa 1NbiezPqGiii
tzywooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAqG9/485/+ubfyqao b3/jzn/65t/K
gD5s/wCCZH/JlPgH/rpqP/pwuK+pK+W/+CZH/JlPgH/rpqP/AKcLivqSuc9U KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAr8/v+Cjv/ACc7+yH/ANjW3/pVYV+g Nfn9/wAFHf8A
k539kP8A7Gtv/SqwprcT2Z97UUUVueWFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAcb40/5D+k/wDXvcf+hRVnVpeNlKazpEpHyGOeLP8AtHYwH5KfyrNr +EPGFNcUzb6w
h+TPtsq/3ZerEd1jGWYKPUnFCsGGVII9RXkHxY0zTPE/xX8C+HvFEMF54Vu7 S/mFhe4a1vL6
PyTEkiH5ZCsZuHVGBHyF8ZjBGL8NHOm2vivS9F8RW/h3wxpvi6Kz0qSQJJC0 O2AzWMO8gKpm
aaJQp+Q5VR8oFfmEMqU8NGsp2k0pWadrOThurtu6vbl2vroenOfJ0/qzf6d/ yZ70SBjJAzRX
i/7Qmj3mr+KfhRHaa/f+HSfEMqfa7BIGZSbC6IP76ORc8FeRjDtxnaRzPhTx z4wbVvC2o3/i
q4u7DVfGOqaJLYva26QJbQfb/KG4R795MMXzbuQgGMli2lLJZV8LHEwqx1Td nzX059NE07qD
e67PzqT5enS//pX/AMifR1FfKd38aPGniCDQNN0ubWbw6lqWvkal4bXTRcGO 0vTFBCpvCISv
ltkkAufLBH8Zr6P8BarqOu+CdC1HV7eK01W6soZrqCCVZY45WQFlV1JVgCTg gkHsT1rDMMnr
5dTjUrSi7tqyeujau1vZuLt+Nhcy5nDsbtdF4C/5FtP+vi4/9HPXO10fgMEe GoWxgPNO6+4M
rkH8jX774Gp/2jjX/cj/AOlHg5z/AAoep0FFFFf2IfJhRRRQAUUUUAQ3v/Hn P/1zb+VfC/8A
KzOsKKKKACiiigAooooAK+U/2+vu/AD/ALKtof8A7Wr6srzT4+/ALw/+0R4P s9B1681TSn0/
UIdV0/VNEuvs15Y3UWdksT4IDAMw5BxuyMMFYAnqj0Civl7/AIYFX/ov/wAb P/Ct/wDtVH/D
Aq/9F/8AjZ/4Vv8A9qrXnRyewfc+oaK+Xv8AhgVf+i//ABs/8K3/AO1Uf8MC r/0X/wCNn/hW
/wD2qjnQewfc+oaK+Xv+GBV/6L/8bP8Awrf/ALVR/wAMCr/0X/42f+Fb/wDa qOdB7B9z6hor
5e/4YFX/AKL/APGz/wAK3/7VR/wwKv8A0X/42f8AhW//AGqjnQewfc+oaK+X v+GBV/6L/wDG
z/wrf/tVH/DAq/8ARf8A42f+Fb/9qo50HsH3PqGivl7/AIYFX/ov/wAbP/Ct /wDtVH/DAq/9
F/8AjZ/4Vv8A9qo50HsH3PqGivl7/hgVf+i//Gz/AMK3/wC1Uf8ADAq/9F/+ Nn/hW/8A2qjn
Qewfc+oaK+Xv+GBV/wCi/wDxs/8ACt/+1Uf8MCr/ANF/+Nn/AIVv/wBqo50H sH3PqGivl7/h
gVf+i/8Axs/8K3/7VR/wwKv/AEX/AONn/hW//aqOdB7B9z6hor5e/wCGBV/6 L/8AGz/wrf8A
7VR/wwKv/Rf/AI2f+Fb/APaqOdB7B9z6hor5e/4YFX/ov/xs/wDCt/8AtVH/ AAwKv/Rf/jZ/
4Vv/ANqo50HsH3PqGivl7/hgVf8Aov8A8bP/AArf/tVH/DAq/wDRf/jZ/wCF b/8AaqOdB7B9
z6hor5e/4YFX/ov/AMbP/Ct/+1Uf8MCr/wBF/wDjZ/4Vv/2qjnQewfc+oaK+ Xv8AhgVf+i//
ABs/8K3/AO1Uf8MCr/0X/wCNn/hW/wD2qjnQewfc+oaK+Xv+GBV/6L/8bP8A wrf/ALVR/wAM
Cr/0X/42f+Fb/wDaqOdB7B9z6hor5e/4YFX/AKL/APGz/wAK3/7VR/wwKv8A 0X/42f8AhW//
AGqjnQewfc+oaK+Xv+GBV/6L/wDGz/wrf/tVH/DAq/8ARf8A42f+Fb/9qo50 HsH3PqGivl7/
AIYFX/ov/wAbP/Ct/wDtVH/DAq/9F/8AjZ/4Vv8A9qo50HsH3PqGivl7/hgV f+i//Gz/AMK3
/wC1Uf8ADAq/9F/+Nn/hW/8A2qjnQewfc+oaK+Xv+GBV/wCi/wDxs/8ACt/+ 1Uf8MCr/ANF/
+Nn/AIVv/wBqo50HsH3PqGivl7/hgVf+i/8Axs/8K3/7VR/wwKv/AEX/AONn /hW//aqOdB7B
9z6hor5e/wCGBV/6L/8AGz/wrf8A7VR/wwKv/Rf/AI2f+Fb/APaqOdB7B9z6 hqG9/wCPOf8A
65t/KvmT/hgVf+i//Gz/AMK3/wC1UN+wGrKQfj/8bCDwR/wlv/2qjnQewfcs f8EyP+TKfAP/
AF01H/04XFfUlcV8GvhHoHwJ+Gmh+BvDCTpo2kxNHE11L5ksjM5eSR2/vM7M xwAoLYUAAAdr
WR2BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFfn9/wUd/5Od/Z D/7Gtv8A0qsK
/QGvhL9sh/Gmu/thfBLTbP4Sf8Jp4W0m5sr5fE32LUH/ALJnlvQJ282CVYRs SCF8SqwXqQVO
KBPVH3FRXwTL8XP2/RK4T4K+CSgJwftcfT/wPpv/AAt39v8A/wCiKeCf/AuP /wCT625kcPsZ
n3xRXwP/AMLd/b//AOiKeCf/AALj/wDk+j/hbv7f/wD0RTwT/wCBcf8A8n0c yD2Mz74or4H/
AOFu/t//APRFPBP/AIFx/wDyfR/wt39v/wD6Ip4J/wDAuP8A+T6OZB7GZ98U V8D/APC3f2//
APoingn/AMC4/wD5Po/4W7+3/wD9EU8E/wDgXH/8n0cyD2Mz74or4H/4W7+3 /wD9EU8E/wDg
XH/8n0f8Ld/b/wD+iKeCf/AuP/5Po5kHsZn3xRXwP/wt39v/AP6Ip4J/8C4/ /k+j/hbv7f8A
/wBEU8E/+Bcf/wAn0cyD2Mz74or4H/4W7+3/AP8ARFPBP/gXH/8AJ9H/AAt3 9v8A/wCiKeCf
/AuP/wCT6OZB7GZ98UV8D/8AC3f2/wD/AKIp4J/8C4//AJPo/wCFu/t//wDR FPBP/gXH/wDJ
9HMg9jM++KK+B/8Ahbv7f/8A0RTwT/4Fx/8AyfTovi5+36ZUD/BXwSEJGT9r j6f+B9HMg9jM
+9qK+G4P2kP2qte+I3xY8N6J8I7IwaGLj/hGLzUdMubWDUil/DEu64lmSJ82 zTSDaV3FARx8
py/+Fu/t/wD/AERTwT/4Fx//ACfS5kP2Mj7q1nSItasWtpSUOQySL95GHRhX HTaPrVnIYzp5
vgOk1s6KGHursCD7c/Wvkb/hbv7f/wD0RTwT/wCBcf8A8n0f8Ld/b/8A+iKe Cf8AwLj/APk+
vh+I+Dsm4pcJZjTblHZp2du1+x24etiMNdU3ofUHiXwOnjPSn0zX/Bqa3p0h DPaagltPExBy
CVZyCQeRTYPAUNro9jpMPgqKLS7Fo3tbJI7YQ27IcxlE34UqQCCBwRxXzD/w t39v/wD6Ip4J
/wDAuP8A+T6P+Fu/t/8A/RFPBP8A4Fx//J9fILwn4ajFQXtLJ3t7R2v39Tqe PxT3S+4+oPE3
gaPxpph03xB4Mj1vTy4c2mopbTxFhyDtZyMiquo/DHT9Y0GTQ7/wDa3ujSym d9PuILV4HkLl
y5jLbSxclicZJJPWvmn/AIW7+3//ANEU8E/+Bcf/AMn0f8Ld/b//AOiKeCf/ AALj/wDk+qh4
UcN00ow9qkndWqPR915+Y/7Qxb7fcfR2o/CLRtY0CLQ7/wCHNje6LFOblNOu LW0e3WUliZBG
W2hiWYk4zlj6muli03VYI0jj0G5jjQBVVZIAAPT/AFlfJn/C3f2//wDoingn /wAC4/8A5Po/
4W7+3/8A9EU8E/8AgXH/APJ9TPwm4ZqLln7RrV61Hu938+ofX8X5fcfXtp4a 1LVn2XcJ020/
j3OrSuPQbSQv1z/iO4ghS2hSKJQkaKFVVGAAOgr4K/4W7+3/AP8ARFPBP/gX H/8AJ9H/AAt3
9v8A/wCiKeCf/AuP/wCT6+84e4ZyrhihKhltPlUtW27t+rOHETr4l3qM++KK +B/+Fu/t/wD/
AERTwT/4Fx//ACfR/wALd/b/AP8Aoingn/wLj/8Ak+vrOZHJ7GZ98UV8D/8A C3f2/wD/AKIp
4J/8C4//AJPo/wCFu/t//wDRFPBP/gXH/wDJ9HMg9jM++KK+B/8Ahbv7f/8A 0RTwT/4Fx/8A
yfR/wt39v/8A6Ip4J/8AAuP/AOT6OZB7GZ95Xv8Ax5z/APXNv5V8L/8ABGX/ AJNr8W/9jfdf
+k1rWj4H+KH7b+peM9CtPFnwg8Iad4XnvoY9Vu7a6jMsFqXAmdAL1ssE3EfK 3I6HpT/+CXb+
MdJ0D4geHvEHwm/4VVo9tfQX1jB9i1CD7ZNKrpM+68lkZsLDAMKQBnkfNUSd zopQcL3PuWii
ioNwooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
A//Z
--------------010902020401020203010406--
Re: Change lable name on creation [message #125349 is a reply to message #125256] Thu, 10 May 2007 07:57 Go to previous messageGo to next message
How could it be that first you say that there is only one label and
later you say that there are two labels?
Dmitry wrote:
> Hi dmitry,
> it saves in xml.
> So, I wonder!
Re: Change lable name on creation [message #125478 is a reply to message #125349] Thu, 10 May 2007 08:51 Go to previous messageGo to next message
--------------060504010208040405050406
It's only one label! That is actually is a problem. It seems like there
are two, but there is only one which has 2 features (as I described) but
it as seem from the screen shot makes 3 wisible text parts!
I attach a map definition screen shot hier to show the situation more
exeactly.
name="mapdef.jpg"
filename="mapdef.jpg"
CAIaA3kDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD9AKCcVhwJJoOp2tojyS2F 1uSPzXLtFIFz
tBJJIIDHnptPPIAZFAfEk9zJd7v7PhlaGK3ViFlKnDM+Oo3ArtPHBJzkY1A3 d6/3h+dG9f7w
/OsMeHbE6Z/aA8Kxm08rz/M8u3+5jOcbs9O2M1JaaBoF9bxzwabYyROMqwgX /Cs41YTfKnqU
4tK5sb1/vD86N6/3h+dZn/CKaL/0CbL/AMB1/wAKP+EU0X/oE2X/AIDr/hWh Jp71/vD86N6/
3h+dZn/CKaL/ANAmy/8AAdf8KP8AhFNF/wCgTZf+A6/4UAae9f7w/Ojev94f nWZ/wimi/wDQ
Jsv/AAHX/Cj/AIRTRf8AoE2X/gOv+FAGnvX+8Pzo3r/eH51mf8Ipov8A0CbL /wAB1/wpG8L6
Igy2l2Kj1MCD+lAGpvX+8Pzo3r/eH51mDwropGRpNkR/1wX/AAo/4RTRf+gT Zf8AgOv+FAGn
vX+8Pzo3r/eH51mf8Ipov/QJsv8AwHX/AAoPhbRR10qyH/bBP8KANPev94fn RvX+8PzrM/4R
TRf+gTZf+A6/4Uf8Ipov/QJsv/Adf8KANPev94fnRvX+8PzrM/4RTRf+gTZf +A6/4Uf8Ipov
/QJsv/Adf8KANPev94fnRvX+8PzrM/4RTRf+gTZf+A6/4Uf8Ipov/QJsv/Ad f8KANPev94fn
RvX+8PzrM/4RTRf+gTZf+A6/4VB4e8A6P401+7t3063h0nTyqzGCMRvNKRnY WGGUAYPHXPXg
gmwG1vX+8Pzo3r/eH51mal8UP2f/AA9fXWm6j4r+H9he2UrW1xbXWoWaSwyI drI4ZshgQQQe
QQc1v+B9W+EnxN+2f8Ihd+EfFH2LZ9p/seS2uvI352b9mdudrYz12n0qeYCn vX+8Pzo3r/eH
5123/Cv/AAx/0L2l/wDgHH/hR/wr/wAMf9C9pf8A4Bx/4UcwHE71/vD86N6/ 3h+ddt/wr/wx
/wBC9pf/AIBx/wCFH/Cv/DH/AEL2l/8AgHH/AIUcwHE71/vD86N6/wB4fnXb f8K/8Mf9C9pf
/gHH/hR/wr/wx/0L2l/+Acf+FHMBxO9f7w/Ojev94fnXbf8ACv8Awx/0L2l/ +Acf+FI3gHwu
gJbw/pYA7m0j/wAKOYDit6/3h+dG9f7w/Ou1XwD4XcZXw/pTA9xaR/4Uv/Cv /DH/AEL2l/8A
gHH/AIUcwHE71/vD86N6/wB4fnXbf8K/8Mf9C9pf/gHH/hWdrmheA/DFqlzr FhoGl2zuI1mv
IoYkZyCQoLADOATj2NHMBzW9f7w/Ojev94fnVjxb8PPh9/aFit49joWo3jiO 0EcscRmYEDak
TZRzlgPuk8j2rntY8BReDyz3+k2epaUMf8TGK0jVohn/AJap6dPmUY65C000 wNnev94fnRvX
+8PzrLTwvokihl0qxZSMgiBOf0pf+EU0X/oE2X/gOv8AhTA096/3h+dG9f7w /Osz/hFNF/6B
Nl/4Dr/hR/wimi/9Amy/8B1/woA096/3h+dG9f7w/Osz/hFNF/6BNl/4Dr/h R/wimi/9Amy/
8B1/woA096/3h+dG9f7w/Osz/hFNF/6BNl/4Dr/hR/wimi/9Amy/8B1/woA0 96/3h+dG9f7w
/Osz/hFNF/6BNl/4Dr/hR/wimi/9Amy/8B1/woA096/3h+dG9f7w/Osz/hFN F/6BNl/4Dr/h
R/wimi/9Amy/8B1/woA096/3h+dG9f7w/Osz/hFNF/6BNl/4Dr/hR/wimi/9 Amy/8B1/woA0
96/3h+dG9f7w/Osz/hFNF/6BNl/4Dr/hR/wimi/9Amy/8B1/woA096/3h+dG 9f7w/Osz/hFN
F/6BNl/4Dr/hR/wimi/9Amy/8B1/woA096/3h+dG9f7w/Osz/hFNF/6BNl/4 Dr/hR/wimi/9
Amy/8B1/woA096/3h+dG9f7w/Osz/hFNF/6BNl/4Dr/hR/wimi/9Amy/8B1/ woA096/3h+dG
9f7w/Osz/hFNF/6BNl/4Dr/hR/wimi/9Amy/8B1/woA096/3h+dG9f7w/Osz /hFNF/6BNl/4
Dr/hR/wimi/9Amy/8B1/woA096/3h+dG9f7w/Osz/hFNF/6BNl/4Dr/hR/wi mi/9Amy/8B1/
woA096/3h+dG9f7w/Osz/hFNF/6BNl/4Dr/hR/wimi/9Amy/8B1/woA096/3 h+dG9f7w/Osz
/hFNF/6BNl/4Dr/hR/wimi/9Amy/8B1/woA096/3h+dG9f7w/Osz/hFNF/6B Nl/4Dr/hR/wi
mi/9Amy/8B1/woA096/3h+dG9f7w/Osz/hFNF/6BNl/4Dr/hR/wimi/9Amy/ 8B1/woA096/3
h+dG9f7w/Osz/hFNF/6BNl/4Dr/hR/wimi/9Amy/8B1/woA096/3h+dG9f7w /Osz/hFNF/6B
8B1/woA096/3h+dLvX++v51l/wDCKaL/ANAmy/8AAdf8KP8AhFNF/wCgTZf+ A6/4UAam9P76
