| Can't use hovers... [message #123387] |
Sun, 11 December 2005 08:22  |
Originally posted by: tomz814.yahoo.it
Since a week ago I used Eclipse 3.1.1 whit java 1.5 normally.
Now,eclipse shows me the code assistant,but if i select an item (for
example,BufferedReader),the help about the command i selected doesn't
appears (is this hover,isn't it?).Why?what i need to do?
I'm a student,and it was a very helpfull things to learn java....
| Re: Can't use hovers... [message #123578 is a reply to message #123400] |
Mon, 12 December 2005 08:59  |
>Are you looking for the Javadoc view? Look under >Window -> Open View...
>Otherwise, try hitting F1, otherwise you
FUDForum. Page generated in 0.08614 seconds
