Home » Eclipse Projects » e(fx)clipse » Support for PropertySheetPage in EMF.Edit.UI(Are there going to be extensions for the EMF.Edit.UI support in e(fx)clipse?)
Support for PropertySheetPage in EMF.Edit.UI [message #1245267] Thu, 13 February 2014 09:51 Go to next message
I'm trying to connect a bunch of simple TextField controls to attributes of an EMF model. The EMFEditFXProperties.value() method is a quick way to create a binding between JavaFX and EMF (inc. undo/redo support).
But some features are missing in this simple approach, namely support for live validation, decoration, and setting values (using a SetCommand) on "focus lost" instead of "key typed". These features are implemented in the SWT Edit.UI bundles (DiagnosticDecorator, ExtendedPropertySheetPage, etc).
Ideally, I would need an equivalent to the ExtendedPropertySheetPage for JavaFX instead of my simple TextFields. Is something like this on the agenda for the Edit.UI bundle in e(fx)clipse?
Uwe
Re: Support for PropertySheetPage in EMF.Edit.UI [message #1245869 is a reply to message #1245267] Fri, 14 February 2014 06:30 Go to previous messageGo to next message
I know Torsten has been working on a form api in a side branch but this
work got stalled a bit.
The org.eclipse.fx.emf.edit.ui-bundle holds adapters to setup JavaFX
(Table/Tree/List/TreeTable)View instances including inline editing.
There is no plan to implement something like the Eclipse-Platform
Propertysheet system currently which is bound to compat layer as of now
anyways.
I can certainly see the need for something like this, you can always
file a bug report but without you driving it I doubt we can get
something in for 1.0.0 (at least not in my opensource time).
Tom
On 13.02.14 15:51, Uwe San wrote:
> Cheers,
> Uwe
Re: Support for PropertySheetPage in EMF.Edit.UI [message #1245874 is a reply to message #1245869] Fri, 14 February 2014 06:43 Go to previous messageGo to next message
Thanks for your reply. I assumed some work had been done but it had not gotten very far. This is a very interesting area for us so we'll consider making contributions.
EMFForms may be worth a look as well, since they seem to cover similar grounds. Their JavaFX renderer is due in the 1.3 release.
Re: Support for PropertySheetPage in EMF.Edit.UI [message #1249468 is a reply to message #1245874] Tue, 18 February 2014 04:30 Go to previous messageGo to next message
we are indeed working on a JavaFX renderer (although it is not due for
1.3 :-)
However, if you are interested, you can find a very first prototype here:
https://dl.dropboxusercontent.com/u/23674036/ECP%20e4%20FX%20Demo.zip
It does not only include EMF Forms, but also ECP. No all controls work
yet, but you can get a first impression of the feasibility.
Best regards
Jonas
Am 14.02.2014 12:43, schrieb Uwe San:
Re: Support for PropertySheetPage in EMF.Edit.UI [message #1249601 is a reply to message #1249468] Tue, 18 February 2014 07:24 Go to previous message
Thanks for the prototype, Jonas. I'll try it out.
If the renderer is not coming in 1.3, you may want to change the target milestone of this bug. Wink
Previous Topic:OSGI DS services not working when I am trying start with with different module.
Next Topic:e(fx)clipse - 0.9.0 Endgame
Current Time: Wed Jul 23 11:57:21 EDT 2025
Powered by FUDForum. Page generated in 0.35173 seconds