/nRuT++v51l/8Ipov/QJsv8AwHX/AAo/4RTRf+gTZf8AgOv+FAGruT/nov50 bk/56J+dZX/C
KaL/ANAmy/8AAdf8KP8AhFNF/wCgTZf+A6/4UAa37v8A56pS/u/+eyfrWR/w imi/9Amy/wDA
df8ACj/hFNF/6BNl/wCA6/4UAa+I/wDnsn60Yj/57x/r/hWR/wAIpov/AECb L/wHX/Cj/hFN
F/6BNl/4Dr/hQBr4j/57x/r/AIUu2L/n4j/X/Csf/hFNF/6BNl/4Dr/hR/wi mi/9Amy/8B1/
woA2NsX/AD8R/r/hS7Iv+fmL9f8ACsb/AIRTRf8AoE2X/gOv+FH/AAimi/8A QJsv/Adf8KAN
nZF/z8xfr/hRsi/5+Yv/AB7/AArG/wCEU0X/AKBNl/4Dr/hR/wAIpov/AECb L/wHX/CgDa8u
L/n6i/8AHv8ACl8qH/n7h/8AHv8ACsT/AIRTRf8AoE2X/gOv+FH/AAimi/8A QJsv/Adf8KAN
vyYf+fyH/wAe/wAKPJh/5/If/Hv8KxP+EU0X/oE2X/gOv+FH/CKaL/0CbL/w HX/CgDc8mH/n
8h/8e/wo8iD/AJ/YP/Hv8Kw/+EU0X/oE2X/gOv8AhR/wimi/9Amy/wDAdf8A CgDc8iD/AJ/Y
P/Hv/iaX7PB/z/Qf+P8A/wATWF/wimi/9Amy/wDAdf8ACj/hFNF/6BNl/wCA 6/4UAbv2eD/n
+t/yf/4mj7PB/wA/9v8Ak/8A8TWF/wAIpov/AECbL/wHX/Cj/hFNF/6BNl/4 Dr/hQBvLb2wP
zX8O3vtDE/hkCnC8tbQD7OBLJ/z0mUfL9FyR+dc//wAIpov/AECbL/wHX/Cj /hFNF/6BNl/4
Dr/hQBqyT+a7O8m5mOSSetN3r/eH51mf8Ipov/QJsv8AwHX/AAo/4RTRf+gT Zf8AgOv+FACa
1/yEdD/6+2/9ES03w3/yC5/+vu6/9HPVS91vT9S1bRI7S+t7mQXTMUilViB5 MnOAfemaHr2m
WdncwXGoW0Eq3dzujklVWGZn7E0AVo5D/Z2mXkFv/pJsoQJktwz4MIUjd9mk PTI6njj2rW8O
Fd+oKsYi2yxblCbfmNvETxtXByST8q/QdK5uHS9CgFvs8URlrdUWJ3+yM6BQ AuGMecgAc+1b
Wk6po+l/amfxBDezXMvnSSzzxBidqqOFAGMKO1dFT2TjHl3RhBTTd9meL698 XZLb42uI59a/
stZ28PugsroaajGIuJ/P2eR5nn7Ycbt3OPUVi/D2/wDGnh3w3pGv6VYazYQX 9vZWtz/wmOsv
qKXtzPPCq3ECi4lMSKjTErmPcXQFflyv0DcXHhK7sWsp5NIms3m+0NbuYyhl 3+ZvK9N2/wCf
PXdz1qT+0PC/2G3svtGl/Y7coYbffH5cewgptXoNpAIx0wMVhC0Vr5fd1++7 fr5o3lrt/Xb9
P6Z5lqPxO8YaX4hmjku9CuLDTdTsdDvbOGzlF3dT3CRf6RH++IhRWnVvKKyE rG37wZ45CH4y
/EuPU7fQ9C0G38QXtiJbnUZII49tzm8uIgqC5v0e3U+QcN+/A3YCgIA3sut6 N4I1vVxrbto0
HiWK3e3tdeSO3e9tFYMMxSOrYxubggrycggkHIg+Hvw2l0bS7DWodF8USae8 k0V7riW9zN5s
j75JMlcKzP8AMQgUdAAAABUWklfe/wDX46/O2yKdtbdv6+/b8dzmvF/i3xnr XgDxzrllruj6
Jp1pbXsFta/YpWvLaSFihlecXCjnYzBQg27l+Y4Oes8T+O9Q8J+Bok/tPSNR 8WD7FbyP5bRW
8T3MwhSd4fMZ1j3FiFL/ADFCu8dRojQ/h4NevNc+w+Hf7avITb3Oo+VD9omi IAKPJjcy4AGC
cYA9Kqap4X8C3nhXUNBsZNH0S1vLIaezWMFr8sA3bYwkiNGUG98Iyso3Nxya zWkdVfb59/S/
f/Iaavf+un5fj82eb6p8WviNo02tWH2nwzqV5osd3dT3K2E8EdzHClq4iVPP cxswndd5ZwMK
dh5FZ3xITxf8SY9H0HUbzw262XiCaG8t7zR5bqxv1Wxa4hEkBuF4TdyCxBdE cbcba9H+HHw6
+H3w18NPo1lPpd7HK0pnmuI7WMy+Zt3qY4USNVIRAVRFB2gkE5J7D7V4T87z vN0nzvNM3mbo
93mFPLL5/vbPlz1xx0q2o2st7b+empEZNa7b/c7r9f6seO+Gvix48hh0ufUx 4cGmmHSrmaKy
tJkcRXjGLykJkIBjZd+/BDg7diEbzn2fx98cz61NafYrEWWp+RPoeoXtgLZG t3u4od7RreSy
P8kysN6wHK4K8kL7creDkRUU6MqIsSKo8oALEcxAeyEkr/dPTFcnq/wv+FOr abdWP9leHLS2
vLlLm7W1t7dPtTLIkhEo24cM0a7geuPoad4897aX79NP+Hv+d9FbSy02/D/P +tjY+FninXNd
fxJpviB7C71DRNRFkdQ0yB4Le6VoYpgwjZ3KEebtI3tyucjOB578U/FfiLVt XvYINR0ew8P6
Nr+m2UllLbvJe3UheCUOsolVYh+8UBdjkhScjdhez1DwzoVvo+n6T4S8Xj4e 6bZlytp4cjsE
ifccnKSwyBecn5QuSxzns/SvCPgqC4ttQ1q90vxV4igTyh4g1aCz+3MgfeqF 4o0ACnoAo6Z6
81Ls2mulvwtr87PTz8itk13/AAPNYPjx4os77wtJY2K3/hpksLPVGNn80NzO iHatxLeCRyBL
G2FglznBfO4rZh+MXj5odBvRc+GrqDxJbQ3VjaxWcymyWS5t49skvnHziEnP Ijjyy9ADgenH
w18NzrEGrf2Z4a/tSCJIIr3yIPOjjQgoivjIVSAQAcDAxXK+CPhF8P8AwV4t 1jxIup2Op6nq
T72e4t7CERnzfNJHkQxl23hW3yF2BUEEEtm04uXvLS7fy7ffrfotLsh3S93y /wCH/wCB18jI
8WfGLxj4X8bWFjDDa6xottPa6Zq91Fpgt40vJQv3JJLzfj95GwRYZRg7TJnJ Vnh34teP7ifT
LjUh4eaxmXSrmaK1tplkMd65i8tWMhAaNl37yCHB27EI3n0m90T4e6l4h/t6 7sfDtzrexY/7
Sliha42qQVHmEbsAgEDPBFXkbwdGqKh0ZVRYkVV8oBViOYgPZCcr/dPTFTFq 3vrW6fy6r5/h
sOSu3bTT8e/9ep09FZf/AAlOjf8AQVsv+/6/40f8JTo3/QVsv+/6/wCNSM1K t/B//j88V/8A
X+v/AKLWsD/hKdG/6Ctl/wB/1/xrb+DE8d1N4omhkWWJ78FXQ5U/u16GlLYD 4F8ZfGjxj4vs
vGPwM0Hwno98db8bahp1nfXE7GdGbXLieaZl8l8KIyTuTDwCFpwzHCx+8/sL fCrxP8Ifip8T
9I8V2lnZajLpWjzxx2dz56mIXGpRh920YDGNmUddjIWCMWRPU9V/Yc+DuseJ 7vxDP4f1GLV7
rUH1WS4tfEGoQbbtpfOMqKk4VG8w7xtAweRjFeieAfg/4c+G2qapqWkDVJ9R 1OKG3urvV9Yu
9RleOEyNEga4lkKqpmlOFwMuc13VcVH2XsKCtFpc1+sl1v28jnjSfNzz1avb 0PIvjf8AGWTw
r8W9KFvNrosvDzWrX8Wn6fdy2Mq3MmyY3M0aGGPyYcSjzWH3sjsa5bR9U8Za OviPxroWneIo
30y61ma7v/Eevvc6TqUKPOsMFvai4kMRWRYfmEURCxuATuwfq250DTL211G2 uNPtZ7fUQRex
SQqy3IKBCJARh8oAvOeAB0FNj8O6XFpMulpptoumShxJZiFfJcOSXymMHcSS fXJzXnwagtN9
fx/yOl6v7vw/zv6rozw/xv8AFjx74Qk1JTfeGpX8O6THrmpwGxm83UYpJZQt vbL5/wC5YJCV
81vMDuw/doBtPNeKvjT8StC8UX3hrw5pdrreuXOpXcyTR2quqW0UNoyx/Z7n UIBuxcqGeOUD
KZ8r94Sv0L4h+HvhjxZqGl3+teHtM1W/0qTzdPur2zjmls5Mg74mYEo2VU5X HKj0rnLX4E+F
bvQrrTPFNlF49F1fHUZ5/E1pb3DST7QivsWNY12oFQbEXgc5JYkTSX3/AItW +639XY7rR/1s
9fv/AD8kc5o3jPx942utQaOfRfCUWmWyQ3+jX1m17e/antVlJWaO4RFRWkVe Ffd5bEMNw2we
CfibqHhH9nXTtc8Q65pviXxHH4dfWIkg3W5uoY4lbcwaSVzjcgeUZGWB2jIF ein4WeDTrml6
1/wimjf2xpcAtrC/+wRefaRAECOJ9u5FAZgApAwT61JafDnw3pNtJHpOiado 0jJcIk9jZxRv
H5zBpivy4y7KrNkEMVBYHFTeylpv+l9r97/K1tQja8ebp/X9d9zxa5+J3xT0 3xHH4afV/CGo
aldiCWHUINIuI4LdHt7uQqYvtTGUhrZQCHTIY8cCub8beK/HvxY+G76NeXfh /S21OTQb1lXT
5rmA2l3Ptks5lMyeaMphmygkjdk2LndXrnwe/Zt8I/BqK+OmwR393dzLM91P p9lbFNqMihY7
WCGMYV5Bu2biHILEYA9ATwnokSIiaRYoiLCiqtugCrEd0IHHAQklR/CemK1f JzXtf4fw1a/T
/hyIymtdnr/w/wDwOnyPmvQ/iV8R/BvhtLS3h8F2+maZY6hPFa6dpU9tEkVh dCBokjE5CCVG
BUjiEr0mB+WbxX+0p410LxTqsthptrfeFJIr6HTLu6sFtl+120LuytJ9saWV Q8MiE/Zo1I5V
yAN/0c/hLQ5I3jfR7Fo3SWNka2QhklbdKpGOQ7Dcw/iPJzXMeIfgV4E8RRa8 ZPC+lWt/rcDw
X2p2tjCl3KGRoyTJtJJ2swyc8EjoalNJp273+f8AXyHZdNNV9y/r+tzN+Gnj LxVeeOvEPhjx
PcaTqbWVjaalb6ho9pJbIqTtMvkSI8smXXyc7ww3B/uLjnd+Jmz7DpXkY/t7 7b/xJ9/+r+0+
VJnzM8eX5Xm7++3ds/ebK0vBfw/8M/DnS303wtoGmeHbB5PNe20u0jto3kIA LlUABYhVGevA
9Kv654c0rxPapbaxptpqlsjiRYbyBZUVwCAwDAjOCRn3NKVnpESvu/6/rc8u H/CK/btN/s7H
9g/bLf7XjzPM83zV/s/y/M5+xebv2eT+73bdv7vzq9gkjWVGR1DIwwVIyCKz tS8M6RrN1ZXN
/plpe3Ni/mWs1xArvA2QdyEjKnKqcj0HpWnUJWGeVeIvDsngaZrm2VpPDznL IOTZE/8AtP8A
9B+nRUdZFDKQykZBHevUpI1lRkdQyMMFSMgivOtW+H99obmbw+ftVmSS2lzS Bdnf9y2OO/ys
cehGMVomBTorOuNaj02Ty9Ut7jR5NxX/AE2PYhPXiQZRuPRjTP8AhKdG/wCg rZf9/wBf8aoD
UorL/wCEp0b/AKCtl/3/AF/xo/4SnRv+grZf9/1/xoA1KKy/+Ep0b/oK2X/f 9f8AGj/hKdG/
6Ctl/wB/1/xoA1KKy/8AhKdG/wCgrZf9/wBf8aP+Ep0b/oK2X/f9f8aANSis v/hKdG/6Ctl/
3/X/ABo/4SnRv+grZf8Af9f8aANSisv/AISnRv8AoK2X/f8AX/Gj/hKdG/6C tl/3/X/GgDUo
rL/4SnRv+grZf9/1/wAaP+Ep0b/oK2X/AH/X/GgDUorL/wCEp0b/AKCtl/3/ AF/xo/4SnRv+
grZf9/1/xoA1KKy/+Ep0b/oK2X/f9f8AGj/hKdG/6Ctl/wB/1/xoA1KKy/8A hKdG/wCgrZf9
/wBf8aP+Ep0b/oK2X/f9f8aANSisv/hKdG/6Ctl/3/X/ABo/4SnRv+grZf8A f9f8aANSisv/
AISnRv8AoK2X/f8AX/Gj/hKdG/6Ctl/3/X/GgDUorL/4SnRv+grZf9/1/wAa P+Ep0b/oK2X/
AH/X/GgDUorL/wCEp0b/AKCtl/3/AF/xo/4SnRv+grZf9/1/xoA1KKy/+Ep0 b/oK2X/f9f8A
Gj/hKdG/6Ctl/wB/1/xoA1KKy/8AhKdG/wCgrZf9/wBf8aP+Ep0b/oK2X/f9 f8aANSisv/hK
dG/6Ctl/3/X/ABo/4SnRv+grZf8Af9f8aANSisv/AISnRv8AoK2X/f8AX/Gj /hKdG/6Ctl/3
/X/GgDUorL/4SnRv+grZf9/1/wAaP+Ep0b/oK2X/AH/X/GgDUorL/wCEp0b/ AKCtl/3/AF/x
o/4SnRv+grZf9/1/xoA1KKy/+Ep0b/oK2X/f9f8AGj/hKdG/6Ctl/wB/1/xo A1KKy/8AhKdG
/wCgrZf9/wBf8aP+Ep0b/oK2X/f9f8aANSisv/hKdG/6Ctl/3/X/ABo/4SnR v+grZf8Af9f8
aANSisv/AISnRv8AoK2X/f8AX/Gj/hKdG/6Ctl/3/X/GgDUorL/4SnRv+grZ f9/1/wAaP+Ep
0b/oK2X/AH/X/GgDUorL/wCEp0b/AKCtl/3/AF/xo/4SnRv+grZf9/1/xoA1 KKy/+Ep0b/oK
2X/f9f8AGj/hKdG/6Ctl/wB/1/xoA1KKy/8AhKdG/wCgrZf9/wBf8aP+Ep0b /oK2X/f9f8aA
NSisv/hKdG/6Ctl/3/X/ABo/4SnRv+grZf8Af9f8aANSisv/AISnRv8AoK2X /f8AX/Gj/hKd
G/6Ctl/3/X/GgDUorL/4SnRv+grZf9/1/wAaP+Ep0b/oK2X/AH/X/GgDUorL /wCEp0b/AKCt
l/3/AF/xo/4SnRv+grZf9/1/xoA1KKy/+Ep0b/oK2X/f9f8AGj/hKdG/6Ctl /wB/1/xoA1KK
y/8AhKdG/wCgrZf9/wBf8aP+Ep0b/oK2X/f9f8aANSisv/hKdG/6Ctl/3/X/ ABo/4SnRv+gr
Zf8Af9f8aAGayoGpaHgAf6W3Qf8ATCWt3w7qM+m+EbRoGCbru93fKDnFw/qK w9a/5COh/wDX
23/oiWtLTf8AkTrL/r6v/wD0oekwIT8S9Rg06x1K8sbqw0u82GO9nW3KAMu5 SwViygjuRx3x
W4PEd+RkTL/37X/CuA8Jq+taV4ZsVnWCC60uOaVvKicuIoolAG+I85lHzEsA AwwCcrqtFqfh
azhW7hsZNOjljtkkt5z5oV3CR/u/LC8blBwQOCQBwteDDMIUavsa876LW2za Ttp67/id7w7q
Q56a79el9zqv+Ejv/wDnsv8A37X/AAo/4SO//wCey/8Aftf8K+ff2hbl4vEH h8PpXizWbKPT
tQuZbfwnqsllIhRrfEsgS4iaUKGYBV3t8xwpzWDefFz4h2U/hnRPDOn2vjS4 g0Oy1HUdRtTb
Sx6gZSy5jd7q38pW8piJVSUHf9wbcN9H7PRPv/wf8v61tw20b7f8D/Nf8Nqf UH/CR3//AD2X
/v2v+FH/AAkd/wD89l/79r/hXzRf/HDxjpet6vaahHpGltNObfSLa6s5WiCG 6it0uXvI5Wil
XMm5oCIZQcL0PmHovBvxb1qfxTqHhvXpdLmutMjvfO1C0ha3huWiW2dXjRpH KqFudrAs3zLn
Izis0rq/k392/wB39bOzcWvvse6/8JHf/wDPZf8Av2v+FH/CR3//AD2X/v2v +FfPHh/4v+L9
c8L6hrzHRLe0VrOytk8iU4nuY7ZhPI/mYEaNO+UAywC/OvOaXin4nfFPQPFl r4b0rTNP8W39
pZxX9/cadZQ28dwkksirGqz6gjQYERHmDzwSx+VduGfL73K9/wCv01EleLkv 6/p6f8A+lP8A
hI7/AP57L/37X/Cj/hI7/wD57L/37X/CvF/jLpOqa3caKbeW4udNt4Z7i+0X Ttck0q+uMBNk
kMsbIXKfMvlvJHGTKCzDaK43wz8aPGniXxhYWXhjw7cah4QtfsVvc3N6tv8A aWSWCKUzSSNd
o8bKsoJQW8m7YcN8/wAhGPNov6/r+tnYa0uu1/8Agep9Nf8ACR3/APz2X/v2 v+FH/CR3/wDz
2X/v2v8AhXk/wNvNev8Aw1qU2u6zaay39rX0UDW1u8TRIlzImxy0sm7BXAxt 2gBcHGa9GpNW
F1aNL/hI7/8A57L/AN+1/wAKP+Ejv/8Ansv/AH7X/Cs2iiyA0v8AhI7/AP57 L/37X/Cj/hI7
