Home » Newcomers » Newcomers » Insert space for tabs not working on C/C++ files in Eclipse CDT("insert/use space for tabs")
Insert space for tabs not working on C/C++ files in Eclipse CDT [message #1221957] Wed, 18 December 2013 15:53 Go to next message
I have not been able to "insert/use space for tabs" feature work on Juno SR 2 on C/C++ files using the native editors. The feature works on text files. The platform is Ubuntu 12.04.
Re: Insert space for tabs not working on C/C++ files in Eclipse CDT [message #1222038 is a reply to message #1221957] Wed, 18 December 2013 23:54 Go to previous messageGo to next message
You might ask in the Eclipse CDT forum. The equivalent feature in Java
actually involves a Java-specific setting for the Java editor. I'm
guessing that would be true reciprocally for C/C++.
Re: Insert space for tabs not working on C/C++ files in Eclipse CDT [message #1696002 is a reply to message #1221957] Thu, 21 May 2015 02:14 Go to previous message
Hit the same problem with TIs' Code Composer Studio (6.1) which is based on Eclipse.
For others hitting that thread in search for the solution to the problem (like me), i'll post it even if the thread is... well, old. Wink
After some poking around i ended up performing the following steps to get the desired result:
- Go to Window -> Preferences
- In tree select C/C++ -> Code Style -> Formatter
- Click 'Edit' button
- Tab 'Identation': Set 'Tab policy' to 'Spaces only'
- Click 'Apply'/'Ok'
HTH,
Matthias
Previous Topic:Hide (not just collapse) comments?
Next Topic:Sudden startup problem
Current Time: Sun Jun 15 08:31:28 EDT 2025
Powered by FUDForum. Page generated in 0.07807 seconds
