SWT not recognizing changes in focused FormField [message #923223] |
Tue, 25 September 2012 14:21  |
i'm on my way to catch some first impressions on scout following the instructions in the 3.8 Tutorial Minicrm
(http://wiki.eclipse.org/Scout/Tutorial/3.8/Minicrm/Add_a_form_to_edit_the_data).
While editing (and updating) an existing record is ok unter rap and swing, it fails under swt - if one make a change to a single Formfield (in the "Edit Data" example) and click "ok" whithout moving the focus to another field.
It seems, that the FieldValue is still the old (initial) value, hence the "SAVE_NEEDED" detection result is false.
I'm not sure if this is a bug...so i start this question in here...
OSX 10.7.5
SCOUT 3.8.0.201206130843
Eclipse Juno 20120614-1722
Testet with Java 1.70_07 (64bit) and 1.60_35 (64bit)
FUDForum. Page generated in 0.06757 seconds