/wD57L/37X/Cs2iiyA0v+Ejv/wDnsv8A37X/AAo/4SO//wCey/8Aftf8KzaK LIDS/wCEjv8A
/nsv/ftf8KP+Ejv/APnsv/ftf8KzaKLIDS/4SO//AOey/wDftf8ACnDxLqK9 JwPpGv8AhWXR
RZAav/CT6l/z8/8Aji/4Uf8ACT6l/wA/P/ji/wCFZVFFkBq/8JPqX/Pz/wCO L/hR/wAJPqX/
AD8/+OL/AIVlUUWQGr/wk+pf8/P/AI4v+FH/AAk+pf8APz/44v8AhWVRRZAa v/CT6l/z8/8A
ji/4Uf8ACT6l/wA/P/ji/wCFZVFFkBq/8JPqX/Pz/wCOL/hR/wAJPqX/AD8/ +OL/AIVlUUWQ
Gr/wk+pf8/P/AI4v+FH/AAk+pf8APz/44v8AhWVRRZAav/CT6l/z8/8Aji/4 Uf8ACT6l/wA/
P/ji/wCFZVFFkBq/8JPqX/Pz/wCOL/hR/wAJPqX/AD8/+OL/AIVlUUWQGr/w k+pf8/P/AI4v
+FH/AAk+pf8APz/44v8AhWVRRZAah8S6i3WcH6xr/hTf+Ejv/wDnsv8A37X/ AArNoosgNL/h
I7//AJ7L/wB+1/wo/wCEjv8A/nsv/ftf8KzaKLIDS/4SO/8A+ey/9+1/wo/4 SO//AOey/wDf
tf8ACs2iiyA0v+Ejv/8Ansv/AH7X/Cj/AISO/wD+ey/9+1/wrNoosgNL/hI7 /wD57L/37X/C
j/hI7/8A57L/AN+1/wAKzaKLIDS/4SO//wCey/8Aftf8KP8AhI7/AP57L/37 X/Cs2iiyA0v+
Ejv/APnsv/ftf8KP+Ejv/wDnsv8A37X/AArNoosgNL/hI7//AJ7L/wB+1/wo /wCEjv8A/nsv
/ftf8KzaKLIDS/4SO/8A+ey/9+1/wo/4SO//AOey/wDftf8ACs2iiyA0v+Ej v/8Ansv/AH7X
/Cj/AISO/wD+ey/9+1/wrNoosgNL/hI7/wD57L/37X/Cj/hI7/8A57L/AN+1 /wAKzaKLIDS/
4SO//wCey/8Aftf8KP8AhI7/AP57L/37X/Cs2iiyA0v+Ejv/APnsv/ftf8KP +Ejv/wDnsv8A
37X/AArNoosgNL/hI7//AJ7L/wB+1/wo/wCEjv8A/nsv/ftf8KzaKLIDS/4S O/8A+ey/9+1/
wo/4SO//AOey/wDftf8ACs2iiyA0v+Ejv/8Ansv/AH7X/Cj/AISO/wD+ey/9 +1/wrNoosgNL
/hI7/wD57L/37X/Cj/hI7/8A57L/AN+1/wAKzaKLIDS/4SO//wCey/8Aftf8 KP8AhI7/AP57
L/37X/Cs2iiyA0v+Ejv/APnsv/ftf8KP+Ejv/wDnsv8A37X/AArNoosgNL/h I7//AJ7L/wB+
1/wo/wCEjv8A/nsv/ftf8KzaKLIDS/4SO/8A+ey/9+1/wo/4SO//AOey/wDf tf8ACs2iiyA0
v+Ejv/8Ansv/AH7X/Cj/AISO/wD+ey/9+1/wrNoosgNL/hI7/wD57L/37X/C j/hI7/8A57L/
AN+1/wAKzaKLIDS/4SO//wCey/8Aftf8KP8AhI7/AP57L/37X/Cs2iiyA0v+ Ejv/APnsv/ft
f8KP+Ejv/wDnsv8A37X/AArNoosgNL/hI7//AJ7L/wB+1/wo/wCEjv8A/nsv /ftf8KzaKLID
S/4SO/8A+ey/9+1/wo/4SO//AOey/wDftf8ACs2iiyA0v+Ejv/8Ansv/AH7X /Cj/AISO/wD+
ey/9+1/wrNoosgNL/hI7/wD57L/37X/Cj/hI7/8A57L/AN+1/wAKzaKLIDS/ 4SO//wCey/8A
ftf8KP8AhI7/AP57L/37X/Cs2iiyA0v+Ejv/APnsv/ftf8KP+Ejv/wDnsv8A 37X/AArNoosg
NL/hI7//AJ7L/wB+1/wo/wCEjv8A/nsv/ftf8KzaKLIDS/4SO/8A+ey/9+1/ wo/4SO//AOey
/wDftf8ACs2iiyA0v+Ejv/8Ansv/AH7X/Cj/AISO/wD+ey/9+1/wrNoosgNL /hI7/wD57L/3
7X/Cj/hI7/8A57L/AN+1/wAKzaKLIDJ1r/kI6H/19t/6IlrU0kZ8I2A/6e77 /wBKHqLxnoVp
4f1vQbezEoia5Lnzp3lOfJlHVyT2HHStnwd4YsPEfhK2+2rOfJu73Z5NzJD1 uHznYwz0HWk3
1A4mXwdHp09vceHhZ6LPEsiFVtQYnV9hYlVK/NmNcHPTPB4wPoWt6i8Mepat az2aTRzNHb2b
RuxRw6jcZGAG5Rnjpnp1Hbat4Y8JaNcLbzpq8s5XeY7S4vbhlUkgFhGzbQSD gnGcHGcHEmj+
EfCuueaLZdUWSLBeG5u7yCQA5w2x2B2nBwcYJBHY15NXK8HWq+3nT97Tq1tt onY7YYyvCHs4
y09F+e5hyWVvLdR3LwRtcRo0aSlQXVWILKD1AJVcjvtHpXMal8I/A+sx2kd/ 4P0K9jtJZJ7d
LjTonEMkjb5HQFflZm+Ykck8nmt/4nDw/wDDaPw/HH4d8R+JtR1zUDptlp+k amVleQW81wxL
T3ESBRHBIcls5wADmvCfH/7XXgH4W69qOjeKfhj8SNI1DT4VubiKW9t2xCyk iRSt+Q68MNyk
jcjr95WA9qEZ1ZctNNvy8jglJRXvOyPXbf4YeD7SfWJ4PC2jxTayrJqUiWMQ a9Vs7hMdv7wH
JzuznJ9ajf4TeCZNG07SG8I6I2ladN9osrE6fF5NtJknfGm3CNkk5AB5PrXq EXw00CWJHCX2
GAYf8TK4/wDi6p6j4O8KaVe6daXT30VxqMxgtk/tC6PmOEaQjIfj5UY5OOnr isrrYp67nIr4
T0RdJutLGkWI0y6Ty7izFunkypsCbWTGGGwBcHsAOgrAk+Cnw+msNPsZPBHh 57LTnaSzt20y
Ex2zMQWMa7cKSQCSMZIr1S98AeGNOiSS7lubaN5FiV5dVnUF2YKqgmTqSQAO 5IFYdrZ+B77x
rd+FbZtYuNXtIhLcmKW/a2gyAQj3APlLIVZW8suH2sG24INPm1v1/wAg6eX+ ehzniv4feGPH
cNtF4k8O6Xr8VsxeBNTs47gRE8EqHBwfpUeofDfwnq2vWOuX3hrSbzWbEKtr qM9lG9xAFJKh
JCNy4JJGDxk16X/wrHQf7l9/4Mrj/wCOUf8ACsdB/uX3/gyuP/jlJSS2DdWO G0zw7pWiXV/c
6fptpY3F/L593LbwqjXEmAN8hAyzYAGTzgVo1s6v4M8KaFFBJevfxLPPHbRY v7pi0jsFVQA5
PU9egGScAE1f/wCFY6D/AHL7/wAGVx/8coTVtPQDl6K6j/hWOg/3L7/wZXH/ AMco/wCFY6D/
AHL7/wAGVx/8co5kBy9FdR/wrHQf7l9/4Mrj/wCOUf8ACsdB/uX3/gyuP/jl HMgOXorT1Dw1
4M0q/azvLq6tpktZL1zLqVyqRwIQGdn37VA3DqR39Di7p/gHwvq1jb3tlLc3 dncRrLDcQarO
8ciEZVlYSYII5BFHMnr/AF/Wj+4PI5+iuo/4VjoP9y+/8GVx/wDHKguPh/4Y tZreGaS6iluX
McKPqlwGlYKWKqPM5O1WOB2BPajmA56iuo/4VjoP9y+/8GVx/wDHKrp4B8Ly Xk1okty13Ciy
SQDVZy6K2QrFfMyAdrYPfafSjmA5+itnRfBnhXxDYC9sHv57YyPGJPt90oJR yjYy4yMqeeh6
jIINX/8AhWOg/wBy+/8ABlcf/HKOYDl6K2ZfB3hSHXLfR3e+Go3EElzHD/aF 180aMiu2d+Bg
yJxnPPsaSbwd4Tg1u30h5L5dQuIJLmOH+0Lr5o0ZVds78DBkTjOefY07/wBf 16MDHoq3Y6T4
D1FrBItSmEt/JNFZwy6rcRyXLREiTy1aQFwu0nIBGOemDVPQ5fhf4n8SXvh7 R/FFpqmvWO/7
Vpln4hkluYNrBX3xrKWXDEA5HBIFCd3ZB0uLRXUf8Kx0H+5ff+DK4/8AjlQW 3w/8MXklxHBJ
dTSW7+VMseqXDGN9obawEnBwynB7EHvS5gOeorpn+Gfh+NGZlvlVRkk6lcYA /wC/lR2Xw98M
6jaQ3VpJdXNrMgkimh1S4ZJFIyGUiTBBHcUcwHO0V1H/AArHQf7l9/4Mrj/4 5WR4r8N+DvBO
g3Ws6xLqFtYWwG9kvruV2ZiFVERGLO7MQqooLMSAASQKOZDSb0RnUVtaJ4I8 Na/pNpqNtDq8
dvcxiVEu7m8tpgCMgPFIyuh/2WAI7ir3/CsdB/uX3/gyuP8A45TuLc5eiuo/ 4VjoP9y+/wDB
lcf/AByj/hWOg/3L7/wZXH/xylzIDl6K6j/hWOg/3L7/AMGVx/8AHKP+FY6D /cvv/Blcf/HK
OZAcvRXUf8Kx0H+5ff8AgyuP/jlH/CsdB/uX3/gyuP8A45RzIDl6K6j/AIVj oP8Acvv/AAZX
H/xyj/hWOg/3L7/wZXH/AMco5kBy9FdR/wAKx0H+5ff+DK4/+OUf8Kx0H+5f f+DK4/8AjlHM
gOXorqP+FY6D/cvv/Blcf/HKP+FY6D/cvv8AwZXH/wAco5kBy9FdR/wrHQf7 l9/4Mrj/AOOU
f8Kx0H+5ff8AgyuP/jlHMgOXorqP+FY6D/cvv/Blcf8Axyj/AIVjoP8Acvv/ AAZXH/xyjmQH
L0V1H/CsdB/uX3/gyuP/AI5R/wAKx0H+5ff+DK4/+OUcyA5eiuo/4VjoP9y+ /wDBlcf/AByj
/hWOg/3L7/wZXH/xyjmQHL0V1H/CsdB/uX3/AIMrj/45R/wrHQf7l9/4Mrj/ AOOUcyA5eiuo
/wCFY6D/AHL7/wAGVx/8co/4VjoP9y+/8GVx/wDHKOZAcvRXUf8ACsdB/uX3 /gyuP/jlH/Cs
dB/uX3/gyuP/AI5RzIDl6K6j/hWOg/3L7/wZXH/xyj/hWOg/3L7/AMGVx/8A HKOZAcvRXUf8
Kx0H+5ff+DK4/wDjlH/CsdB/uX3/AIMrj/45RzIDl6K6j/hWOg/3L7/wZXH/ AMco/wCFY6D/
AHL7/wAGVx/8co5kBy9FdR/wrHQf7l9/4Mrj/wCOUf8ACsdB/uX3/gyuP/jl HMgOXorqP+FY
6D/cvv8AwZXH/wAco/4VjoP9y+/8GVx/8co5kBy9FdR/wrHQf7l9/wCDK4/+ OUf8Kx0H+5ff
+DK4/wDjlHMgOXorqP8AhWOg/wBy+/8ABlcf/HKP+FY6D/cvv/Blcf8Axyjm QHL0V1H/AArH
Qf7l9/4Mrj/45R/wrHQf7l9/4Mrj/wCOUcyA5eiuo/4VjoP9y+/8GVx/8co/ 4VjoP9y+/wDB
lcf/AByjmQHL0V1H/CsdB/uX3/gyuP8A45R/wrHQf7l9/wCDK4/+OUcyA5ei uo/4VjoP9y+/
8GVx/wDHKP8AhWOg/wBy+/8ABlcf/HKOZAcvRXUf8Kx0H+5ff+DK4/8AjlH/ AArHQf7l9/4M
rj/45RzIDl6K6j/hWOg/3L7/AMGVx/8AHKP+FY6D/cvv/Blcf/HKOZAcvRXU f8Kx0H+5ff8A
gyuP/jlH/CsdB/uX3/gyuP8A45RzIDl6K6j/AIVjoP8Acvv/AAZXH/xyj/hW Og/3L7/wZXH/
AMco5kBy9FdR/wAKx0H+5ff+DK4/+OUf8Kx0H+5ff+DK4/8AjlHMgOXorqP+ FY6D/cvv/Blc
f/HKP+FY6D/cvv8AwZXH/wAco5kBy9FdR/wrHQf7l9/4Mrj/AOOUf8Kx0H+5 ff8AgyuP/jlH
MgOXorqP+FY6D/cvv/Blcf8Axyj/AIVjoP8Acvv/AAZXH/xyjmQHL0V1H/Cs dB/uX3/gyuP/
AI5R/wAKx0H+5ff+DK4/+OUcyA5eiuo/4VjoP9y+/wDBlcf/AByj/hWOg/3L 7/wZXH/xyjmQ
HL0V1H/CsdB/uX3/AIMrj/45R/wrHQf7l9/4Mrj/AOOUcyA5eiuo/wCFY6D/ AHL7/wAGVx/8
co/4VjoP9y+/8GVx/wDHKOZAcvRXUf8ACsdB/uX3/gyuP/jlH/CsdB/uX3/g yuP/AI5RzIDA
+Jv/ACMvh7/rsf8A0VNW/wDDH/kUk/6+7v8A9KJKwPib/wAjL4e/67H/ANFT Vv8Awx/5FJP+
vu7/APSiSk9gOO+LGn622tzS6ZqviHQFuLe3Vb/w7Zw3MrGNp98biWCZVX96 hztBJAwcBhU/
wm0fW3fUJ9R1XW7tvIit11PVraGG6uGDTsdyLCiAKJUwVjAO0Z3YbPpGtuse jXzOsboIHLLM
qshG08MGZQR65IHqR1q4v3R9KObS1hW1ufIf/BRvxHf+CPhr4C1Sy1240W5i 8VFP7TikWKSF
JNPvkZVfA2ZVygcYcZBVg4DV8aRaN4S+MXwp+J3xC8ZfHC2fx9M92y6NNPZR TXyQ6ekduixi
JP3jvHGN0W9TH8mFmLNH+wN7JbQW0k120SW8Sl3kmICooGSSTwAB3rA0fxT4 f1bUZbW31HS7
mYyYt4oJYmd1CAkgBiTg7ucDp0wNx7KeKlSo8lNWld+8t7NWt6GUqSnLmk7r t09TI+MWoXGk
fBTxVeWt1c2N1b6PNJHc2mfOiYREhkwCdw6jA618/WKa8PEra74R03xjrvhW 2H2iCz8THUIb
htQFleibyzdr58UTB7ZQQPL3HCDduFfW97YW2pWc1pd28V1azIY5IJkDo6ng qVPBB9DVHVvE
2leH73SbG+vI7W41Oc2tnE2cyyBGfaPT5Ubk8dB1IB449bLVo6OZJJP+tv6+ dup8e6F4W8Q6
r4B8R2us3HjDXvD0Go6RqcDwWmuWF6gW5IuhEt1cyXjlERW2ow7FE3HLdLqv w0i8L6l4j16G
Px7FoWqeI431X+ytQ1OS6lsjYx7HSFXMoxOI1ZoF8wKuwkRq6j6ypu9efmHH XnpRzPW3X/7X
9IpffuTHTR+f6/dZu/rY+VtA8NeOdW8I+Jb69vvF0FzZ6A3/AAj8P2m5jl+a S9WFpEPzS3Ig
NvuEoZg4UsA4zXSeGvBfiDwz44jmTUvFt3p0esT2ojvb+4uYhZPp4lJw5Ib/ AEnO2RsspPlq
wT5K+hgQRkHIpacpKTbtvf8AEN1Znzd4vi1TxH8P/DekaJP4ohv9O8OXGrI2 pEjWRP5Bgt/P
AyTNmWViMH54we1c38YvCvi/RvHGh2OneKvE2i6BDZRS2F5Dpesa4Wvmmkac zG0uU6Aw4S6R
4dvyoAA619Vpp1nFqMt8ltCt/NGkMlyEAkeNCxRS3UqC7kDoNzepq1RzPmUu t7/n+Wnra5bl
e67q35frf5N92fHdwfGSeJ/Gwgl8a6vC0ztfajAmo2T29p9siD29rbSg28rC 3WXZcWTLIw/5
Z+YVdui8EeKtc8HakLyW08bXfga5N/aaILyy1C8vgWFqY/tKSK1wn70XeySc AKmAWUMufqKi
pTtG3lb+vTp2u273YSkm7263/r9fuVrHzD4Z0Lxh/wAK413XNWufFzariyt3 tTc3Hnx2Jt7M
3n2eEH5puJ8OAZA+8IQxIPHeM7LW7vxBoJ8LeI/HPhzwelqjaZPqOg+ItUuf tvnyecZ1W4jl
wB5OFvEeIr9zjzAfs+iq5vfU10t/X6+pKbUHHv8A1/wH3Wh88+O4PEXi6TxU /h7TU1u71G+s
/DyQ3dw9vafZYAZrppJFSQxBy80RbYSTsGOlebx3+p6DcaV4N+INv4t0iKwh 1SKCz8DPqlxH
Mvm20tqyT2kSSukUc3lb2CLuVwRX2LYabaaVC8Nlaw2kTyPMyQIEVpHYu7kD uzMzE9SSSeTS
tp9s99HetbxNeRxtElwUHmKjEFlDdQCVUkd9o9Kzikvi1/4a2nbXVb2bHfX+ vlffpZfJHzBo
Phf4g23ww1zVPE1/4rufE0b2FrdRWF1JvFn5Nmb1raKMhGkO2f54wZAxkERD EA5N0viqHQba
fwtf+Jra4k1HU7XwrBrl1di7lgOmyOPtEF44aRhcxuYzcDKqFwQh5+vay38L aNJ4kTxC2lWT
a8lubNdTNuv2lYC24xCTG7Zu525xnmtee7lpuvu/p/deW9wUrJeTv5f1/kj5 N8E2uv2PhC9/
tbxH401rwzJqFudVtbPQdfsNStk8uXcYXuZ5rqRWl8gMLZsKFPGHcnrdmm+C PGmteJ9NtvF3
