Home » Language IDEs » Java Development Tools (JDT) » Home and End does not work properly in M3I20031104
Home and End does not work properly in M3I20031104 [message #121912] Tue, 25 November 2003 15:41 Go to next message
Hi!
I have problems with Home and End under Linux. They work as expected in Windows,
i.e. Home = first character on line, and, End = goes to EOL. But, under Linux
Home = first character IN FILE and End = goes to EOF.
I use the Standard key-mapping as always. It does not seem as if I can rearrange
the mappings.
Any ideas? This is bugging me like crazy - kinda hard to just let go of 15 years
of habit :)
Kind regards,
Jimisola
Re: Home and End does not work properly in M3I20031104 [message #122191 is a reply to message #121912] Wed, 26 November 2003 04:29 Go to previous messageGo to next message
This is fixed in the newer builds, try M5.
-tom
Re: Home and End does not work properly in M3I20031104 [message #122546 is a reply to message #122191] Wed, 26 November 2003 13:47 Go to previous messageGo to next message
Can't go M5 because of plugin dependencies. Do you have a bug # so that I can
check if it was fixed in an M4 Integration build?
Jimisol
Re: Home and End does not work properly in M3I20031104 [message #122659 is a reply to message #122546] Thu, 27 November 2003 05:07 Go to previous message
Go to bugzilla, type in "home end" in the search expression, enable
search for fixed bugs, and you end up quickly with
https://bugs.eclipse.org/bugs/show_bug.cgi?id=46037
-tom
Previous Topic:Building project with compiler compilance 1.4
Next Topic:local history files...
Current Time: Fri Sep 19 09:02:33 EDT 2025
Powered by FUDForum. Page generated in 0.07046 seconds
