Using JavaFX in Eclipse RCP Web Start Application [message #1240409] |
Thu, 06 February 2014 06:37  |
I found a short discussion on google groups:
https://groups.google.com/forum/#!topic/efxclipse/CYHPLA0dTec
and decided to continue topic here.
I am trying to create a webstart for my eclipse 4 rcp based application.
I am using JavaFX inside SWT.
I have everything configured correctly, exported product works great.
Problem comes when using WebStart.
In JNLP file I tried to add this line:
<j2se version="1.7+" java-vm-args="-Dosgi.framework.extensions=javax.transaction,org.eclipse.equinox.transforms.hook,org.eclipse.equinox.weaving.hook,org.eclipse.fx.osgi"/>
later I tried to use this line:
<property name="osgi.framework.extensions" value="javax.transaction,org.eclipse.equinox.transforms.hook,org.eclipse.equinox.weaving.hook,org.eclipse.fx.osgi" />
Moreover, I tried to add the same property value as in config.ini in exported product, so with reference\:file\:....
Neither of them work.
I think is more general problem with osgi extensions under WebStart.
Any idea?
Paweł.
Re: Using JavaFX in Eclipse RCP Web Start Application [message #1240458 is a reply to message #1240409] |
Thu, 06 February 2014 09:06   |
I really can't help because I don't use WebStart generally speaking I
think you have to ask at an Equinox specific list.
Tom
On 06.02.14 12:37, Paweł Doleciński wrote:
> Any idea?
> Cheers,
> Paweł.
FUDForum. Page generated in 0.06586 seconds