+leFLWPRptVl1J4JZFaZfLuFnbCzZeHi4AkJdiuTvr6ZqtqGm2mqwLBe2sN3 CsiTCOdA6h0Y
OjYPdWVWB7EAjkVnL3r36/5W0/rv3uCdt/61v/w/c+ZbT4R6/a6nb6edY8Yp p8V+dMYWup3U
MTWS6WjbgUI25uUB85cPvLKGwzKczT5PHEuv6E92fGZ8cNLphsjKl2mjfYPI i+2/aFjAthLn
7VkTgS79mzjy6+tqKvm1vbt+H+fXyuupPRp9mvv/ADPiS80fxXPp8upeH08d xeLRo72/iHUN
Yg1CdYpjd2hultImkjQgxicr9hZAwX9025Ux1Hw8l1/wfpba1Pq2q+I47TSt TisrnVdF1LT2
hlke0EVuRqEsk77pAxDO5zkhcBMD6zqtqGm2mqwLBe2sN3CsiTCOdA6h0YOj YPdWVWB7EAjk
UubTl8mvvvt6X06+erKcru773/L/ACPlnxt4N+IGlajYXnhzw1BqemeCLWwj t728vplv5jFi
W8+zwLA4uDNERFkyJlweuKtn4X+N9V8B61q9xqrWR0651m/0HTtK0mS21OOe VrmNHkmaR/M+
SZmULGmSUPzY5+pKKalZNd239+//AAOxPZ+n4befr3Pl74r6FrXhvVUsdPn8 c3F0mmxP4Xls
bq+uLVtVaaRpTfPGSNmTBxdHyVj3BAAGA5H4mWXiyXW9UsNN8SeILLwxBrd1 9ruLG31fWJYb
lra0kjjxY3Ud0keXuCFDGFc4Kj93j7OIDAg8g8VmeHPC+j+D9Kj0zQdKstG0 2NmdLOwgWCJS
zFmIRQACSST6kk0lKyt6/i0/wtp8u2tXs0/62a/r59zwXQ7KTUvFEVj4xvvG mp67LYRRaVe2
Fvqlhpk8JtAHeaOEiCGUy+cStwd6koAeEqbwDe6n4Y+AFp4Y8L6N4qg8SL4f unjn1dJ2Ntew
qiGHzbsnDF3zEOYmEbFTsHP0RUV1bQ3ttLb3ESTwSqUkikXcrqRggg9QR2qW 9Jab/Lvbb117
+QRaTi30/r/hvuPj7wxZx+NPF0uieF9W+I0fh9fsz6kuq3ur210rta32TvuS ssaM6w8xlVLK
oBzkVqXPwq1zxX4SttK8QzeLtSiuG8OancGbULuGVbzzyLplaNlMQVVRmjTa kbAOFVvmr6U8
H+AvDXw906Ww8L+H9M8OWMspnkttKtI7aN5CAC5VAAWwoGeuAPSt6tXKPNdL +X8Nfu/yRmuZ
bvv+PX17nyX/AMKz8V6Vpl1JZ6x47eaGy1aeGOXVryYme3vR9gHzMS37ssAp yJl/1gkwCOZ8
fax47s/F/i3Xre78SaLCltqEF7ZQWmrPFbRJbSmG4juJZTaFmaKNwLaAMrOF LE7t/wBtVBfW
NtqdnNaXlvFdWsylJYJkDo6nqGU8EH0NQpWtZd/x/qxWj+9fh0/r8jxj4BCe fxP4lvNJm8Uv
4MntrXyE8Wi+WcX+ZTcGJb0CZYyhg4AEeQdgB317dSABQABgDgClok07WQl5 /wBf1+YUUUVI
wooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPNfib/wAjL4e/67H/ ANFTVv8Awx/5
FJP+vu7/APSiSsD4m/8AIy+Hv+ux/wDRU1b/AMMf+RST/r7u/wD0okqnsBu6 4/l6NfPu2bYH
O7dtx8p5zuXH13L9R1q6v3R9Kpa55v8AYt/5P+u8h9n3/vbTj7nz/wDfPzen NXV+6PpUdQOZ
+I7tF4XaYAlYLu0nkIGdqJcRszH2CgknsATXjei+LfFuua1Z2Gq+LPDfiK3l vLZo7TQ9Dls5
wyXEbly7Xc2UVFckbR67gAQfoojI55pBGinIVQfYVomluhNMrW0V8rDz7iCR duCI4ShLYXnJ
Y8ZDnHoyjPykt8dfHDw345j+IWmjxNO2vahfSiLwxc6Qpt4raYSI2NhyY3BC uSztwud2F/d/
aFZ2px2sl5prTW0NxJFOWikkXc1u3luN6nB2nBZckrw5GecHWhW9jLmtcxrU vaxtcyPhvp/i
rTPCttB4x1Oz1bW1+/cWUBiXGBwegds5+YKgOR8gxz4Xq/grxLf/ABC8ezeH Yo10vXdT/s3x
FN5vlyQ26WUDpLGP4mI8yHA5Hnq3SMg/TYORxzTWZEzkqvrmuaa5+a/VNffb /I6IvlSX9f11
PirTvjH4l8P6t4F0vQ/EENlY2FjpVjd+Hb2/tlluUljjBuIbQWjzvGPNUeab iNQ6EbCBh1tv
j9rf9k6NqVj8YbPWtNvLG0k8SagUsDB4cne6tY9oZEAi8xJLkbZy5BiyMBWB +zWjs71Xj/dS
7lKsFIJwayh4D0IeH9P0Qaeg0ywaBreDc3yGFlaLnOTtKL1JzjnNb86cnKav rf5Pdf1+FhK0
dl0S+7+v809j5c0/4leLtQ8QLb6P4zTxFpbXostI8ZNZWk0l5avc6cspV4o1 jfa81xFujVVy
i7gzJmtfxP8AEPXvCWq3HhrxN8V7rwtotld3aL4wvYNPguLqVYLaWG1eSSH7 MpInmOBEGZYh
g/K5b6oWGNQAqKAOgArmvHfw40f4jWUFprEmqRwQuXA0vVrrTyxIwQ7W8iFx 7MSPas200kl0
t+WvqtX5t66FJ63f9ff3/DpbSyfCzWbrxF8NfC2qX1z9svLzTLe4muNqr5rt GpZsKABknPAA
rqar6fYW2lWNvZWcEdtaW8axQwxKFSNFGAoA4AAGMVYp1GpTbitGzKCailLc KKTIzjPNLUFh
RRTXkWPG5guemTigB1FFFABRRRQAUUU15FjxuYLnpk4oAdRRRQAUUUUAFFFF ABRRRQAUUUUA
FFISB14petABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQB5r8Tf8A
kZfD3/XY/wDoqat/4Y/8ikn/AF93f/pRJWB8Tf8AkZfD3/XY/wDoqat/4Y/8 ikn/AF93f/pR
JVPYDd1xPM0a+Tbv3QONu3dn5Txja2fptb6HpV1fuj6Vn+Ijt0DUjsVwLaT5 XZFU/KeCXBUD
3YEeoxWgv3R9KjqAtFFFMAr558R6trUWo3Laf4N8H+JQ11dCa98Q6tJa3IZb mVVQKtnNlVRU
AJYem0BQT9DVzWueEfD+oana3F7o9jcXNxNtaSW3hZpMRtgMXGSAF/h5+Ufw g1SaW4mm9jP+
Hd7fXHhSN7eCCSEXF0kQeYoFVZpgqABThVCxqMdBnj5QG+Tf+CiGu+OtI+K3 wQtvh/Y/2zre
p/2tp8uiyxCW11K2kFr51vcxsQrQMoJfcQFC7tylQw+4ra2hsreOC3iSCCJQ iRxqFVVAwAAO
gArP1rwto3iISHVdJstS32s1i/2u3WXdby7fOhO4HKPsTcvRtq5BwK9jKMwh lmMWKnTVRJSX
K9nzRcdfLXUzqQc48t7HhPhH4d+GPAP7RXgN9B8J+HvCV/feDtZbUrfw9BGk TSrc6X8pdY0M
iqWcKzKDgk4XJFd3+0V4Xt9d+GOt3z3+sadd6ZZz3NtNo+r3WnsJAhwWMEib wMdGyPatfwB8
I/h94KuE1vwn4J8P+G766thG11pWnQQStE21iheIcqSFOASCVB5wDWn8QfGX g/wXoBn8b61o
2iaLeP8AZDJrtzFBbzOyk+VmQhWJVWO3uAfQ14ztJ3sbJ2Z434p8Ya38IE1L S/C15avpHhnS
Itdv7fxHdXeqajqaSySAwwSyz7ojiFgrt5o3OAEAX5tLw18WfG134p8Mz6g2 hz+H9e1q+0Zd
NtLWVL218n7SyTtMZWVwRbgMnlrgvkOcYPffES0+G8FpZeKfHMXhqO30KRZr XWNeWALp7s6h
XSWT/VkvsAIIOdvfFV/hl8LPh/4ceTxX4V0vSLm91vzb0+I7WCFp72K4k87P 2hFBkjJKleSC
FXk4zVxaSXOu/wDwP66dBO1rR/rT/PXz22PJ/iB4u1zwUPitrTa1eLoslw2n qXuWA02f7HAY
HhJP7sO7lCF6u8ZHJYmbUv2hvFXh2KbXrhNE1Hw/LPqlha6RbJIl5ay2Ucz+ dcXJdl2N9mYM
ohBTzU+Z9p3fQdz4c0q9tb+2uNNtJ7bUCTeQyQKyXJKhSZARhvlUDnPAA7Vn W3w58K2fiW98
RQeG9Kh1+9h+z3WqR2ca3U8WFGx5QNzL8q8E4+UegqYtJJPtb8F+t9el/IpN Xu11v/wPLp93
mz5p8QfE34i+AvGWqRxTaJ4t8W62ml2ds2kaesMNshS9mwYbi+QStiJgP38W Q24A7drd94/8
ReK9Y/Z7sLzxBoerab4iuNQsre70vQr9LO8mU3iIRFLFclYjInO0XB2h9pc4 Jr0a3+Cnw+tP
Dt1oEHgjw9DoV1tE+mR6XCttLtYuu6MLtOGJYZHBJPWtvS/BmgaHoVpounaL p9jo9myvbWFv
bIkELK29SiAbVIb5hgcHnrTbT3XVfcun9b9RXas+uv39/wCrWtofNOn/ABW8 UeCfAMtt4Xsd
RvdU1DxO+kafo3iK7TUNR0YLa+a8VyZ7uPznZopJEBuv9XPGyMyhUND4k6h4 31q68J+LPFuj
6Kn/AAjfh/U9bufCur6clwJbq3li2zxul08VvIU2lHzL5IkkBL7uPpvXvhv4 T8UjURrPhrSd
WGoxxQ3ovbKOX7SkbFo1k3A7wrElQc4JJHWrGi+CfD3huytLPSdD07TLSzhe 3toLO1SJIYnI
Z0QKAFUkAkDgkA03O75ra/8A2rX56/8ABKUkmlbTr5q9+nlppbv1Z4P4R+K/ xj1dtL07VdC0
zRLrVb8Q2mq6hZxCIxG2nlOLe21C4LlGiTlpYwwkwANuTnzftCfFKXUvFupW XhG2l8K6WdSt
obmZbdY4prXzFWSSVb1pXDvFgx/ZUK+Z94hMv7x4W+E3gnwNIz+HPCOh6C7S +eW03T4rcmTa
y7/kUfNtdhnrhiO5ptz8JPBF74lufEVx4Q0OfX7mMxT6pJp0TXMqFdhVpCu4 gr8uCenHSlzL
mvbS36f189fISejTWun639L6fdbqeZ3XxI+IOl6/N4Tu7/w2NavprU2GrjTp ltLSOZLhyksJ
uN0zgWzKGWSMMZAdq7cNnWfxd+Kdx8WW8OWugWeu6Lo93bafrGoWVtbwpK0k Mcklwpk1DzYF
US5EXkTFgnEmX+T23xB4E8N+LbK8s9b0HTdXtLxI47mC+tEmSdEYtGrhgQwV iSAehJIrKX4M
+AU1LSNQXwV4fW/0eJIdNuhpsPm2UaElEhbbmNVJJAXAGTiphaMrtaf8N/wf W973SF9hrrb8
f6+75lf4q+O9T8D6Zay6fpf2hbiQRzancK7WunqWUGSZYlaQgBi33Vjwjb5Y hhq8F+NUGv6l
qvhDxIPEvhTxVpGi+HbzxEv9p6IbqyuZ0kgcXMG25VY8I2IpDvaNS5LSFyR9 ZkBhgjI9DWcP
DWkqxYaZaBisqZEC52ytulHTo7Dcw7nk5NEHyPmeut/wa/N3/O+hV1a3yf36 /hoeT+MPir4o
f4i2nhDwvLokU1ytsDeX8Mk4tzJBdyFjGkib8G3jwu5chm+bpiv4O+I3jrx1 qlppUOo+HdHu
9MVm1aa406acahtupoD9mT7QhgH+js2WaXBkUYO3Lel+Gvhd4O8GJCmgeFdG 0RIW3xLp9hFA
EbDDK7VGDiR+n99vU0msfC3wb4huNOuNU8KaLqM+mztc2Ut1YRSNazM4dpIy VOxiwDFhgkjP
Wh2urf1/X4mavbX+v6/DofPGi/FTxt4VtS99rmja1dXl5qVpY3M0dxBDZsdW htV88G4cShDK
SBhCAojDLlmPS6b8VPiXrviC/wDCVle+GYtY0r7aLvXZdLne0uDEtrInlWwu QwBW6KNmY4aP
IyDtHsp+GfhFp9WnPhfRzNq6umoyGxj3XiuAriU7fnDBVB3ZyFGegqfw94D8 NeErG1stE0DT
NHs7WOSG3gsbRIUhR23SKiqAFDMAxA6kZPNC+Gz3s/v6fd+N9dkaNq+i6/h/ X3dDxbwj8cvG
PiDxtokep2+maJ4e1W2i+xr9iluvtczWfnyf6XHLttyjHb5U8Kb1G5HYkqvN arpPjf4n+OLa
5hWw8ReV4f064nk0bx9quiacJpHn3vbrao4mRtowz4OFXrX0HYfCvwZpfiE6 9ZeFNFtNcNuL
U6lBYRJceSFCiPzAu7aFVRtzjAA7Vr6P4b0nw9Gkel6ZZ6dGkKWyrawLGFiT OyMBQMKu5sL0
GTjrWjlG90rf0/n/AF2FdKNl2X9f169bLxbxX8fNY0L4f22qWEWlT6rJfatZ rbzM2w/ZFutn
Rs5zAgY89W4HGHXXxI+IOl6/N4Tu7/w2NavprU2GrjTpltLSOZLhyksJuN0z gWzKGWSMMZAd
q7cN6e3wo8FPrd/rDeEtEbVr/wD4+746fEZrj5Sn7x9uW+UleSeCR0NXfEHg Tw34tsryz1vQ
dN1e0vEjjuYL60SZJ0Ri0auGBDBWJIB6Ekis5WevX/g/1qLZ6ba/8D7jwvxB 4o8c+HfiTfpq
HiXStUsLe20IT6daWVxbM8s13JG0sRF0dina2VIfcAqsSFO6ra/H7x6Y9Cfd 4a1FvFNrbX+m
LZ28wj0yN7u3haO4k81vPbbcgq6rEC0Tjbg/L7pF8L/B0EulSx+FdGSXSYRb 6e62EQNnEGDB
Ijt+RQVU4XAyoPYUulfDDwfod9qV5p3hbR7C71K4S7vZ7axije6mRi6SSMFy 7qxLBjkgkkc1
UWlpLa/4f1r5bbMG9HbfT8DyjxB4n8S+IPBWr+EteuNNvNck1xNFku9NtpLa C4t/KS5mIiaS
RkPkeYn32GQDwDgcZ8IovF3w88L+H/FWrWCJBqkenWhv73x1qmsGb7TcQIWN pcIsULEOSGRj
tOFAKk19H3PgbTLjxNaa35flTwLNuhjVVjmkkVEMsnGWcJGEBz91iCDxi7fe F9G1Pw9JoN5p
VldaJJD9mfTZrdWt2ixjyzGRtK4424xilCXJra70/BWa+e/z17IeunTX8/6+ 71PHdW+Knjbx
B4/1rwz4VuvD1ilh9qb7fqFpLd48mOzcIY0mj3Em4kBO5cYXg85m8JfETxr8 TbefUNO1HQvD
+nWtjF9p0+5sZbq6lnltEmEiSieMJGDKoAKMW2NyuRt9R8P+APDPhOGOHRfD 2maRFHGYkSxt
I4QqEKCoCgYBCIMf7C+gqu/wu8HSa9puuN4V0ZtZ0yEW9jqBsIvPtYgCAkUm 3cigMwwpA5Pr
Wcopx5fJa+et3+WgJ2d/66f1c+efAfxR8dW+j+FtHbX9Bvtf1zT9LWDXr2C4 a2jEkN3MS0Bu
T5shW325WSMuWLE4UJWtZfHP4ia7outajYjw9aw+G7L7Tf8A2iynk/tJ47m6 hlEGJh5KP9mD
o7ebtD4IfGT7Q/wf8CyaNqGkN4N0FtK1Bt95ZHTofJuG3mTMibcMd7FskfeJ PU1rWngzQLDT
m0+20TT7exa1SxNtHaosZt0BCQ7QMbFDEBegycDmt3JSbbW7v/wP636idrJL +v6X3dDgfGnx
I1fwf4ysrXT5rXxQ1/HHI3ha3jYanAhDAzxuuUERKbR54iTexzcKNqV6qhLK CQVJGcHtUNvp
9raTTSw28UUszB5XRAGkYKFBY9ztVRz2AHarFZ3VrC638l/w/wDX5hRRRSGF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAea/E3/kZfD3/XY/8Aoqat/wCGP/IpJ/193f8A6USV gfE3/kZfD3/X
Y/8Aoqat/wCGP/IpJ/193f8A6USVT2A3dcfy9Gvn3bNsDndu24+U853Lj67l +o61dX7o+lUt
cdo9Fv2RZHcQOVWFWZydp4UKykn0wQfQjrV1fuj6VHUBaKKKYBVDUX23emjd t3XBGN2N37tz
jG4Z6Zxhumccblv1Q1J2W80wKsjBrghiikgDy35bBAAzjqCM44yQQmBfrzv4 qa7caTcWax6d
qmtRC0nn/szRrtLW4ndZIEUrI8sS4VZHJDOAQOhIUV6JWR4h8KaZ4ojiTUYG kMROx4pXidQe
o3IQcHAyM4OB6CqW+omec/DXxhd6n4gji/4R3X/D6SQTGTTtb1CG7lfa8AWV WS4mVVAlkyAw
Y4OVOEzzf7Yfw48NfF74UaNp3i/RpLiyh8VaG0cE1wYjmW9gt5OYn7xXE0fX gkkchWr2Pw94
H0bwvcSXGn2zpPIuwyzTyTMFzkgF2O0HAyBjOBnoK4D9pn9mbwz+1T4H0/wr 4q1DVdO0+y1G
PU45dHmjjlMiRyRgEujjbiVuMZyBz1zvSqRp1o1GuZJp2fXyFZtWOD/ac/Zj +Ekn7O3xCdPh
74csZbXQ7q7gubHT4raaKWKJpI2WSMKwwyLkZwRkEEEg+7eG/D+n+Bvh9pmi 6FB9j0vSNNjt
LKEO0nlRRRhY13MSWwFAySScck15J8Tv2N/AvxX8Fan4O1PWfG0FpdpCZZV8 UahcABZA64W4
lkhY5j5DIxHBGDtNet+BfA9h8P8A4faB4QsZZ7jS9F02DS4JLpg0rxRRiNS5 AALFVGSABnoB
XRja6r01CM3Nq/vS0etrLeWitffq9O5Bcru0eF6R8dPEXhfwh4Tm8TXMuo33 knUbqWGCJH1S
0NhNOu0YVFcSR7CF2jKqTtD4rpR8efFcWot4YuvBemx+O5pLc2mnw62z2LQT RzOsstybcMhA
tpwVWJ+QmCQxK97qHwq8E65b6HaXmj2V9HolvLZ2Ec58wxQyReTJGck71ZPl KtkHAJ5AIx4P
2d/AsWiz6UltqbiS4juvtr65evfxSIpVPLuzMZ41VWZQqOFAdxjDtnjbi2/w +/8Ay/4Fty1Z
LXf+v19OmrtZ+QaT+0/4k8IwWejXPg+/8S6ws91daqdPXUL5beNr64jWK3kh s5BIyiJgBN9n
XATBxu2ehfGn4m6x8O/Fnh/Vorm4XwvY6ddajrWnw2yyvLAskCGQfKXzEJWk wh5CsMMcCr9z
8G/hzBPZiFNT0m5sC6CbStXvrOWQGVpWWZ4ZVaZfMd2CyFgC7YxuOe2kuPD0 2tW2rO27ULa3
e1imIf5Y3KMy46HJjQ5Izx7mhtNp26v8tP8Ag/mGl9tLL/g/1+B4TL+0R4t8 G6Hq1xf6dba/
rsurv9n0NvtIntbP7NDNtVLO0uJH8syqrOyBQXGXGVB3T+01q02nL4itvB0T +Do7yxsri9l1
PZeq10luY3S3ERVlVrlFfMikBWKhuAev8R/DvwD4o1Br68W9hvHna4knsNQu 7RpWZERlcxOu
+MrFGDG2UO0Ermub0P4F+AtF1q91EXeoTI00Ullp7X159htRHbxwxZtTIYZH XywwkZNwO05y
oNTGyVmtkvwtf7+/q/INLr53+b/D8fRmVJ+0h4gQ+GxrPhWPRIPEVtb6jpc2 n6qtzI0Xn2yS
x3CvABG2LlMbC+4B/mQ7TV2D9o7xDBpun3epeCba0bXbCC70KCHWRI80kssM QiuSYlWHD3EZ
3IZflDnG4BWv+Bvgn8P/AAdodnZzz6hrd3DDbxG81PULy5KmJlceSssj+Qhd FYxx4U7VBBCj
Gt408A+FPEng4aNY/Z7S4ttO/s7T57pLmVLVN0bKcRyxuWVoY2V1kV1ZAVYH mrlyLZN6v5rX
8drdOrXQN32/rt2+d+zXTofhn4z1rxVa63F4i0ey0XVtJvjZzQabfvewt+6j kDLI8UR6SAYK
DBHU1wHi74z634i8G+NtR8I26abZ6FZXQe8uZYzqP2pYQ8apaMD5P31b/Sdr grgw7XDjd+CX
hKz+E3ha60+88Qy69qV7dveXV7L9qcM5VUAX7RLNLgKij55XOc4IGFG74j8P +CPFl213qdjB
PeNbSWTXSI8czW7g74TIuGKEnO0nG4K2MqCJlFcy7W/G2/3/AOfkFOVtWtb/ AIX/AMjgvhV4
t8WaJqlhZeKLfxrOdZultoJPGD6MvlbYJpWaEacOf9WAwkx1Ur0YU6//AGiN eZ9dm0nwbbXm
n6CjXOo3Fzq3kt5C3NzC3kqIW3yYtiwViineBvGMnvPGmieEvH+l21hq73Pl 2sont57G5uLO
4gkCld0c0LJIhKsynawyrMDkEis/SfAngDRNI1LTLSzMdlqVubW7jaWdjLGX kcgsTkEtNIcg
5+brwMNtS1aJtZW/r5HM+Mfiv45u/BHjPXfDWg6Tb6Rp9rdrp+pXequt1JcQ sUYtb/ZnRU3L
JgmRidq5Ubjtq23xq8aC7u9GtPCthqnimKSWW4tbjW/KsbeGK3tncRzi18xi WuFCq0XPzkso
CrXUt8OvAL6jrV2wvXj1iCS3vtPbULs2EqyACQ/ZN/kqzY5dUDEknOSSc69+ Dfw0v9MhspU1
MGKRpBex6xfpetujSN1a6WUTMrJHGGUuVbYpIJANZxTW/b8f6+/y3NE4318/ y06/8NvrsZvh
/wDaM1PxWbLVtL8KRP4OlvrKyk1G41Ly7v8A0qKB4njtxGQwBuFVw0ikbSV3 8CuK8f8Ai7x3
rPxbuIvDV34yGkyC6t47Xwk+lM7C2+zq0rDURsUebNOh2fM2xCeAMe2Q+HfB Vrp0tlbWsdvb
SXUF75UQkVBNCIxEwA4AUQx/KMD5enJzD4M0LQPCtnpTzXYvtYsreaF9QWJ4 xK00gknbZkgb
pFDckkdMnnN2jzXSdtfxSt9zv8n3RCul936/8D7tjJ074tXWkeDrma/0y9lv tL1Cy0iddTnh
F1I8yW5aSXyF8oODOcrHlCVO0gEYwtO/aG8QtZWNzqfgu2sf7b02K+0OGHV/ OeaSSSGIRXP7
lRD89xH8yGX5QxwCAp6TWfhv8Pte8Ty69eRXTX00sVxLFHfXUdrLNGV8uZ7d XETSDYg8wqWw
oXOBiruo+DfAmq6Ra6Zc2pa0tbA6ZAqyzK0UBKHCuCGDAxRkODvUqCCDzQ9d WtfL0/8AktV2
XfYeidun/B/y0/yOC8d/E/4m+GdVsReaJotjajQdQv8AUYNO1tpWiMTxBHhe Sy+dgGHysqr8
7ZztG6XXP2ltV8OxXOp3PhCJ/Dkr31npdwmp5vLy6tY5XdHh8rZFG4t5tr+Y x4Xcq7jt6O6+
Ffw9v9N02yvH1W+SwSeKGe71i/muGjmx5sUkzSmSWNsKdjsygqpABUYenwi+ G91rt9fCynku
NSWWOS1N7dfZQ0wxK8dvv8qKR+d0iKrnc2W+ZskbJJS8/wAdvu/q+yem/p/X 9el1uW/Dvj3x
fr03iPSrrQNK0bxBp0MF5Zx/2k9zbXMMpfYsknlI0TnynVsLIEyrAycrWt8N vibb/EJNTgFk
9nqOlzm1vEjkW5tvNVmVhHcRko+GVsodsqjaZI49yg6upeA9D1dtSN5Yi4Gp W8VpeI7tsnhj
LFY2XOCvzuCMYYMQ2RxWvp2m2mkWMFlY20VnZwIsUUECBEjQDCqqjgADgAUl ZX/r5/1+BGtk
v69Pv/p30s0UUVIwooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooA81+
Jv8AyMvh7/rsf/RU1b/wx/5FJP8Ar7u//SiSsD4m/wDIy+Hv+ux/9FTVv/DH /kUk/wCvu7/9
KJKp7AbuuJ5mjXybd+6Bxt27s/KeMbWz9NrfQ9Kur90fSs/xE8cWgak8pURL bSFy4yoG05yN
rcf8Bb6HpWgv3R9KjqAtFFFMAqhqKbrvTTt3bbgnO3O3924znacdcZyvXGed rX6zdVkjS+0g
OVDNcsE3DknypDx8p5wD3XjPP8LJgaVFFFMAooooAyZbmOx1i5lkjlIaCMbo oGcnHmtj5Uz0
zxuPJAABYb531aE70Ec+7kfNA4Xjd3xjHyHnOOV/vLlkEkZ8Q3qAr5otoSwA +bBaXGTt6cH+
I9+F6toOu9GU9CMUkB+Tvhv4x2UEN74n0fwdoHh648ZeHvEs2jDR/C40ufwt JZWs+x7XUljX
7W0iK3mFCCjEY2D5D9f/ALDPxUs/iFo2p2N94ehsfHOmaPoMmta/HILiTW45 7BZLaaacosjy
hd4ZX3BM/K7gnHQt+x3p5sLCwHjjVxYafHcw2VqNC0DyraO4BFwka/2bhFkD EOBgMCc5zXef
Bf4JWPwS07UbDTNXub+xvJVm+zSadp9nHDIBhnVbO2hBZgEBL7jhFxjnP3WZ 5xlOLwk6GGwn
JJu8XdaWk7bWv7lo6rV+825Xb5YU6kZXcr/1/meIfGP4q+JdA+LeoaDpd/Hp 9lFbRXJI8Haj
rju0kkqnL2sirGAIxgMMnJPaptE/ae8Ia78QrjwdayGbUonngSQXVr++nhDG SIQ+d56EbH+a
SNUO3IYgqW9dufBbw+NNY1yKC6e4vkjt3G3MeyNpCpXjqfMbPPp+PAzfs9tL LrVv/a+vjw9q
y3IuNAMUDWoafcZGV2hMwyzMwXzNoJwBt+Wvi07K3r9/T+tvQ7fdf4fd1/r1 6nEQftS2nifw
veaj4V0K51XULHU7OxudNhvLC5fZPKF3LJFdNFkjcADICDgsoU5Pa6p8atI0 XwnDr93YajHB
JLdQm3WNHmR7dZWkBCsQf9S4GCckj14ZD+zpJ/Zmow3eu+I77ULwWuNUkS3j ngNtK0kLRrHA
sQ2s3QoQwA3A85rzfszLeebDd634lutNMlxPFp7+SIoJJ0kWZ1IhDksZXbDM wUkBQqjbVXjq
v62X63+/czXd/wBf1oYnjH9qjwt4A1DTbDxBZ3ek3t3ELmW2vLuyhktrcyMi SsrzgyBtjNsh
8xwAAyqxCn0O48Szp460vR41jazu9OuLxnIO8MjwqoBzjGJGzx2FVvEnwZvd a8RQa3p2sa74
bvhBHbXB06KCRLqJGLIrrPDIBgs/zIFY7iCTgYl8ZfCXVPFOs6ZqtlruveGb 6xhktxLpcFu/
nRuULK4nglHWNcFcHrRFrS/d/lp+OpT127L7+v6/K3mecfET9pHTNC1fxP4S tllsfEljp89x
azi5s597pD5oxAkrzL8vI8yJQcYycrmzrv7T+g+DtMu38SaVqOg6nbywxJpu ozWcL3IlV2jk
SVp/JVWEUv8ArJEOYyMbiobW1D9l6HUmvY5dX8QpYTy3VxDYxR26xWstwkiz OhEG9iTM7fvG
cA4xxxVl/wBnB7iBri517xJdeJBLFJF4keO3W7hEayKiBFgEBQLNKMNEc+YS eQpCTXKu/wDw
f8vkPTm8tfy0v5X+f61fhx8W4fiVearqekXIm0UaXb3NvETG/lzGS4SUF4yy thoguVZl+XKk
g5PH6B+0NrWp6T4fs5bbT28Tvd2h1eOON1hhs53jEcqKWJBcTKFyxGUl67CK 9i8OfCy60GS6
uLi71XWb+6tI7Oe7vYYleRUaQq22KNFB/ekcKBgDjqTXPwU086BY6WNOuV+y pZxfbFiAuJkt
nDxK7heQDnjj7zYxmqbjzXW11+bv+nqiN467/wDDf8H5nA237Ufhu51zXNGX Tb6TVtLnS3Nn
a3NldSzs06wDCw3DmPDuuRN5Zwc4+VsWov2hobm6n0228FeJrjxFbGYXWiIt oJ7cRiFiWczi
EgpPEw2yNkEj7wIFbU/2V7+LSrO30jxFr0c9k0EFjJPFbKNPtVuIZSkSrb7W ZRCAplDk/wAR
PUWZv2atdj8R2uoWPi3xFY3EkNz/AGnq8cNqb2/lk8hUDBrYxKqxwhfkRCNq 9SWJmNnFXeuv
39H1+fnsVpd9un9fl+JDp37Rlhq679G0TWPFBuYjd2sGm20ULiBYrd2LNNMi 5H2hT8xQ9QFJ
XLaMfx8069vrJdO8Pa3qWlTy2kE2sRRwx21rLcBDGjiSVZGOJYydiMBuwTkE Df8ACvwD0zwZ
ffaNKtL+BBbvapbkZjjjaOCPAyu7gW6cknktnORjz+4/Z08X6f420m30Ge50 /wAEQzWV1fRS
XaO91LbqgVjAbMsGYRRKSlwi8bthOQ1rk50umn/Bv8vncmV+Vtdn/wAD5/ga nxO8XeKLf4oe
FfD2kWmsw6PJbTajfahpP2HL+W8aiJ/tLZEeHYuUXf8ANHtbh8c7aftVaH4k jh1GwklsLHSr
qX+14PPtL1jAtpPKCHtZZk6xZwGDfLyACM+xeLPhRB4zknbUbW9KTadcaW8a LhTFNs3nkdfk
GO3JyDXK2n7N7wzteXOv+Jb7VvLEaajIlvHLHtjmjQqscCxgqLhyPl5KrnPO Yi0lZ76/fd/p
Yt2bT/q1vzv18tjl9c/ay8N+GvDulapq2k32myaoWezs7u/06IzwKqMZ0ma6 EDpiRMBZSxyc
KQrEe0+CdesvFNroesadMLjT79Ybm3lHR43wyn8QRXmdj+y6ukp9p03XfEOm 6+9zPdXGuWtt
ZpPctMEEgki+zeQc+VGd3lBspndktn17w7od9pz6dFMt1cmExq9zPEFaTGMu 21QoJ6nAA9AK
d42ff+v66a30ttL6W/rX+u56PRRRWABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAea/E3/kZfD3/XY/+ipq3/hj/wAikn/X3d/+lElYHxN/ 5GXw9/12P/oq
at/4Y/8AIpJ/193f/pRJVPYDd1x/L0a+fds2wOd27bj5TzncuPruX6jrV1fu j6VS1x/K0W/f
fs2wOd27bj5TzncuPruX6jrV1fuj6VHUBaKKKYBVDUX23emjdt3XBGN2N37t zjG4Z6Zxhumc
cblv1Q1F9l5pg37d1wRjdjd+7c4xuGemcYbpnHG5UwL9FFFMArO8Rat/YOga lqXled9jt5J/
L3bd+1ScZwcZx1xWjVLWtKi1zR77Tp2dIbuF4HaMgMFZSCRnPPNAHhiftJaE nxE1/wALweN/
DmpeIdJskuJtNgAVrhlNx5ltEPtLETxiBzINhKB4yc9B7pDq9lPIkaXcLSsd ojEgLZ+bIx6/
I/8A3w3oa8pb4G3N54o1TU7rVoftGo2VvY3lzDZlGmt42mKRrmZgrKZpTu2/ 8tBndjA9gVAi
gADgYqpW6CV+p8oa/wDtfXj/ALTHiX4Ixarovg/XYLq0/sXWNX0+S9tr1JbW ORrV0WeEpOZJ
Mo+7aw+Tbv2l/Zvgx4s8Ua9e+OtH8WXWl6hqPhzW102O80ixks4po2sbW5BM TzSkMDcsud+C
FBwK4jUP2VFs/jZ4n+Lfh/U9Kj8d6vNAlvda9pL31vp1qlqsLpDGk8RErlcm YtwhKBRlmb0L
4S/D3W/A8vi2/wDEWuWOu6x4i1ZdUnl07T3soIttpb2yosbzSt922DEl+Sx4 GK9nNJ5fOVL6
hFq0Ic99nPlXNbra/wCN7aWIhz68/f8AATxn8QPEFt4oXw14N8P2HiDWYrVb 69bVNUNjbW0L
syxgukUzmR2R9qiPbiNyWB2huf0L9oOxi8QanofieJtJ1aG/jso4re1nntoJ HtoZBHPdIhiR
y8pVdxTf8u1STzveM/h/4jufFa+JfBviSz0DVZrVbG9h1XTmv7S5iRmaNvLS aFkkQu4DB8EO
QythCtR/g7dXmg6nZ32ui5vdQ1W01We7W0CAvCsAZQgbgMYCevG/occ+Iv6+ 9bfK/wDw5rK1
9P606/MxLD9pPSbfStQvNXLPK9wE0200TT7vUJ54/skEzP5UUZlKKZgDIY1A DIGCkjOhe/Fj
xGfAXgDUtH0TS9V13xOsWbfUNQk0+2iLWzzsd4imb+AgLtPXk8ViaV+ztrXh M2Vx4d8XWtrq
EcZtJ5L7SjPFLbNb20ThUEyFZM2qsr7io3MCj8EdHq/wD0PxT4O8EeGvEkVl 4i0vw5sMtvqN
kksV4VtnhBKMSFOX3jrgjHuNJctny/3f1v8Ap/Wouq9H9/Tt+v6DLD9oTQ7X wfp2r+ILe70+
/ubi6tG03S7W41STzLaZoZ3jWCJneAOvEpRRh03BSwWuZ139pCG3+LI0e3u/ sXhSw0y31G61
B9AvbxdRNxv8qK3uI8RI3ypt4kMrSeWi71Iql4o/ZQbXtO0O0bUfDusweHzP a6RbeLPDa6pb
wWMgjxDIvnIXkjMaqkwZTs4dZGy56TxT+zrZeK/C2p6PPNplvDdadptnHaRa UhsIns5GkT/R
mYq0DFgphyMICA+SGBJwu5LvovL/AIH9dzRct1F9d3297/L/AD30N7TPj94L 1eXTILa9vje6
g7xw2Emk3cd0pRo1cywtEJIlXzYyWkVQFcOTt+aq8P7SHgCWO8kOrXMUFu0Y WefTbmKK6Eki
xo1s7RhbhC7oA8RdfnTnDLnO+F3wFj8AXMFw6eGbIpb3dvJa+FdB/sm1l84w neY/Ok+cCEAt
nkEdNvPK+Av2SrXwLOsdt/wiUNtbzWzW9/pvhZLPVZY4biOYLc3KzbZiwjAY iNAWw2OMUrRb
Sv8APt/W/wDwxF1yt21/r+v609A/4aD8GHRIdSSbV5vNuXtBp8OhXz6gsiAM wezWEzoAGUlm
QDDoc4Zc6Gi/Gfwp4g8WHw7ZXl0+o5dFkk0+4jtZJEzviS4ZBE8i4YNGrllK OCAUbGDrHwh1
628VXvibwr4ksNK1u5upJCdU0try38iSKBGjKJPExbdbIwcOMZIKnrWJ4D/Z rg8DfE6fxRHD
4Qu0muri9+1t4YVNZSWfczgX4m+5udgAYy2zClj94zCzfvdvxtt9/wDXVjso trf/AIL/AEt+
fkeoeL/Huh+BreB9XvfKmuCyW1nBE891dMBuKwwRhpJWCgsQikgAnGAa5qX4 ++D7PXodFvrm
9sNSa4is5lm0+doLW5kRGjgmuURoI5GEkYUGT5iwC5JFbPi/4b2Him+j1SC7 vdB8QQxiKHWN
KkCTqo3YV1ZWjmQb3ISVHVSxYANzXmQ+C/jHxT4i8Q23iDW9Li8HXms2upSW lvpji8vHgit2
V0n+0FYkM0IyhjLbVI3fMGBDV2l/Wq/S/wDw12N8tv6/r8V6o622/aR+H91D ezLrE6W9s0QE
82nXMcd0JJREj2ztGBcoZGVd8JdcsvPzDNO7/aT8MaV4m1HTNSttYsLa1020 1FLuXRr0eZ57
MqQ7fJyJSQirF/rGZioTcpFYek/s46ol/o8ms+K4NTt/D0cFpogh0wwSxWqX MMzLcN5pWaRh
bQrvVYwMMdhzgbnxM+DWqeNtW1e5sdV0RbDVbC2tLvS/EOhDU7Z2gmaSN9vm x5Uh3DKcnIRl
ZSp3N8qSa/r+vw213HaPM10/4K/S+6Xp33E+L+kaxp1uNDMlxrN/Y3d7p+n6 pbXFgZRbsqSC
XfFuhw7op3Ju+bIVsVzWhftJ6JD4c0e58XR/2Jrd7ZQahcWGlxXWpQ2VvOX8 mWadIFEaEIdz
uFRSCC2ACdDwz8LfFXhbw1YaXB41+1tBY3kMx1C0kukmuZnDRS7pZ2mEcXzq IzKSVYAv8oNZ
3hv4EalYeCNU0TV/EVrf319oMGhG8tNOa3jRYvOCSeW0rknbKoI3dVJGA2Fq 0dde35yv+Fu/
5pS9lbfX9P8Ag7FfSf2gb+LW4pPEmjaRovhS8vb+ys9Vg1lpp1Nr5zPJcQtA ixRlLeQlhI+0
7AepI3rX9o7wLdWK3K32pRO9yLSOyn0W9ivJZDE0qhLZohK4ZEcqyoQ2xgCS CKqaL+zf4T0b
w34msodOsbbWvEC3kd7r9jYxQ3siTyO+GkwSxTcAN2QdgOO1V/C/wQ1i28aW ni3xN4ks9Y16
3liTzNP0xrOFraKG4jjj2NNIQ+66kdn3YPACrjNC5Xo+i+93/wAvJfMH1fm/ +B6fe/le60IP
jxplwPiEhsNQtn8IF/NkuLG4SG4AhWTKSNGEZssRsQscAHowrH8N/Hm/0pNV T4haZY6NJaXy
aZaHQ5bnUZtRuPs32hwtutuHQ+WchFMhJDDJwC13xB8NNe/4SPUFtb2O/wDD viDWbS/u7U24
SWy8lELkymT543NvEoQR7gZGO4r92XQvhFrtr46u9c1XxFp97ZnWm1e1s7TS 3geIG1a28t5G
ncP8vlncFXlW4wwCxDVO/b8Vb87vrbToEtP66a/k1r11+Zg69+0ldRy3mqeH dE0/WPCGmadF
qeo317qUtjfJG0kqPHFaNbndKnkuPLkeM7vlO05NdZP+0P4EtdQ1O0uNXmt/ 7NhmmuLqSwuF
tP3I3TIlxs8qSSMZ3RozOu1sgbWxmeGP2b/DOk+M5/E+r2GmeIdVVi9jc3mn RtNYsbm4nzFI
24qczgZXH3Ae+Bi67+zfqXiGe5sbzxVA/hmKe/vtMsxphF1a3N0kquZJxLtl jUXE21BGh5XL
tty1rl29dfy/q3zDTVvy/wCD/V/k7WfVxfHXR7rxv4c8P22n6xKuuWlzc292 2k3aIhikVMPm
HCK24kO5VSAhGRIpPR+GfiNovijUrnSoZpLLXLUFp9Jv4zBdRqG2+YEb78e7 KiVN0bEHazYq
rrPgnULrxr4c8QadqsNmNOtp7K7tLi1MwuYZDGx2MHUxuGiXDHcMFgVyQQzR PhlbW+vp4g1z
ULrxJrsTM9tPeELBZZDDFvAuEjwruokIaUqxVpGFTG3Xz/PT8LX/AKvLvbTf T/g/1/wbdpRR
RUjCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA81+Jv/ACMvh7/r sf8A0VNW/wDD
H/kUk/6+7v8A9KJKwPib/wAjL4e/67H/ANFTVv8Awx/5FJP+vu7/APSiSqew G7riebot+mzf
ugcbdu7PynjG1s/Ta30PSrq/dH0qlrieZo18m3fugcbdu7PynjG1s/Ta30PS rq/dH0qOoC0U
UUwCqGopvvNMOzdtuCc7c7f3bjOdpx1xnK9cZ52tfqhqKbrvTTt3bbgnO3O3 924znacdcZyv
XGedrJgX6KKKYBVLWtUi0PR73UZ1d4bSF53WMAsVUEkDOOeKu1neI9J/t7QN S00S+Qby2kg8
3bu2blIzjIzjPTNAHBSfEyTT/E+t21xb6Wb7TdNtr+/toL52ljtXecRspNuo dmMM4CF+CnO3
dk+mK4dQQRyM181xfst2zfErWvFUfhzw1p2uapbJDPf28ILwlmn8y4jbyFJm kE7iQ78uFjDY
HJ+iodIsoJEkS0hWVTuEgjAbPzZOfX53/wC+29TVNJbCXmeE6h+1Wt58bPE/ wk8P6ZpUnjvS
JoHt7XXtWext9RtXtVmd4ZEglJlQtgwleUBcMcMq+hfCX4ha344l8W2HiLQ7 HQtY8O6sulzx
adqD3sEu60t7lXWR4Ym+7chSCnBU8nNeHa/+yDeJ+0x4l+N0WlaL4w12e6tP 7F0fV9Qksray
SK1jja6d1gmLziSPCJt2qPn3b9oT2b4MeE/FGg3vjrWPFlrpen6j4j1tdSjs 9IvpLyKGNbG1
tgDK8MRLE2zNjZgBgMmvZzSGXwlS+oSbvCHPfZT5VzW62v8Aje2liIc+vP3/ AANTxv8AE8+F
NXttH0zwzrPi/WpYjcvYaMsCmCDO3zJJLiWKJQW4C797ckKQrFc7w58dfDur a3caNqd3aeHt
c88Q2ej6leRx3t1/o8czbYiQcr5hUhdwG0nNReLvDPjHRfHsvizwXaaLrEl/ YRaff6brV5JZ
ACJ5HiljnjhmPHmyKY2TBypDLtIfGuPg5rGq6Prr3qaRFrWr65YaxLJb7tg8 lLYOu4ruJBhc
LnsVyRk48Rbf13W3y16/LZaytfT+tNb/AD0/z3NiL9oDwtZaFquseINU0zwv p1pdJaQXGqal
DHHcO9tHOoD7thYiQjCswO0kEipL/wCMxs/BPg/XLXwvqmv3niVYjbaXpEtu ZFLQNMcvPJEm
0Krc5BPGBzXnOgfAnxp4JudN1HToPDus30UD2MkN/dSwpFFJa2cTzRuIXJYN aH93tAdXGXQj
B6/VfgdP4l8EfDnw/ql9Nbr4e8s3s2kajc2MrFbSSH9zLCyOBvcHBIyuc56H WSjZ2f8AL+t/
0++3cV9V6P8A4B0lr8b/AAfH4MtPEuuaxaeEbGe5ksWXxBcxWrQ3UbukkDMX 2F1eNx8jMDtJ
UsOa53XP2jdD034vHwRDqPh2NbHTxqer3Wp62lrLbwsrsvkw7G80qsZd9zRh EdGy27jz/wAS
fs5eLLux8OwpFp+sf8I8LyxtxD4k1DQpb+2naJ/tE89ohYT7o8SLh0lYmTMZ +QdF4q/Z4vNc
8IajpVilppqtpej29naLqVz8kljM0vlG6XbMFPyqJh84+/tJGCpcl3JbX/D8 /O3y0a10SjdR
fX8Pe+Sene3e1j1Gx+LXgjU9P02+tPF+h3VlqUnlWVxDqETR3T+YI9sbBsOd 7BMDPzEDqaLX
4t+CL2bVobfxfoc8ukSiHUY49QiZrOQsVCSgN8jFgQA2DkEV5p8KfgTd+GNd t9Y1DR7PSbkW
19FKq+IbzXJjJN9mCyLc3cauPkt8FeAMLjOTjjfA37Kuq6EllY6jpVhPHpj2 cUGqTeKdSv1u
IIbqCVgLC4QxW24QKQsbsFKhQdvNJJNpXtf8P+G3809rqxGnK31PdpvjT8P7 fwrb+JpfG/h6
Pw5cTG3h1d9ThFpJLzlFl3bS3ytwDn5T6Voad8R/Cmr+J5/Dlj4l0m88QQQi 4l0qC9je6jiI
Uh2iB3BSHU5Ix8w9RXm+p/DHxX4e8c3/AIr8NWGg6zc3F7Oy6bql7JZxiGWC 2QyeYkEpWQNb
YxsIKv8AeBGDi/Dr4A6t4S+KbazqGmW97YrqN5qdvqSeLNSJhkuDIzKNMZTb ZHnOm8MMj59q
sdomFm9e3422+/8Ay3B2UW+v/Bev5aed9j3TX/EWl+FdKuNT1nUbXStOt13T Xd7MsUUYzjLM
xAAyR1rEj+LPgx9bsdFfxPpdvrl8M2+k3N0kN5J8gfAgch8hSCVK5A6gVneP vhg/inXNM8Ra
ZqKWHiHS8mza/the2YJV1yYWIKHEjZeF4nb5Qzso215TcfDTxp458S+KdJvN A0bSNAvPEVhq
txrgvZTeeZbxWkmIITbhZF3wiMSmVSBuO3K7SQXM7P8ApXX6O/yt1Q2la9/6 9P6+R7Ra/Fnw
TfSavHbeLtEuJNIlWDUVi1CJjZyMxVUlAb5GLKQA2CSCO1YyftB/D0+Ib7SH 8W6PBNaaZFrL
Ty6hCsT2kgYiZW38oFUMWxtAdDnmvLdK/Z28U3snh211q38O22neGILXT7Ma fNI66lDHeW87
TTxNEBC4W2XbGGkG6RvnGMnqPi18J/EHirXNal07SNF1rStTsrFDBfatdaXP DcWty0qMk1vG
7LnfuDqQVaMcOGO1tRSTvv8A1f572/7deuo7Lma6afmv+D+Z6LH8U/B8+ix6 vB4n0m502W0m
v4rqC8jkSW3hx5sqFSdyJkBmGQMjPWuc0P452l9qkNvrfhrXPB9ldxST2Gqa 4kCW14iLvYgx
yu0J2fPtnEbYDcZVgvPaV8IfFGpeFrPRvE0+j3M1zpepWl/q8cSPqFtJcSK0 awSJDFG6Abt7
GJN7RxkrnNU/Ffwx+InxU0yPS/E48OaPb6XBcfYbvTbie6e9uXt5LdJZI2jj ECBZXYxhpSSw
G8bMvVop6v8ArX/gf8HoJJ2TffX7rfJ9eq8uvo/xB+LnhT4YaZ9v8Q6zZ6fb rPbQSNNcxx+V
58myN33sAq8McnsjEZwa5/wr8ftP8Ta7b2j+HtY0rSb66uLPTdfu2tWsr+aH eWWPyp3kGVil
cGREBCHnJAPNX/w3+IXiSHWNW1Gy8N2OtyDSms9Og1Ga4tmazuXmZZJzAjKH DABhEdpJ+Vsc
rpn7MtlL4N8Rx6k7/wDCTawupBZJ9Rur+xsjdPKcw28riNPkk2t5aIWBYZwx zKtFNvX/AIZW
/G/p1WxK96y2vb/g/wBde6PRLP4z+ANR0OXWrXxt4euNHhma3k1CLU4WgSVV 3shkDbQwX5iM
5A56VStPjj4Q1Gbxpb2usWk154SDHU7YXEZkiVYhIXKhiVXkrlgPmVh2rg/D PwY8Tal8QtM8
X+KLHQNNns57dRpel3Ul1AscFtdRpMrPDHiVmusbduFSMfMx4q/4k8GeIYNc 17SjY2t14f8A
Fet2kwurYyNNDEsUf2iOePZsWMrbECQvhjKFKg43EklKye609dPu6t329QXe 22r9Nbr/AIPz
sX4/2h4VjS6m8I65Lotuywanr1kIJrHT58hZY2zIs0gjY7XkjhZVw2SNj7fR Lvxlodlph1CX
VbNbTMoWUzoFZowxkUHOCVCPkdtrZxg15TrHw08ctpGu+BtPGhzeC9bmuWl1 i7upVvrSG5dn
mhW2WLZKfndUkMyYDKSrFDvbofwt8aWmtaXpt0miL4Z0nVb7UIL+K6la7uEu EuMI0BiCxlDO
BkSPuCk/LnbRKzi+Tfp93+f/AA73Cyju76/h0fz69uy2TrT9rHw3rVpHqeg6 PqniTw5HYQ6l
qOu6XNZy2umQuXDecDcCQtH5bl1iRyNuME8V6OvxS8HNrd/o3/CVaMNX0+3+ 13mnm+iE9tDh
T5kke7ci4ZTuIA+YeoryfwH+zhNPfW1147hhl+waVZaTDZ6RrN4LO7W3aX95 cW48uOQOHQ+X
IsgX5lyw5OV4l/Z48V+I0vdBaLw/b+H4brVdQtNRinkFzeyXiTL5FzB5W1UX 7Q25xI5fykOx
ckLbUG7R83/l6elr9NwS3v5f8H+r9b6JHrA+OfgeTxdonhyHxJptxqGsw3Et h5N5EyzmGQRv
GnzZZ924bVB/1b5wVNdN4c8W6P4ttpp9I1GC/SCVredYm+eCVfvRSL1R1yMo wDDuBXMar4P1
e28f+FNa0i202XTrKxuNOvYLiRoXijkMTLJDtRgxBh27DtBDZ3DbhoNC+F91 L47/AOE08Q30
D60kZt4LbSYRbQxQ5YrHLJ/rbkje332ERO11hRxuqI2e77/np+Fv6ViXe115 f8H+vw109Foo
oqRhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB5r8Tf8AkZfD3/XY/wDo qat/4Y/8ikn/
AF93f/pRJWB8Tf8AkZfD3/XY/wDoqat/4Y/8ikn/AF93f/pRJVPYDa8RJHLo GpJKFMTW0gcO
cKRtOcncvH/Al+o61oL90fSqWuP5ejXz7tm2Bzu3bcfKec7lx9dy/Udaur90 fSo6gLRRRTAK
zdVjje+0guFLLcsU3HkHypBx8w5wT2bjPH8S6VUNRfbd6aN23dcEY3Y3fu3O MbhnpnGG6Zxx
uVMC/RRRTAKralqEGk6fc3t0/l21tG0sr4J2qoyTgcngdqs1leK9Ll1vwxq2 nQMiz3dpLBG0
hIUMykDOM8ZNAHNf8LEjtda1BbrTLy3+y2kNxdRNcW7vawFpcTvGs7HY2xwC qZbymA3YAXuQ
QwBHQ18rL8B9Vn+K/iTxPBaa9Fe6xp8NobW78QyyW9ud11mR4/tTK0R+0HZF 5ZWIxsY1BY19
OwaVFDIkgecup3YM7lc/N2Jxj5zx04X+6uKkrCTueY6h+0fov/Cc+JvBOh6N qnijxl4emgW8
0LT5LWG4MEsKSrdRm4miR4gXWNsNuV2GV2srHpfhj8Tl+JMfiCOTw/qnhnUd D1Aabe6fq5t2
lSQ28NwpDQSyoVMc8ZyGznIIGK+Xtf8A2XNdsv2y/Evx1vdG1vXrGC6tI9E0 bw1e28FzcMtl
HHJcTvLPCogVlaPyg26Qn5l8sESfQPwM0/Xv7V+JGu674bvvC39v+IUvrOw1 Ga3kn8lNOs7f
c3kSyIMvBJgbs4AJAzXs5pQwWHlSWCqc94Qcv7s3FOUU+tn9226Ig5O/Mup0 /jj4reHfh7cW
drqs17Pf3as8NhpOm3Go3TRrgNJ5NvG7iMEqC5XaCygnLAG14S+IOk+NIb+b Tml8mzlWItMm
wyboY5gVU/NjbKvBAOQRiuP8Wr4l8FfEy48UaV4UvfGmm6npsNhLa6Xc28d1 ZyQySurhbiWK
No3ExBIYMCi8MGynF6n8FbvxDc6v4ruPCkNt4vn1+yv7K4kmjkubO38q1S4S OXPyDCSqyqRv
weGDDPiL+vvS266f5mstHZP+rX+Wuh7LoXjzTfEMOry26XEKaZMIZftURiZm MKS8K2GHyyKM
MAQQQRxWTq3xm8O6F4Q0DxFfLqYtNcEZsrey0y4vrly8ZkC+VbpI3CKxJAwM da8Ag+CGu21j
pcXif4eDxxpIUwtosk9rLHDcGys4kunjmkEbhDDOm4FpF3ZRWDE16TffCzxP qngD4U6PZ6je
+E9R0URfbb3TDbSS2m2ykiKgTJJG43sq8KeDkY6jSUUk7P8Al/W/5fL8BdV6 P/gd/wCvvPWP
DPi7SfGGhW2saXdCawuNwVpEaJ1ZWKsjo4DI6sCrIwDKwIIBBFYt98TLa3+I dv4QtNLvtTvP
syXl7d2zQrBp0Tl1iaUvIrNvaKQARq5G3LBQQT83fED4G+K/Efhvw3pWreG9 Y1Ow0e4v01CH
RG0m5Oq3UzpKupLDqIaFQxM25TskieRlTfGSx2PHH7M82t6ZrWo6foEkniCT RNItY9WuxYtr
N0IXYXcLzMjxGWSELG28eTJkIx2ZwSUU209E/wCv63+eholFtRvv+HvW/K// AA2p9TieMgES
KQeh3DmgTxnP7xOOvzDivmT4O/s/Lpd/o0l74d1q10ywivpbaz8Trpi/Yrpp LVomit9P/wBH
UBonkUhdyvvYkFgTxvw9/Zq1ywe4t9V0XxOdRmnshq11dy6Qmn6p5d5DJLMJ LUR3U7bUdg1y
NxV3ByzkFcqbUb7/ANa/1tYjTlcu39f1/V/s37REF3eYm3pncMUqzRs20Opb 0B5r5o1j4KR+
GtRuLf8A4VhD4w8AxanPJZ+EbFbIQQmSC323KW9xJHCArpcgjIYGVmCncxqp 8K/gnq/hz473
HiPVdK8TQ3T3d3MurQ/2MdPltZNxht5JFUX7KiMiiJiyK0S7SURTUwtJ2btp f8L2/r89AatF
y/rd/wBf8DU+o3dY1LMwVR3JrC8N+NdM8VPqf2CXfFY3C2zT7lMcxaKOUNGw J3KVlXn69sE8
l8WvhtqnjS4tLu2ez1yxtlIm8K63I8enXvDD52jB5yykiWOdP3a7Y0b568q8 e/C3WNa1y/1X
V/htJ420K6uZ5I/DrXNoWhmktbRIrkxzSrCTGYp492/em7KBgxNKOt7/ANar 89f1t0pRTsr/
ANW/r9Ln0808akAyKCeQCwrP1jxJpugWkVzfXSQwSTxWquAWzJI4RF4z1ZgM 9BnnFfOth8Nv
E/h24J1fwLD498bppMUWmeNrxbWeCxkWzEbQv5sqTqrSiRj5SkN5+SQS2OQ8 Mfs66nZeBvE1
jceAbrUNGnvdK1OHw1rdvo0LTyQzsboJDZhbVWaIKAXbLAhWcAfK7K7V9rfd ez/DXr81qQ9l
br/l+V+9n3Seh9g2WqW99B5sbMil2QCZGjYlWKnAYA4yDg9CMEZBBqx50e4r 5i5HbIr5E134
JeJLm3eNvADX95cwzReH7/7Tan/hFLlr2eVbnY0g8v5ZIG32+9z5O0j5Vz0W pfs93FtoCaha
+H5h4pnutZXUNS0y6ig1Ka0nW7MUaXDNwCzwsqE7UbaSBtOKcbK9+/4f1/lc qy5kr9v6/r52
0v8AS0l3DHC8pkXYgJJBz061X0jW7LXNHs9VspxLYXcKzwzEFdyMMqcHBGQR wea+d/hZ8LdU
8P8AhjRrO4+HUFhFb67Lc2ccZttOnsI/sTxC7uIbWWS3llc5QiLareaH8tCp FNuNE8TeKvhb
4U0PXPhTq95ZeHJLVdS0DULvT2TWY1gkj/dKty0cgSTy5Nk5jBwCMsoFDSV7 O+347/dp/Wwo
7X8/1t99v+Btf6UM8a4zIoz0yw5qlrXiHTvD2kXuqX90kFjZRNNPKMtsRRkn AyTx6Cvm/wAM
/CzVtBm8NSeJvhs3jO2iiP8AZFqTZTL4UJupZI0KzSqBsie3Tfb7z/o2BkBM 8p4d/Z88U3y+
PHvfCTWkviLQ7yDULK9t9KtrC81AujxNEtoGkaPJl2yXTPIvfBJLTZczjfv+ F/zt/lcVtvVf
i9X6Lzs+6R9f2mr2t753luwETiNmkRkViVDfKWADDDDlcjORnIIFrzo9wXeu 49BnmvkrUPg5
fNbie5+Dzax4WaSf7N4LEtgv2KV7W1SGfyTMLb5DFOmVcsm/KAhmI6Hwz+z9 qem6dBq+uadD
rHjmy1jS549fkkVrjyY4bSO6eKRjujVhHMGUbS4zkHdzaina7tt+Nr/du/Lr vaXpFNb2f9f8
Pr2TWp7na+P9Ku/HV34TQzDVbe2F0cxny3XIDAN/eXfGSDjiRcZ5x0PmoWK7 13DqM8187eHp
dc0vxNpnxA0rwdqni+219dQmmfSJ7RHRJJLcWrt9oniBUwW6cqT0Hrk4U3we 8W3XjLUZ9L8M
v4e8SNPqk9146+1Qt/altPHKLa03q5uBsZ7c7WQJH9m+QnC5haxT62bfqun9 b9E9lpy6v1/r
+vvaWp9SfaYcZ81MdPvCsqbxfpUOr3Gl/aHkv7dYHlgihd2VZnZI2+UHglGy eigEtgc18teN
vg7L4u8I6Voek/Ba48H6L9pklvLOy0/w/NdNd7EWO5zNJND5W0yBnCmclVwA M51j8FdfXxDo
OpXPg2K88RS6TocNx4mD2zz2k1rOGuUlkZhI25dhBQMG8sg4wuWkn96X39fl b+tiHpt2b/FK
3430PqUTxnP7xOOvzDioptRtLdoBLcwxmd/LiDOB5j4LbV9ThWOB2B9K+StB +AevXdzZ2x8D
v4bjhW0h8RXP2yBh4luEvoJWuzIkhkkCpHcEtOEkYXBXacsK9X0/4V/8Ix4W 8WeGtK8D6Pe6
FfawsunaJdtHBpsUPlQs0hRUfywJUkYKsZJkwcAEuHy6Xv8A1dL8b3XprYcl aXKv60fyfydv
M9m60tcn8M/B+peCPDMem6prs+v3AbcJZt5WIYA2RmR5JSuQTmWWRssfm27V XrKlpJ6MlarU
KKKKQwooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKAPNfib/yMvh7/AK7H/wBFTVv/AAx/ 5FJP+vu7/wDS
iSsD4m/8jL4e/wCux/8ARU1b/wAMf+RST/r7u/8A0okqnsBu64jSaLfqjSI5 gcK0LMrg7Typ
VWIPpgE+gPSrq/dH0qlrieZo18m3fugcbdu7PynjG1s/Ta30PSrq/dH0qOoC 0UUUwCqGpIzX
mmFWkULcEsEYgEeW/DYBBGcdSBnHOQAb9UNRTdd6adu7bcE5252/u3Gc7Tjr jOV64zztZMC/
RRRTAKKKKAKcUkh1W4QlvKEMZUEfLkl84O3rwP4j24Xq1ysmW0kuNYuTHPLa kwRjzYkXLf60
YyyEHBYNjceQMgAnfbjspkmDm+ndQ2fLYJtI+bjhc4+Yd8/Iv+1uQzw2P9rv Tr/xfL4a0vwT
ruq6obu8tLW3i1LR4Zr37LPNBNJDBNfJM0Ye3mwxQZCE9q9H+GPxOX4kx+II 5PD+qeGdR0PU
Bpt7p+rm3aVJDbw3CkNBLKhUxzxnIbOcggYr5T8LeGdF0LxRq+sa1f8AxC0H xbZeIdcNpNpf
w+F99mt5dSu5E+z3Z0uZjHIkxfiVh+9bGAcD2/8AZbgvGk+JuoXNx4hv7fUf EyXFpqPibSm0
67vIxptjGXMJghwoeN4wRGoPl9zkn0K9LDxpwlRqXbS5lrdPW9tErbdXr5Ga bu7o9T8ZfELw
v8O7GG98VeItK8N2c0nkxT6reR2yO+CdoZyATgE49AfStmyvbfUrOC7tJ47m 1nRZIpomDJIh
GQykcEEcgivIvGeqw+AvjC/iXXtC1XVtIu9HjsLG/wBJ0mbU3spVld5omigj eVBKDC2/BQ+R
hipCbvPfEE+v3Xj2ObSbPxlp2syXti+h2ixXcWjQ6SYozcpMkf8AoyygfaRt n/eh/LCcbK4V
rbz/AA/rfpZXeqWurjZvXZX9dvy29T6mor5R0nwV4x0WxstSOreNJryG10S8 eO7v7mRPtErt
Hfb0Y4I8oLujI2Rkb1VGJY8v4c1jXtQ8JQ6t4Xk8davb3PhtYfEcutjWFX7V I9usdzaIQsrs
ifanK2JXeAo3AsjCnBpyV1p5+V/u6X72Eld/1/Vz7WqvZX9tqUJmtLiK6iDt GZIXDKGVirLk
dwwII7EEV8v/AAJ8MeLtW13TbPxBq/im58P6e15PazSrqOnLc82ckPmrczSX BAZpwEmkORvU
rtGwc/a/D3WrW28RWGiTePtIvLBdcvCq3t+YnvftaSWbxM7NHKpjJYRoWRtz h1Ztwo5dYq+6
v8v6/G3clO6b87fmfZFFfHHxQ8O+O9MuBpUGveKtO8Hw6lckXiWWr6tcGRob Z4husrmK7Me9
rrB3PEp+VgNsYXs9E8H+Kpok8QXuu+KtU1m01vTIreQNdWVtNavFaLcubHOz Y2ZmIkVjG27B
UqSFGLlbzt+Nv8/u1HL3Vf1/C/8Al+h9BT+JNJtdHu9Wm1O0i0u0EjXF686i GERkiQu+cLtK
sGyeMHPSkXxPo7vparqlmzaopawUTrm7AXeTFz842/N8ueOeleDeGPBx0z4J fE/QrPTvER1e
S61QSWupvd3HnGSWVojbGUsroyMh/ckjJO759wrN1b4YeK/AmpWOspbnxRHp d1droGn2W+Jr
WxayncQyOAdjGZxEGUH5I4OrZzPS/S1/w/4b5XfkVytuy3u1+P8AX4ebPp6i vhjw/qOteHpb
Oz8S6546u/B9/qcJDafpniC2vJC1reCSFFmmnvSoaOFiVKqMKwCgktN9o8RS R6xol3qfxDfx
KNNWfwfFa/2kfJL3V59ia/dF2BvLFuHF6cYT94CQ5rX2bb0fb8f607ijqr7f 8Pa/p37XXU+2
rO+ttRhM1rPHcxB2jLxOGXcrFWXI7hgQR2IIqevleLwf411zTPF9/qd/4tg1 PTLNrnSILO9u
reN7pbu9KlUQjzgUEI8t9yFPL+UjFP8ACWsTxfGvQbfV7vxjF4xuNav0vILp 78aO9kIZ2t1h
HFk2EEDfLmTIbd8wekoPmt6/1/XT7iJSUYuT/r+tvN6H1L0qva6ha30lxHb3 EU8ltJ5UyxuG
MT4DbWA6HDKcHsQe9edfF3RfFepz2kmnm91Hwyin7fo+h3o0/UbjhvuTsRkZ MeFWS3I2sTI4
Pl1wll4rn0WL4i+HPDejeINP16/3XGhGPQLmO2AGnwiMC4kiFvGwZCoWRgAw CkdqzWqk+yf4
W/S7+Rry3aV9/wAD6IrmfFfxO8IeBL2ws/EninR9Aur8lbSDU76K3e4IIBCB 2BbBZRx/eHrX
zhpzaiun6j9l/wCFiH4ZG5sxf/bBqx1zzvLm+0eTv/0zyt/2PPk/L/rdvy+Z XU+FNc0X4ea7
4gfU/C/irVrHxBFatpGoSaJfalPPZrbrGLW5Zo2midJPNYi6K588tuOZAl8v vNdvx22+/TvZ
kP4W9v8Ah/06rp3PosHIBHSlr5D8SR+NJdZ12PRm8cQeLWbVRqJf7X/Zyaf5 cv2L7FjNr5ob
7Lt8rMv+s3876l8eeG/FHgLRPE2p2OueMlt7Oe+hillv7m4WGzbTfO3qGLbi LnJSQ7mU/u1I
X5KFG6Tvo1f8bf18+xTjaXKt72/r9O+nc+t6a7KiMzkBQMknoBXxxrU2tzaR r58MN45XwRqT
WMbX2tQa9Le2N4PPeeWG3Ro754mAtk2xukQLEjhZFPafBTwh4r8QW9yfGF/4 lk+w6SLWzSae
7sYpm869i8xkaQuzmEwn968jD925JcB6mScYSa3X+V/673uTpdLv/wAD+n2s /K/0dZXlvqFn
DdWk0dzazIJIpoWDI6kZDKRwQRzkVPXwlD4e8W6dY+C9P07W/GnhDSLHS7eK AXOh67q0kepr
I4uRIILlDsGItonWS3ZR+6+XeD6DqHgbxlJDqOpLq/jQ3z2mr3ixRX1ysZuY b0GxCxg4A8tm
AjA2yp99ZAq4vkTa5Xpd/ctb/Pp8u45Ll066fj/ls/O66H1ZVe91C206JJLu 4ito3kWJXlcK
C7MFVQT3JIAHckCvjW50/wCJU3jHxnLceKfE1nrbx6kkGm2mgaq0MkBWT7L5 N0J3sFYL5LBk
hWUldrfMz7u0+Ivw0ubHTfEGnu3jPVvD0dzourMINTv7i5Egum+1tA6OZflj VG8mI4XAKIGI
zFtIu+jt8tf0Wt/+DZyVpOK13/r59PLU+nQQe9LXjfiLQ9d1HxbZT+BINU0a 7WKH7brOpXDD
Tpo9nCSWsmXuJgPLLMohYquz7SpUpXsSAhRuILY5I9adtLkX1t5J/f8A1/Ww 6iiipGFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAea/E3/AJGXw9/12P8A6Kmrf+GP/IpJ/wBf d3/6USVgfE3/
AJGXw9/12P8A6Kmrf+GP/IpJ/wBfd3/6USVT2A2vEQ3aBqQ3qgNtJ8zqjKPl PJDkKR7MQPU4
rQX7o+lUtcfy9Gvn3bNsDndu24+U853Lj67l+o61dX7o+lR1AWiiimAVm6qu b7SDvVcXLHDK
hLfupOAWOQe+VycAjGCxGlVDUX23emjdt3XBGN2N37tzjG4Z6ZxhumccblTA v0UUUwCiiigD
NgX/AIqG9O9Tm2hGwKm4fNLySDuI9iMDBwSS2NKqFxaXZu5Jra4ii3xqm2WN nAID843gdWXo
ASFIJ5BWSOK+EwL3EDRbuVWEhsfNxnd15TnH8LcfMNqA8yk/ac8EC/vrSCLx PqDWd3PYyzad
4T1S6h86GRopVWWO3ZH2ujKSpIyp5rrfh98TtB+J9nqVxoT33/Etu/sN5BqO nXFhPBN5ccu1
op0RxlJY2Bxghhg18UeDLXwdp/xHvvGl98Uvhv4X8Z6D4i8Q2dlB4gWY3lnC +q3xKyINRiRt
wnkYExA7ZF5OA1fQ37KWvnxRffFrVP8AhItH8WC48VpjWNAj2WVxjSdPX92P Nl+7jafnb5lb
p0HoV6FCnThOjV5m0rqzTT107NLTW616WVyE2200e8ySpEMu6oPVjinAhhkH I9RXgPxek8A/
8LVSP4vDSB4S/suNtG/4SYJ/ZZu/Mk+0Z80+V9oCeTt3APsMmwkGTHK6p8Vb vR/GNtYeGvF3
2ZYLqws9C8DpBCq6lpckMZkvAZEM8gjV5mDxuqL9n2sCQ2eFK9vP/hv6+fRG ri02uyv+X+e7
srn1O6LIjKwDKwwQehFR2Vlb6daQ2tpBHbWsKCOKGFQqRqBgKoHAAHYV8s6N 4z+I1pZ2Gp3n
ji51BPs2iX8lq+nWyJIb12imiJWMMI12h0wQ4Ync7rhBz+k/H3Wf+EeXU9P+ Jf8AwmkF34e8
7WZrN9Pii8N37PBHCzTLCywRkyTs4nWYhYWZVOxlauRpyT6b/JX/AOB6iS5n p/V/6/y10Psy
kBB6HNfLXwM8eePPiFr2naRqPjSO4s7NryaXUNJe2vRqSRmzkiAufssKMhW4 kQtHCmVIwdw3
nmNK8ReK9B0/xFYeH/iXfPd6Sde1O7sLqzs5Xtp4b1GihkUQqyxSJIzkEh2W QFHUbTRyO8V3
V16f1/WxKfMm10dvz/y/rU+zaK+O/id8U/iL4TuRoS+ObHSbKHUrmN/FGvXl tpOWENtLFbNM
1jcQZ/fzYXyldliUhyUff2Wi+KfH2oxr4hvPGcTpaa3pmnPpejwQS6bdR3EV oJWEzR+a67pp
HjdWTqu4MOKUYudrdbfja35ocvdV35v7r/5f56n0gXUDORj1zRvXj5hz0561 8zaBBG/7PfxY
0y48TXXiO5hudYhu7G+W3D2G6WYiMpHGhAdSJBvySHBU7SBWZqel+Jvh9qvh /VPEFtPJpXha
4vLTQI9NkWWa5sxp9xL5u1jgSACOEB+8DNwsmBPS/lf8P+G9d9lcrlb0W92v uf8AV+x9TXGn
213PbTT28U01s5kgkkQM0TFSpZSeh2swyOxI70R2FrFezXiW8SXcyLHJOqAO 6qSVUt1IG5sD
tuPrXxX4X+PXiM7LHxJ8XNK03QZ9QhH/AAllrqmn3yxxSW92fKFybKC3DCS3 TjynIO4FmyAs
z/HLxU2m6pDdfFSLT9dtLD7T4XsBb2Ql8VH7VdpbMY2jLSrcJHbcW/l5L7kK hgBr7OV7Ly/H
+tvuuKK5lf8Are33eey6tH2qCD0Oa53Tfhx4U0bxTe+JrDw1pNl4jvlKXWrW 9lGl1OpIJDyg
bmGVXgn+EelfOun+KvHV/o3i/ULTxNN4di8PW0upR6dY6fa+XcTC9vQ8cxaN iUYRIG2bHJBb
fkk1q+DfitqGsfF7SbC8+Ih/tm51i+srzwDss0+x2sUcxhlKeWbnLCOGTzDJ sbzMgBWUCVB8
3nr/AF8/+HJbtFt7f1+X/DXPpikBB6HNeZ/F3WvFemT2keni907wy6n7frGh 2Q1DUbfhvuQM
DgZEeGWO4J3MDGgHmVwGk/FvQfCyfE3SdC8SabfeLw7XmkaRNd/ary8C6bA6 OsIfzZwQpb5c
lsHnvULVSfZN/db/AD/DsacrbS7n0ZTHmjjIDuqk9AxxmvlDTvjFftY6hbw/ FdtU8FfabNLn
4jlbDOmySRzNLbhlhFuuGjtxmRGK/asMSShE8d98J9Q8U6nL8Vdd0fxPMyWz eF9Y8SNAy3tm
YE/fWLKBEZmm8zebZVfPlZGPKJvl95x7f8D8ddvnsQ9I3/re39dtnZn1X1qC +sbbU7Oa0vLe
K6tZlKSwTIHR1PUMp4IPoa+TPEnxo8VWGr64uk+NTc+IEbVYbnwk9pbgaHaw Rym1vTGU887i
lv8ANI5jk+0ZUAFcW/F3jr4heA7DxBdv47nvY9Pub2xia+0+1VFUab9sSaQp GuXjk+UY2qY+
GVm/eUKLaT7q/wCNv66eZTTUuXre39f1fy1V/q4AKAAMAcAUdK+PNc+N+r2O l6/HofxRTxJ4
fuGsUsvGsl9ptpZ6deP57z20t4LWSARhIocAwySBp1BPzhl6/wCDHinxz8UL a6/tjxTNBHp+
khXi02CCQXc5mvYDK0rwLuBEUbjZHGCy52hWKVMk4xlLt/lf+v8ALUnRNJvf /gf5/g1ufSgO
enNLXwhpnxX8Y+HtG8DaNoXxN0W106DR7Z47zxVq1rpou7zeyTWL/wCgSCTy dkaNFG0Myb/n
YllK+i6j4w+I6RajqieOLiKNbTV9QSyTTrYxobK9EcUQYx7jG6NtkySx2qUa M53acl2uV3Tb
X3ajknHR76aep9VUhIHU4r4xufjZ8SpPF/jIDxl4b0yezj1JIvDNxqURvreO JZDbzx2DWayk
kLFIWa5eNkdmUAFQvWfFD/hIdM0nXdL1r4h6sun2F5oernW3tbKOWwSS7YSj PkeWIU8tXDSK
xXBLuy5rO2kX0dvxdv8AghJWk49V/X/APqOivHPEev6/Z+LrKPwPqN/4mvZI oTfafdwK2l+W
U4ma7AXyJGHl5WMykK28Wzbi9ewoSVG4ANjkD1ptWVyb628k/v8A6/XYdRRR UjCiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKAPNfib/AMjL4e/67H/0VNW/8Mf+RST/AK+7v/0o krA+Jv8AyMvh
7/rsf/RU1b/wx/5FJP8Ar7u//SiSqewG7rnm/wBi3/k/67yH2ff+9tOPufP/ AN8/N6c1dX7o
+lUtcTzNGvk2790Djbt3Z+U8Y2tn6bW+h6VdX7o+lR1AWiiimAVnalIwvNNC MoX7QfMyX+75
b/3eOuPv8f8AAttaNfKHxR8ReLbHxh4VXQfCXhvxBaXOv30Wq3er3TJM8ape 7IpiLSbyoVKW
+2UNksqRbQrbqajcTdj6uByOOaWuK+Hd7fXHhSN7eCCSEXF0kQeYoFVZpgqA BThVCxqMdBnj
5QG4D9pHxX8X/Dmr+DIfh1oNtqHha7mlXxZqyost9pVoDF++tIi/72UIZ2VB FNlkUbGztalH
mlyh0udp8Ofjz4H+LPijxf4d8K61/aeseErv7DrNv9mli+yzb5E27nQK/wA0 UgyhI+XryM+g
V5r8E9O+FZ03UtW+GDeHdQiu5hDqesaFNFcy3lwg3ZurhCzTS/vCxaRmcmQs SSxJ0/Hupz6f
4s8BRR3UlvBc6pLHOiyFVlUWk7BWHcblBwe4B7UrK9kPpc7ekBB6HNeDal8Q PG198RfEPhvw
tcaLp4ha5uDfatb3F6FEUNkVVYlnQYbz3B2soGAcEls4/wAD/inrfirx/qFo bK20e11OePVb
m4uwZVuy2n2ube1KsMMhYMzSD7uAqPuZonCLnrtpf7/6f3eYS93f+v60Poxr SBiSYYyT3KCn
xxJEMIioPRRivm3XdU8b2nxB8aWuivqt/p2uaj/ZTXKzs8WhFLOGXz1UnEas jTjK4HmiHIO8
kYul/H7xloaeC47GE634bjt9N07V7y7sl8xLyeJDzdSXiu7Ylic7LaQHJBcH cUmKbV/8P/k1
/wDgK+12vMck43b2V3939PTfQ+rJIklGHRXH+0M0eTHuB8tcjgHAr5jf46/E nTv+EUW5k8LX
j+LLC3vLX7PZzxrpbNcWkTrMTM3nAi6JUgRYMeCDuyrZfjb48sfF93oFwuh6 hrunXo0wanbx
XFvY3Kyy6f8AvBB5z7WRbtlILOd0Ywyh2WrVObdrd/wdn+Ngasrn07NbxzxP E6BkdSrD1Bqn
ougaf4e0i00vT7ZLextYVghi5baigBRk5JwAOTzXhP8AwtH4j3GvzeC01Twt aeJLOS8ln1uf
SrhrWeGGO2cJHafaQyuftagkztjy84O/Cen6L431O7+Emk+KDpTavqlzp0F1 JZafhQzuqlio
ZiQq5JwCzbQdodsKc37sHN7aP5O9vyYJNyUeup2iRJH91FX6DFHlxqSdqgnq cV8ueN9f8TfE
7RPDDWes2WpXl9rfkXGg6Xrl94fSw22UsrW1xcxJ9p81SVYh44sgRgxRnJaL x5qPi7Rvh9r/
AIRtL3RfD1tpPh/+0NUXVNRvPEFxcieSdRHDdTyQuABEcSSB+XChAE+a+R3s /wCtL/1a6D09
fxt+fex9UNDHIMMisPcA0uxEX7qqB7V806v8fPGfh/S5/Fe7QbzwzHPqlnFo KW0qXwaziuCG
ku2l2Lua2OV8n5Q+NzbclD8Q/iR4h+DHj0+MtGPh0SWBSz12OOC2jgiljcPM 0cF7dttiwrF1
YM28YQbS1Llb/ru7f15DSWjk7K9u+2+nl+PQ+lkWNgSgUg9SO9KQrcEA+xr5 V8JfDq/sviXr
K6NpKR+E9D1KCK2js/G2paZHbRpawSFItMgT7O67mZsMwDlm3e8E/wAV/GUe v+G/Fd1qfhm4
n13RMaRZW9rMsemi6vbKJWuZfOb7QF8xeVSHcVI+XcCrUeZpR6/qm199vTzJ 1td9Lf5fh9/k
fUGoeGtM1W7065urRJJtPmae2bkBHKNGTgcH5XYc56+uKIfDem2+t3Wrx2qD ULmGOCWbJO5I
y5QY6DBkfoOc89BXzZ4k+OXxX0fVh4S0yy0jxN4nW8uQ1/pmmRpC0EUVq+0W 1xqMPJN1y4nb
GwfId2V9W8XfEbxFZfDNrrR9Lsj8QBaWc03h6e7gke0adwh3AzRpJtIl2jzU EhiKq46gs+VS
XW34/wBa9upXK20v60dtT04Io/hH5VyVl8KfD9j42l8WBNQuNYfdt+16pc3F vAWGC0Nu8hii
bGRlEU4LDoxz5L4T+OPi7V7LWtSe40fUdM8PaU19emLSbuwuLyUPdIYlhnfd bbTAhJcSfxgA
gqw7OHW/G2l6Xox1nxR4QvpdRu3DG1tZbEtB9mkcRW4aeXzZg6hs5A8sOdoI zUP3G31S/P8A
zsHK5e6/u9Nfw/P529W61H9ni3bvLTd67RmvGF8f69Z/Cv4aQaRqWnR6/wCI UtrT+1NcD3MU
TfZXmZ2jV0aV2ERAXzF5bdk7cGj4K+LHjL4h3Vpa2t9oWhPpcbyavNeafLcD UQl1Nbs1oonT
ykP2Z3DMZceagwdpLXOPI2n0dv1FbRPur/ovvf8AwT3XyItpXy02nqNowaDb xNjMSHHTKjiv
k/U/jt491/QvHdq7waRYT+HrrWvD2vPpy2Z8iNlAcot9LKcpIpDOtuykZ2HJ V
Re: Change lable name on creation [message #125507 is a reply to message #125349] Thu, 10 May 2007 08:58 Go to previous messageGo to next message
Originally posted by: DolphinS.Rambler.ru
I've just express myself a little bit wrong saying label below and label
above. It suppose to be text below and text above.
Re: Change lable name on creation [message #125543 is a reply to message #125478] Thu, 10 May 2007 09:25 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
1. May it be 'Location' child node?
2. You've said that you change bottom label programmatically - what does
it mean?
> exeactly.
Re: Change lable name on creation [message #125554 is a reply to message #125543] Thu, 10 May 2007 09:52 Go to previous messageGo to next message
It is definetely a part of this label, because without my changes in
programm it shows the same defaul value. But the text below doesent
change if I change the label text manualy in propeties window.
Programmatically chenges means:
In class FunctionEditPart I cahnge the foolowing metod to seem:
private void createContents() {
// as I understand creates the first part of the label
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel functionNameLabel0 =
new org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel();
functionNameLabel0.setText("Enter the function name");
this.add(functionNameLabel0);
setFigureFunctionNameLabel(functionNameLabel0);
// as I understand creates the second part of the label wich
// I'd like to change. But It changes the below text part.
// If I comment this, than it creates the Label as it should be
// but in that case I can't find where to change the text of the
// second feature.
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel clockNameLabel0 =
clockNameLabel0.setText("c" + SystemEditPart.gls.clockCount);
SystemEditPart.gls.clockCount ++;
this.add(clockNameLabel0);
setFigureClockNameLabel(clockNameLabel0);
this metod is generated by GMFgen... seems like a bug here.
Re: Change lable name on creation [message #125567 is a reply to message #125543] Thu, 10 May 2007 10:01 Go to previous messageGo to next message
It cannot be 'Location'. At the first screen shot you can see all the
child nodes as well. In and out ports are located just outside a
function rectangle and Locations appear as yellow rounded rectangles inside.
Re: Change lable name on creation [message #125610 is a reply to message #125554] Thu, 10 May 2007 10:28 Go to previous messageGo to next message
So you've mapped two model attributes to produce the text of the first
label (functionNameLabel0) and defined the second label
(clockNameLabel0) as simple child figure (without editpart and notation
view). If you want to 'connect' the text of the second label to some
model property you should add mapping for the second label as you did
for the first label.
> // second feature.
Re: Change lable name on creation [message #125683 is a reply to message #125610] Thu, 10 May 2007 11:47 Go to previous messageGo to next message
Thanks! You're right. I should've not define a second label figure. Now
all seems to be more clear.
I've just realize that I don't need to change a label text, because it
doesent affect on EMF model file. I need to change the context of an
attribute 'clockName' on element creation. In this case I hope that the
label context will be changed as well.
... trying to find out how to do it...
Re: Change lable name on creation [message #125919 is a reply to message #124907] Fri, 11 May 2007 04:37 Go to previous message
Originally posted by: fanshuchuan.163.com
Hello:
You may have a try by using the code below to set a default value,when
creating a element.{
SetRequest setRequest = new SetRequest
(selectedEditPart.getEditingDomain(),
ViewUtil.resolveSemanticElement((View)
sourceElementEditPart.getModel()),
nameFeature,
"defaultname");
SetValueCommand setValueCommand = new SetValueCommand(setRequest);
selectedElementEditPart.getDiagramEditDomain().getDiagramCom mandStack
().execute(new ICommandProxy(setValueCommand));
the "nameFeature" paramete is a variable of EStructuralFeature type for
the element.
Hope this helps.
Previous Topic:Undo/redo command stack - size limit
Next Topic:Attribute non editable in property view
Current Time: Thu Oct 23 06:10:50 EDT 2025
Powered by FUDForum. Page generated in 0.07603 seconds
